Question about GoVideo DVR4250 DVD Player/VCR
DVD disc stuck inside
I put a DVD in it about 2 years ago, and have not played it since...The DVD is still in the player, and when I attempted to eject it, The eject door does not swing up and a I don't get any response.. The Eject doesn't work.. I can find no pinhole of any sort to insert a paper clip... What am I doing wrong
  • 3 Answers
SOURCE: Disc Tray Will Not Eject
Just next to the eject button on the actual recorder there should be a tiny pinhole.  If you use a small paperclip and insert it, then push, you should be able to manually eject the DVD.  Hope this helps!
Posted on Oct 16, 2007
SOURCE: the dvd player will not eject the dvd
We once had 2 DVDs in the tray (thanks, kids). The tray would not open and had similar symptoms.
We eventually pulled/pried-open the tray (while it was attempting to open by itself, aka you could hear the try motor was activating.)
I'm sure a tech would cringe at this, but it did eventually pop open (with our aggressive help) - and all is well.
Good luck.
Posted on Jan 10, 2008
preachw996
  • 1179 Answers
SOURCE: DVD slot does not open. Can't insert into it.
Sounds like the dvd door is stuck. Try using a paperclip in the small hole by the dvd door to open manually. Once opened then try to use the button to close. Hope this helps.
Posted on Dec 22, 2008
SOURCE: Go Video DVD will not eject
this suggestion made on this forum worked great for me.
I don't care if it does sound silly.. smack the unit smartly over the eject tray when you press the eject button.
Posted on Dec 27, 2008
  • 4234 Answers
SOURCE: System will not eject video tape and is locked
This unit is confused. The timing may be messed up. Try unplugging the unit for 1/2 hour. This will force a system reset and make the unit go through a complete startup check/reset. This may clear it up. If not, hopefully the symptoms will change slightly. Please post the results of the "reset".
Thanks,
Dan
Posted on Nov 03, 2009
I bought my first RTD215 2 years ago but the dvd player got stuckand wont open nor play... I bought another unit same model and after 8 months the same thing happened.. the dvd player got stuck again but...
If you really like the unit (disregarding the DVD player issues), maybe you could buy a GOOD stand-alone DVD or BluRay player and be ready for an upgrade in the electronics when the bug bites.
Feb 05, 2011 | RCA RTD215 Theater System
My DVD tray will not open, and with no disc inside the display says 'reading' constantly. Any thoughts?
The DVD player in model DRC8295 uses a magnet to pull the Disc tray up into position. You can open up the front disc cover and push down slightly on the Disc tray and then push the open/close button to eject the tray. I had to do this on my unit and therefore I recommed leaving a Disc in it at all times. I leave a "Bad Disc" in mine and it opens/closes with no problems.
Oct 11, 2009 | RCA DRC8295 DVD Recorder/VCR Combo
Dvd wont play ...each time you insert a DVD it shows DVD HO2...
I had the same Problem, player was only 13months old when the error HO2 appeared (typical huh?) anyway 2 years of this thing getting shifted from cupboard,wardrobe,attic, (did'n't want to throw it out cause it cost me £700), finally it came to fix it or bin it time. scoured the net to no avail, lost the rag and half dismantled it..then during all of this ( oops I'm going on a bit LOL)
you can hear a sound as though the disc is trying to be read, after 100's of attempts to get it to work, I finally noticed the disc had not changed position. (disc was not spinning) pointed to the Motor??
what I did to fix this was unplug from main's, remove top cover until you can see the top of the dvd disc, got hold of a pencil with a rubber on one end, plug back in, switch power on, and gently pushed top of disc ( clockwise ) and it kick started it off
that was over 3 years ago and the player is still going strong
I know its a bit rough, but nothing ventured nothing gained ;)
Feb 17, 2009 | Technics SC-DV290 System
Unit will not record DVD's
remove cover clean burner eye a little toilet paper,put a little grease on linear bearings, very little using a toothpic use verbatim dvd rw discs from cdw inc. 1x4 speed
Jan 22, 2009 | RCA DRC8300N DVD Recorder/VCR
Stops Playing: screen freezes
My friend suggested I clean the dvd optical reader lens inside the player with a fine brush (like a camera brush with a blower bulb). This seemed to help immensely. I'm not certain if this is just a temporary fix, but it seems to be ok so far.
Jun 06, 2008 | LG DP781 Portable DVD Player
46w500 hitachi tv-dvd
My Hitachi 46W500's DVD tray will not open. My son about 2 - 3 years ago said he had done something to he tray that may have caused this, is there any way to fix it at home ?
Jan 10, 2008 | Hitachi 46W500 46 in. TV/DVD Combo
DVD eating discs
It's obvious that the DVD is stuck in the player. There's only one way to get it out! You have to open the DVD player. If you have never done this before, I don't recommend that you do it.
Apr 17, 2007 | Conia DVD8500 DVD Player
Cannot play this disc
use metho on the cotton bud and check the grease on the laser sled rails is not solidified,carefull the laser lens is plastic.
Dec 07, 2006 | Sony DVP-NS575P DVD Player
GoVideo DVR4250 DVD Player/VCR Logo
27 people viewed this question
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
