Question about Panasonic TX-32LXD1 32 in. LCD Television
47LG50 Stuck In Standby Mode
I have a 47" LG LCD TV, model # 47LG50. I purchased it 2 months ago and it has worked great until this morning when it went in to stand by mode and I cant get it out of it.
So far I have tried two remotes, pressing the power button that is on the TV itself, unplugging the TV and re-plugging it, tried plugging directly in to the wall, and in different spots on the surge protector (monster power surge).
It is under warranty but I wont be around for a repair person to stop by until next week so I am hoping I can do something myself. Anyone have any ideas?
Thanks in advance, I appreciate any help!
    Sergeant:
    Champion:
  • 331 Answers
Try doing a hard reset i.e  unplugging it for  something close to 10-20 min  and then  try to open the  TV
if this does not work maybe there is some problem  with the power board as no light are showing if you have called a repaiman (under the warranty)  it would  be  safer not to  fiddle with the hardware much
as the warranty may get void
Posted on Nov 18, 2008
  • 10,594 Answers
TV seems have problem either in Power or Back Light Inverter boards.
I would advise to call LG for warranty and if you open your TV yourself, warranty will be void.
    Sergeant:
  • 306 Answers
Press and Hold <OK> button on remote as well as TV panel at the same time for a few minutes. To save the changes press <OK> in Remote.
PS: Be very careful while playing with the service menu. If something goes wrong, just switch off the TV and switch on it again.
  • AbdulRahiman S Nov 18, 2008
    else not much to add, but as for unplugging the TV, leave it unplugged for a minute or two before plugging it back in.
  • Panasonic Master
  • 19,396 Answers
Try first unplugging the power cord for ten minutes. The TV is in protect mode.
  • 541 Answers
If you do it yourself you will void your warranty so i would wait and they will give a a new one repair that one
47LG50 won't turn on, no standby light at all. DEAD! tried different power sources, but nothing. was on, made a "bzzzddd" noise then turned off. Serious or just a fuse?
you can remove the fuse and check them with a multimeter. put a lead on each end If the meter shows a low number (normally less than 1), then the fuse should be okay. if not than you need a new power supply board. be sure at all times to have tv un pluged while working on them and always be very cautious as the do still hold power. hope this helps
Dec 02, 2013 | LG 47LG50 47 in. LCD HDTV
LG model 47LG50 47" HDTV
you can get cheap replacement boards for this tv via ebay,...........good luck,...
cheers
Apr 10, 2011 | LG 47LG50 47 in. LCD HDTV
Im trying to find a firmware update for my LG 47LG50 47" LCD TV? where and how do i do this?
I've checked the LG support website. The product is discontinued but if you register your product you may get downloads of firmware upgrades, etc. With my phillips I couldn't see any firmware upgrades until I registered my product. Register here!
http://www.lg.com/us/support/product/support-product-profile.jsp?customerModelCode=47LG50&matchedModelCode=1000003999&searchEngineModelCode=47LG50&initialTab=documents&targetPage=support-product-profile
Please rate if this helped :)
Mar 10, 2011 | LG 47LG50 47 in. LCD HDTV
I have a two year old LG 47lg50 LCD HDTV and recent started getting "function not available now" flashing continuously on screen. Also set will not power off permanently, returns on shortly after...
The solution for the problem is to replace the control PCB. The PCB is the printed circuit board that controls the volume, channel and menu buttons.
These parts can be found and bought from Sears parts direct.
A break down of the cabinet parts can be found here.
Nov 27, 2010 | LG 47LG50 47 in. LCD HDTV
I have an LG 47" TV (47LG50) that I bought a year and a half ago. It worked great up until now. I have three seperate HDMI ports (PS3, Cable and Blu-Ray.) It all off a sudden says "no signal" to all...
Tries reset the tv and cable box,by unplug,replug both devices about an hour later.Let the cable boot up and update it softwares.Goto tv Menu goto PICTURE,go down to reset.The Tuner board it reseting to the Factory setting.The HDMI hubs,should all works now.Not than,the tv Tuner board have problems,must be change.Tries Shopjimmy.com,Ebay.com to buy a refurbish a Tuner board for the replacement.
Jul 15, 2010 | LG 47LG50 47 in. LCD HDTV
SKY REMOTE CODE FOR LG 47LG50
please follow the steps below:
TV
RED + SELECT (flashes twice)
TV
0056
try the volume if this works then press SELECT to save the code. If not then press TV again then the volume. repeat this step until the volume works then press the SELECT button to save the code.
cheers
Little Dish Fitter
Jun 08, 2009 | LG 47LG50 47 in. LCD HDTV
Sky code - LG 47" TV Model Code47LG5020ZB
If there is no code, then there is no code.
The only other option would be to buy a 3rd party remote that is compatible with both devices. Unfortunately there is no way to know if it will actually work until you try it.
Jun 03, 2009 | LG 47LG50 47 in. LCD HDTV
Panasonic TX-32LXD1 32 in. LCD Television Logo
113 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
