Question about Sport & Outdoor - Others
Not sure how to replace the belt in my MTD, Wards snowblower
I have an old Wards snowblower. I replaced the drive belt, but don't know if I installed it correctly. The blades turn without the bar on the handle being engaged. It doesn't look like the idler pulley is working correctly. Are there any diagrams available on-line?
The Model # 35153A/TMO K066B
  • djmccol Jan 04, 2009
    Thanks, it works great!
    Novelist:
  • 148 Answers
Remove the housing with the machine off
The idler pulley is designed to push up against the outside of the belt between the drive and motor pulleys when disegaged the belt should look like a loop like a race track
engage the blade clutch and watch to see if it presses up against the drive pully and the motor pulley
their should be a spring attached to the idler arm and i believe the new belt is dragging a little
you should be able to move the belt with your hands ( it should slip freely) rod is engaged or it pulls the idler away
Either a spring causes tension when the rod is engaged or it pulls the idler away
Keep working with it until it is free you may have an adjustment on the spring tension or the linkage rod has an adjustment
I am sure you can do this without an diagram good luck
Posted on Jan 01, 2009
Replace snowblower belt
Locate the two top auger housing fastening bolts and remove. The auger housing will tilt forward and then lift the housing off of the bottom 2 bolts/bushings. You will need to support the traction frame as it will try to fall onto the handles.
Feb 27, 2017 | Mtd Garden
Auger belt keeps coming off when engaged with new belt or old
Put a straight piece of metal or wood on the top pulley and slide it down. Both pulleys have to line up if you slide it down and it hits the bottom pulley you will have to replace or shim the pulley (top or bottom) with washers so they are perfectly lined up
Jan 14, 2014 | Mtd Snowthrower Snowblower 5 24" Parts...
Mtd belt replacement
control cable for snow blower #31a612e515
Mar 06, 2013 | Mtd Snowthrower Snowblower 5 24" Parts...
MTD starter ingages but wont turn motor
HAVE REPLACED THE BATTREY LATE LEY IF SO SOUNDS LIKE THE CABELS ARE BACK WARDS CK IF THAY ARE IT WILL SPIN THE STARTER THE WRONG WAY
Aug 25, 2012 | Mtd Drive Belt 42"
I have a MTD 5/20 snowblower that won't engage in Forward. It will transfer to neutral and reverse, but I can't any forward power. If I tilt it forward, the wheels will spin. I installed a new belt and...
ALL SNOW BLOWERS HAVE WHAT THEY CALL A FRICTION DISC DRIVE IT SOUNDS LIKE THE FORWARD SIDE OF THE DISC IS WORN OR THEDRIVE WHEEL HAS A RUBBER DRIVE RING THAT IS WORN. IF YOU REMOVE THE BOTTOM PLATE YOU WILL SEE TWO DRIVE WHEELS ONE IS JUST A METAL DISC AND THE OTHER LOOKS THE SAME BUT HAS A REBBER RING FOR GRIPPING THE DISC TO MOVE THE BLOWER FOREWARD, WE END UP REPLACING ALL THE DRIVE DISC AND DRIVE WHEELS ON OURS EVERY SPRING THE FOREWARD DRIVE TAKES THE MOST PUNISHMENTTHERE FOR WHEARS OUT THE FASTEST. MTD HAS A WEB SITE FOR ORDERING PARTS AND ARE NOT HARD TO INSTALL.GOOD LUCK LET ME KNOW HOW IT GOES
Feb 05, 2011 | Mtd Genuine 9460897 Snow Blower Auger...
I have a mtd 26" 8hp snowblower that need aufer
if the bolt broke off then you need to get old part of it out before putting in a new bolt.
Dec 12, 2010 | Mtd Products Yard Machines 158CC Tiller
How do you replace auger drive belt on mtd snowblower
Try going to partstree.com. This site will give parts list and view of the belt assembly. Hope this helps
Feb 19, 2009 | Mtd FASTATTACH MANUAL SLEEVE HITCH
Sport & Outdoor - Others Logo
747 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
