Tried printing double sided and now the job will not complete. I can not delete, pause or restart the job. It is affecting my other printing jobs.
Improve the FixYa experience for everyone by voting.
The first thing you should do is have Microsoft check your operating system for errors or inappropriate drivers. It only requires three clicks and it's FREE. You can give it a try by CLICKING HERE
SOURCE: Print Jobs from our IBM Unix System Reports creates Ghost Jams
The answer to our problem ended up being a firmware upgrade to the Canon iR7095. I would look into that as your possible solution.
What it means is the tank to collect waste ink (from cleaning etc) is full.
Canon suggest you return ther printer for replacement of the absorbant mat, suggest you scour the web for DIY cures.
SOURCE: We own a Canon PIXMA
the paper pulling gear is blocked by some dust on the right side.a proper servicing is required to make it work fluently.a common problem.not to worry.
for any further queries feel free to ask.
thanks
SOURCE: unable to delete/cancel print job while it runs
Hi.
To temporarily delete the print jobs in the cue do the following:
Disconnect printer USB.
Restart printer.
Restart computer.
Access printer cue with printer not connected (get there from control panel)
Clear printer cue.
Connect the printer back.
If the printer cue gets stuck too often, and always with different documents, try reinstalling the printer software.
Regards.
Ginko.
1. Browse to Start -> Run... and type in NET STOP SPOOLER (this will stop the
print spooler service)
2. Browse to your windows\system32\spool\PRINTERS\
folder. You should see files there ending in .SPL and .SHD created around the
time you tried to print - delete these files.
3. Browse to Start -> Run... and type in NET START SPOOLER (this will restart the
4. Double click the printer icon in the lower-right
corner of your taskbar to examine your print job queue and browse to View ->
Refresh.
I hope this information has been helpful.
