THE CD DRIVER WILL NOT RESPOND ERROR MSG IS E:\is not accessible ...The device is not ready etc. Tried rebooting with Restoration disk ...no luck! All lines connected... Tray moves in and out... Label up on cd...an clean Would like any suggestions to prove cd unit is just inoperable and not drivers or something simple THANKS
    Genius:
  • 1,124 Answers
To prove that you will need some utility program to test your cd drive.
You can use this cd to test your drive
http://www.cdspeed2000.com/
At this point is better to change it.
Posted on Nov 18, 2008
Acer aspire PC model M3470G with error msg:can't find reboot disk or it is damaged
check bios at boot for any 'hard disk detection' options to see if the drive is actually getting power and being recognized by the system. If it is, it may likely be the boot record, which will require a reload or restore.
Jan 10, 2014 | Acer Computers & Internet
Laptop won'y start up has non-system disk or disk error
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
May 02, 2012 | HP Computers & Internet
My hp laptop shows non system disk or disk error
Apr 04, 2012 | HEWLETT-PACKARD MINI 5103 Netbook
Operating system not found
The error PXE-E61: Media test failure usually means the hard diskhas failed or the hard disk needs re-seating or the disk controller is faulty.First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.The hard drive needs to be replaced in the computer/laptop, Windows installedand the computer or laptop's device drivers plus your programs etc. to get afunctioning computer/laptop again.
Feb 02, 2012 | Microsoft Computers & Internet
I restored my acer aspire one back to factory settings without a back up device. when I try to restore from disk with an external cd. it says my disk is incorrect. it was the disk that came with it.
In that case, only the seller can solve it replacing the disk or your CD drive that I did not want to mention but seems to be your problem. Before calling them, try to disable the CD driver in Control Panel, reboot, Enable the driver, reboot and try the cd again.
Aug 10, 2011 | Computers & Internet
I'm having compaq presario A900 with Windows xp2003 laptop. When I try to install sound drive it is giving error msg like device driver not found..plz give solution for dis
Make sure your sound drivers are in fact there and are thew correct drivers. If in doubt, reinstall these drivers from your Restore disk. If you do not have this disk, look on the Compaq website to replace the disk, and then replace this defective driver. Oh --- when did your sounds last work?
Nov 04, 2009 | Compaq Presario 700 470024-192 Notebook
Full factory system restore
insert 1st cd
reboot
then a msg comes up press any key 2 boot from cd
folow the instruction and your ready to go
thanks for using fixya
Mar 17, 2009 | Computers & Internet
No screen visible
run win xp boot cd and access recovery console... run chkdsk... hit y when it asks you to... another way of doing this is right click on ur hard drive and choose properties.. tools... disk check... choose both the options asking for complete scan etc.. itll then say that scan will be done when windows is restarted.. say ok.. restart...
Nov 20, 2008 | Dell Inspiron 8600 Notebook
Windows goes off with the msg 'NTLDR is missing'
NTLDR errors are usually caused by defective RAM on the motherboard. Try removing one of the RAM sticks on your board and see if computer works fine. If still gets error msg, swap the RAM stick and try again to narrow down which stick is faulty. Sometimes, its simply some corrosion on the RAM contacts which in that case, you only need to re-seat the sticks.
Nov 05, 2008 | Umax Astra 2000U Flatbed Scanner
Computer Crashes -- error msg is that GEForce 4 (4000) is causing my crash
It may not be video card it could be system files at fault I had similar and some files were not indexed
go to C:\ right click Properties / Tools error check check errors new box opens tick the small square to fix errors and reboot while rebooting windows will scan disk and fix errors and if you are quick enough will see what it fixed then it will restart
I scan disk to fix errors every 3/ 4 weeks and do not have may problems
Aug 13, 2008 | Nvidia GeFORCE 4 MX440SE / 4000 / 4X DDR...
Computers & Internet Logo
55 people viewed this question
David Payne
David Payne
