Question about Jenn-Air 24 in. JDB8910 Built-in Dishwasher
Intermittant no power to control pannel Jenn Air dishwasher.
Hello, Without warning the control pannel on our Jenn Air dishwasher would not light up or respond almost like the unit was unpluged. After checking breaker and power outlet to dishwasher we decided to pull the unit out and look around for a reset switch which did not exist. I checked the float which moved freely, after finding no reset button and wiggling the connections around I gave up, banged on the motor a few times and put everything back in place. My wife leisurly walks by and presses wash on the pannel, IT WORKED! So I decide not to waste the electricity running a test cycle because it worked flawsley prior to the pannel porblem. Hours later we loaded it, filled the soap and was suprised to find the pannel would not light up or respond just as before. Please HELP !
  • dditch Nov 20, 2008
    This sounds like my problem. I believe it is either the door latch swith or the touch control panel. I live in Canada and have had a difficult time sourcing the parts. I have now gone back to the dealer to look for the parts.
  • jbatoni Nov 23, 2008
    I had the same problem. I had the control panel replaced. I bought the control panel and had one of the maintenance staff from our crew, (which oversees 250 apartments), replace it.
  • 236 Answers
SOURCE: Dishwasher fills with water... wont wash
usually if the motor is not kicking in then it is a blocked/seized wash motor or a broken wire somewhere from the timer to the motor. either will mean a stripdown. try checking out the motor first.
Posted on Jun 16, 2007
aborcass
  • 2651 Answers
SOURCE: Jenn-Air JDB890AWQ stopped middle cycle no motor activity or sound
no real reset, nut you can check for power leading to the unit, make sure the bnreaker hasnt tripped , and next if you remove the bottom acees panel you lfind a box to the right . the electrical conne\ction is made behind ther make sure the connection hasnt shaken itself loose.CAUTION LIVE WIRES BEHIND THAT COVER"
Posted on Mar 29, 2008
appldoctom
  • 311 Answers
SOURCE: Dishwasher is noisey when the pump is starts to pump water around
yes somthing /pice of somthing has gotten into the works;usually its a chunk of glass or small pice of plastic.no eazy way to fix.youl have to drain and go from the top down.[removing wash impeller pump cover and keep going down each time taking parts off and looking for some small hard somthing.im afraid youl end up going all the way down to the chopper/food grinder.leave the screws in the parts you take off so wont get mixed up.take your time.ive done it hundreds off times i know you can pull it off ,once.you can do it.ps you can let it run like that thru some loads to see if will grind up or clean its self out.knowing what i know i would have no problem trying that on my dish washer.and have done it a few times.hope that helps God bless,tom
Posted on Jan 03, 2009
heatman101
  • 43501 Answers
SOURCE: Front of dishwasher leaking from sides.
I think it is the seals...even though they look good they can be compressed and loose the eleasticity to swell and seal....
Here is a tip that I wrote about leaking dishwashers
http://www.fixya.com/support/r4546178-leaking_dishwasher
heatman101
Posted on Apr 23, 2010
  • 3247 Answers
SOURCE: After interrupting a wash cycle
It is possible that by opening the door mid cycle, the door switch mechanism has got disengaged. Refer item 11 in this diagram and expose it by taking out the panels around. Then tape it in depressed position and press start button to see if it engages.
If ok then put panel back and readjust the door latch mechanism to make sure the switch engages.
Hope this helps. Please post a comment on what you found. Please rate this solution if it works.
Posted on Oct 25, 2010
Jenn-air dishwasher will not start
it is usually the panel that fails
Apr 12, 2015 | Jenn-Air Dishwashers
Jenn air dishwasher model JDB3610AWX has no power at the control board please help
Their are a couple possiblities that could be causing that;
1) the connections where the house wiring connects to the dishwasher in of the junction box has burnt, the circuit breaker will very likely be on but the bad/burnt connection wont send power to control.
2) one or both of the door switches on the latch asm. are bad,to check those use a meter set to a low ohms setting and check for ZERO ohms when the door is closed,to check those TURN OFF CIRCUIT BREAKER remove wires from switch(s) and place one meter lead on each terminal
I hope this will help you to figure out why your dishwasher won't come on,
Gene
Aug 06, 2011 | Jenn-Air Dishwashers
Jenn-air dishwasher works in sensor clean and quick clean but not in normal or heavy clean. buttons will not light on modes that don't work
Same problem. Replaced Control Board ($167) ...no improvement. Beginning to suspect the keypad or it's connecting ribbon.
Apr 27, 2010 | Jenn-Air Dishwashers
Hi i have a jenn-air dishwasher JDB8910AWW about 10 yrs oldand started to have problems that it wouldn't drain now I can't get it to turn on..any advice??
I have a Jenn air dishwasher JDB8910AWW It fills with water but will not wash also i hear a clicking sound and the control panel blinks
Nov 18, 2009 | Jenn-Air 24 in. JDB8910 Built-in...
We own a Jenn-Air JDB7900. This morning the
More then likely the washer control panel has failed.
Apr 24, 2017 | Jenn-Air 24 in. JDB7900 Built-in...
Jenn air diswasher mod # JDB1100AWS
disassemble front door to get to the latch. Check if the latch is properly in place, sometimes the metal cylinder that hold it in place, slips out of position.
Jul 08, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Dishwahser won't start, start button won't light
I took the door apart, removed the control board, which I had expected to replace. I disconnected the ribbon cable that connects the control panel to control board cleaned the connections and reassembled everything. The dishwasher has been working since.
Jun 16, 2008 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Jenn Air Dishwasher Model JDB1100AWS Light Normal/Extra Rinse are the only two buttons that work.
have you solved youre problem ? i have a dead 11000 series unit no one has any input so much for trying to save a buck.time to switch to paper plates i had a bosh before this i went through 3 contol boards then threw it out i miss the old manual controls
May 31, 2008 | Jenn-Air 24 in. JDB1100AWS Built-in...
Jenn Air DW961UQW Partially Fills, Drains and Done
is there a diagram of how to replace pump in the jenn=air dishwasher model dw961uqw?? If so is there aweb site I could look at? Thanks Ida Vogegelgsang
May 31, 2008 | Jenn-Air 24 in. DW961 Built-in Dishwasher
Dishwasher will not run
here is the link for the manual etc. if you need it http://www.jennair.com/assets/product/6_920374_A.PDF page 27 appears to describe the solution to your issue and check page 28 about the control lock feature I hope this helps :)
Mar 10, 2007 | Jenn-Air 24 in. JDB1090AWS Stainless Steel...
Jenn-Air 24 in. JDB8910 Built-in Dishwasher Logo
244 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
