Question about Memorex MP3838 Radio/Boombox Portable CD Stereo Personal CD Player
Memorex 2xtreme radio/cd player doesn't recognize disc
Disc spins @ start up [erratically] then stops. when i do that w/o any disc it spins a little than stops. I think the disc is not being recognized. Could the disc be slipping on the turn table? Wouldn't this cause it not to be recognized? Something I can do to insure it's gripping cd. I cleaned little laser window. I'll try cleaning table. This unit is only about 1 year old. Junk? Any suggestions are appreciated.
  • 3 more comments
  • nancymilljb Dec 29, 2008
    My Memorex 2xtreme radio/cd player does the same thing. I hope someone can tell me how to fix it. It only worked for about a month!
  • Anonymous Jan 08, 2009
    yep Junk mine does it too
  • MitchManor Jan 19, 2009
    Yeah, had the same problem - died after about 3 weeks, the day after I threw the box into the trash compactor. CD starts, plays for maybe 2 minutes then sounds like everything falls apart. I took it apart and greased some components because it looked bone try all around, but this didn't help.
  • Anonymous Mar 26, 2009
    mine worked for about 1 hour
  • Anonymous Apr 07, 2009
    I just got a Memorex 2xtreme for my birthday and the CD player does not work. It tries to spin, but can't seem to pick up the momentum.
5 Suggested Answers
  • 1003 Answers
SOURCE: memorex black cd-r discs
these disc have a compatbility issue with a lot of computers and players reading from the dark recording surface .
the solution is simple use memorex cdr that have a mirror type recording surface on back the more reflective the recording surface the easier the media is to read stay away from dark recording surfaces.
Posted on Jan 15, 2008
early1234
  • 871 Answers
SOURCE: Not reading cds
hi
the lens may have been damaged. what you can do is physically open your cdrom and manually check for the lens. as you open the cdrom panel, be very careful as it would damage the chips inside. as soon as you see the lens, check it first by looking at it and look for dust and residues. clean it thoroughly and try to insert a cd now if it works,
hope this will help.
Posted on Jan 28, 2008
SOURCE: My Memorex MVD2042 Progressive Scan DVD player says no disc
the lens is located on the inside. you will have to remove the top casing, once you do you will see the dvd player, then you will need to remove the top bar that runs across it. you will see a yellow sticker on....undo the screws and the you will see the lens.....
Posted on Nov 28, 2008
  • 16 Answers
SOURCE: New Memorex CD-R's won't let me burn music to
Try to burn a similar disk from different package or with some other utility i.e nero or something similar, ir possible use different machine
Posted on Aug 24, 2009
cybergeekkid
  • 24 Answers
SOURCE: Memorex MP3 player MMP8595. I have an imac and my
Yeah, the MMP8595 happens to be nearly incompatible with everything except for vista and 7. As for the mini-CD, it only gives you a myDJ plugin for Media Player 10.
Basically:
get vista
or
get a new MP3 player
sorry....
Posted on Oct 11, 2009
Memorex portable cd player will not hold place on the cd when turned off
Audio books may be different but with a music CD if you press STOP once you can pick up where you left off. Pressing STOP twice reverts to the beginning.
Jul 15, 2016 | Memorex MD6451R Personal CD Player
Memorex mp4047 Personal CD Instructions needed
You may download a copy of the user's guide here.
Dec 19, 2012 | Audio Players & Recorders
My cd player stops while playing and shows er on the display
Try checking for dust on the laser eye, A fine, clean and very soft artists brush will do for cleaning or perhasp the CD has a miniscule scratch on the surface. You'll know if it is a scratch as the CD will always stop in the same place. CD's and DVD's should only be wiped clean with a very clean duster in the direction of from the centre hole to the outer rtim of the disc. Never ever wipe anything across the whole surface from one side to the other or wipe in a circular motion. There a quite a few products on the market that will help you keep you discs clean. Just google CD (or DVD) cleaner. CD's and DVD's are quite forgiving in how badly scratched they can be and still play. It only takes a small scratch or dent that can only be seen under magnification to deflect the laser beam off track.
Mar 15, 2011 | Memorex MD6451R Personal CD Player
Ccoby-cxcd375 micro sterio system has a problem the cd spins no sound then it stops spinning why is this?
maybe is the optical lens, clean it with some cleaning disc if do the same the lens is bad and need remplace
Feb 20, 2011 | Coby CX-CD375 Personal CD Player
MD6541BLK cd player has two dashes (--), the cd spins and spins, and i am hearing a "zipping" noise. it does this for approx 30 secs then shows ERR. Is this cd player ready for the trash or can i...
It needs a new optical eye,also called laser eye.The part alone is $70+.This is a common malfunction of CD and DVD players and you described the exact symptoms.Greg
Feb 10, 2011 | Memorex MD6451R Personal CD Player
Hi Last night I was listening to my disc player and when I went to change discs nothing played. I don't know if I touched the wrong button in the dark but nothing happened. I changed batteries and when...
Not to worrry , but there is a sliding button, knob that makes the set pause and called as HOLD. All you need to do is to slide the knob back,look at teh side of the door/set. please look carefully even if the pause is pressed twice.
I am sure you will find this out and continue to enjoy music during your treatment. I wish you luck and my prayers for a good treatment. Good day
Jun 17, 2010 | Memorex MD6451R Personal CD Player
I have a Sony Psyc CD Walkman D-Ej010 and I will have a cd in there at it will play for a few minutes and then stop and say no-disc. What could be the problem?
There may be a couple of reasons why a NO DISC , DISC ERROR or INSERT DISC error may appear in the display of your CD player. Try doing the following steps to troubleshoot why the error is displayed:
  • For disc players with a HOLD switch, make sure to move the switch to the OFF position.
  • Verify that the disc being used is supported by the CD player. NOTE: CD players do not support VCD or DVD discs. In addition, some CD players do not support CD-R or CD-RW discs that are created by a CD burner. For information regarding disc compatibility with your player, refer to the operating instructions supplied with the product
  • Ensure a disc has been inserted into the player. Make sure that the disc is inserted correctly, with the playback side of the disc facing down on the disc tray.
  • If the disc still does not play, attempt to play a different, commercially-produced disc.
  • NOTE: If more than one of the commercially-produced discs do not play, verify whether the discs are extended-length discs. Some players are not able to play discs where the recording exceeds the standard 74 minutes. If the recording of the disc is longer than 74 minutes, it is possible that some of the specifications of that disc were compromised and therefore, the CD player will not recognize that disc.
  • If the disc is dirty with fingerprints or smudges, or if the disc is scratched or broken, the CD player may not recognize the disc.Clean the disc using a soft, dry cloth.
  • Properly reinsert the disc into the player.
  • Attempt to play the disc again.
  • Only press the PLAY button once. If the PLAY button is pressed more than once, the disc may stop playing.
  • If the disc is still not recognized, remove the disc and leave the CD player powered on for approximately one hour to resolve the possibility of moisture condensation inside the player.
  • Please use a Lens Cleaning disc and check if that helps.
If the issue persists, please click hear to locate the repair facility near your area.
Thanks for understanding. Please let me know if you require any clarifications.
Jan 29, 2010 | Sony Walkman D-EJ010PS Personal CD Player
Blinking "disc" error
Hi Lambo, 1) Your disc may be bad: scratches on surface, the surface maybe dirty, the disc is maybe bended,... Try with other discs, if the error occurs see next steps. If not, the initial disc was bad, but don't throw away, you may be able to clean it. 2) The Laser-optics in your Walkman can also suffer: - open your Walkman as if you would load a disk; look inside and you will see a little lens inside: clean it by using a ear-cleaner ( little stick with cotton on one or both ends). First dip the cotton end in some pure natural alcohol ( ethyl) and wipe very carefully over the little lens surface 3) The drive-mechanism of the Laser may also be cause; the only thing you can do on the field; the little lens ( see 2 ) normally should be near the end of a channel which you can recognize as the cut-out of the plastic . While reading a CD the lens moves thru this channel. You can try to push very softly this lens towards the nearest end of the channel. It often helps. 4) The Laser can be to its end of life; you can ask to change the opto-electrical mechanism, but I'm afraid it will cost you nearly as much as a new player; if you can buy a second hand might be even cheaper. Important for the future: - don't write with markers on discs; these texts release small quantities of fumes on laser-lenses - smokers pollute also with nicotine-fumes their lenses and discs Hope you can get nice music ASAP; let us know
Nov 01, 2006 | Sony Walkman D-EJ100 Personal CD Player
Memorex MP3838 Radio/Boombox Portable CD Stereo Personal CD Player Logo
757 people viewed this question
Top Memorex Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
 Grubhead
Grubhead
Are you a Memorex Audio Player and Recorder Expert? Answer questions, earn points and help others
