Replacing battery My bryant thermostat needs the battery replaced but i cant figure out how to open it to replace the batteries. There's two little arrows but it wont budge I feel like i'm going to pull it right off the wall!
  • 31 Answers
There should be some clips on all four corners,try lifting from the bottom and pulling outward,then pull out
Posted on Nov 18, 2008
Screen on Bryant thermostat is blank---Batteries?
Heidi, all thermostats that I am familiar with require AAA, AA or nine volt batteries and are accessed usually be separating the thermostat from the sub-base. Some older stats have a 'ribbon' connector that maintains connection during removal, but most of the newer stats have 'pin' connectors. A picture would help...could you post one with a smart phone ??
Apr 19, 2015 | Heating & Cooling
On the temperature display the second symbol is permananently missing eg 20.0 is shown 2 .0 how do you fix it?
Display figures when lost generally can not be reallocated as the digital format has been compromised. The nonfunctional pixels are bypassed and only functional display is active and observable. The entire display needs to be replaced or live with what is available.
Feb 02, 2015 | Heating & Cooling
I put in new batteries; calculator turned on but I could not clear the screen nor input any thing. Now it wont turn on.
Open the back of your calculator. There is a backup battery behind a little door that you will have to remove with a small phillips screwdriver. The only thing that I can figure out is that you either need to leave this battery out for about 10 hours and put it back in and hopefully the calculator will reset itself. If not, you might try replacing this backup battery. Hope this helps.
Jun 27, 2011 | Texas Instruments TI-83 Plus Calculator
Thermostat says lowbat.....where is the battery and what kind of battery do i need to replace? will my furnace still come on?
If you replace the battery in time, the furnace should still work. You didn't mention what type thermostat you have, but the battery is located inside the thermostat housing. Most can be accessed my opening the flip down cover of the front of the thermostat (this where you generally program it). Inside you will either see instructions for replacing the battery or you will see another small compartment door with a battery icon on it or it says "Battery". If none of that appears as stated, the batter will be behind the thermostat housing. It's generally 1 AA Battery.
Hope this helps you solve the problem.
Mar 09, 2011 | Goodman Heating & Cooling
Cant figure out how to get back of watch open to get to battery to replace it
Take your watch to your nearest watch shop and ask them to do it for you.
You can get into difficulty replacing batteries and it is not worth the risk for the small cost saving in doing it yourself.
Mar 19, 2010 | Watches
Furnace is not working, digital thermostat does not register
sounds as if your low voltage transformer might have bit the bullet will need replacing all of the devices you mention are powered by this one low voltage t-stat
Dec 09, 2008 | Bryant 462AJC021BA Air Conditioner
Need to replace thermostat batteries, can't open
Figured out how to take thermostat off -- not hinged, after all, but snap-off arrangement.
Thanks anyhow.
Nov 22, 2008 | Heating & Cooling
My Thermostat is flashing "L6"
The battery needs replacing.
Aug 28, 2008 | Heating & Cooling
Heating & Cooling Logo
187 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
