Cannot get a picture on Sharp LCD 42" TV. It turns on with a white screen but the picture does not come on.
  • tjacks Nov 18, 2008
    Turning the set off for 30 min did not solve the problem. The TV is connected to a Verizon FIOS box.
    You were no help. All that had to be done was turn off both the TV and the Fios box for 10 seconds. I should not have to pay you. Thanks, Tom JAcks
  • 3,037 Answers
I can better narrow down the problem with more information and I will get back to you as soon as possible with a solution once you answer my questions.
1. Can you get a picture from a dvd player or any other source?
2. New tv or had it for a while?
3. Has this setup worked before?
4. Has anything changed that could have caused this problem?
5. Anything else you would like to add?
Posted on Nov 18, 2008
    Genius:
  • 1,913 Answers
Disconnect from fios .then check your pwoer suply waltage and earhing.try tv at other place.
    President:
  • 624 Answers
This is an inernal problem that must be repaired by a service center. It is not a setting or set-up problem. It is a malfunction in one of the video processing circuits. Take it to a service center, unless you have very good electronics troubleshooting skills it will be next to impossible to repair. It also requires the use of a multimeter and maybe other specialized equipment to find this problem.
    Genius:
  • 1,550 Answers
HAve you tried hard reset .
Unplugging the power chord of your tv for 30 minutes and plugging back the power chord to tv .
This will reset .
How old is your tv ?
    Scholar:
  • 181 Answers
Unplug the tv from the main cord then replug it after sometime and then check.
  • 1 more comment
  • fixyy Nov 18, 2008
    mostly it gets resetted and starts working if it is not an internal circuit board error/fault.
    also when u ON the tv after unplugging it for sometime .at that time remove all the external connections connected at the back of the tv.just connect the tv to the main power outlet and ON the tv.
    if resetting does not solves your problem then its a problem on the main board of the tv and needs reparing.
T-Con Board Symptons
If you wish to get some details; check the site linked here. Pull up older posts. Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size
Jul 07, 2016 | Sharp AQUOS LC-42D43U 42" HDTV LCD TV
Hi I have teviono 42" lcd4203id model and tv is white picture nothing on there the TV powers up light comes on but it doesn't bring picture what the fault would be?thanks
TEVION 42" FLAT SCREEN LCD TV MODEL LCD4203ID
www.ebay.co.uk/.../TEVION-42...TV-MODEL-LCD4203ID-/1213...
eBayTEVION 42" FLAT SCREEN LCD TV MODEL LCD4203ID in Sound & Vision, Televisions ' eBay.Missing: white
main board for tevion lcd4203id 42" lcd tv mhdv4201 ... - eBay
www.ebay.co.uk > ... > Other TV & Home Audio Accs.
eBayMAIN BOARD FOR TEVION LCD4203ID 42" LCD TV MHDV4201-ZC01-01 (B) ... Mouse over image to zoom .... *Please open the back cover of TV then check the part number of screen, it would be on white label at back of screen ... of actual item in yourTV as well as check either if it is compatible with your TV model.
LCD TV Repair made easy # 1 - YouTube
? 7:38
https://www.youtube.com/watch?v=GryA_Zl4EBk
Aug 27, 2009 - Uploaded by Grants Pass TV Repair
I have a 2008 model Sanyo dp42848 42' lcd tv with ccfl lighting. .... bought a Seiki tv and within 1 month ...
LG 42LC2D 42 in. LCD HDTV Fusing unit - Que
Dec 29, 2015 | Televison & Video
I have a 42" Sharp LCD and the whole screen is
Sounds like the pixels are bad try unplugging it for awhile if that don't work you have to replace the screen
Mar 03, 2011 | Sharp Televison & Video
When tv is turned on picture flickers really
When it goes black can you see a ghost image? It will be a normal tv picture but very faint black and white looking, you may have to get close and look at an angle to even see it. If so that means your backlight system is failing. If you don;t see an image then it is a problem with the power section of the board inside the tv.
Check if it is covered by warrenty and get a quote if it isn't. A 42 inch is new and big enough that it should still be worth repairing but it may cost you anywhere from $100 to $250 depending on the shop to fix.
Apr 12, 2010 | Vizio GV42L 42 in. LCD Television
We have a Sharp Aquos LCD TV 42 inch. When I
Call Sharp for warrenty repair.This problem very common in Sharp tv.Picture will come on turn power on/off button few times will work.But still under Wareenty call to Sharp to replaced the main Tuner Signal board.
Jan 15, 2010 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Black square on screen that covers half the picture appeared on my 42" sharp aquos tv.
sounds like you might have PIP turned one (picture in picture) .. if there is no input hooked up for the PIP . you will just get a black screen ... you should be able to move that PIP around and change its size .. indeed turn it off .. look for a menu item called PIP .. select PIP off ..
Nov 06, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Sharp Aquos 42 in screen was black when we turned it on. Remote will only turn tv on and off, will not control inputs or channels any longer. i think i may see a little white line at top every now and...
I can try to help you with the problem, but you have to clarify the situation a little bit. First of all, give me a model number of your TV, and second of all, do you have anything displayed on the screen?
Sharp 42" flat screen LCD T.V.
This could be 1 of three things! 1-main lcd panel
2-y sustain module
3-z sustain module
This is something you cannot do yourself my friend.
Feb 22, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
No Picture
Sharp 42" lcd. TV accessed incorrectly. Resulting in no picture.
Using TV remote, changed from analog 2 to input 4. Turned off TV remote. Returned to satallite remote, turned on TV, turned on satallite, still no picture. We seem to have power but no satallite signal. Ist time users of satallite TV.
Dec 27, 2007 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
