Question about Palm Treo 755p Smartphone
When I install my battery I get the Access Powered then Palm.
After the battery install the phone will not function. I get Access Powered and Palm and then the screen goes black.
Confused
  • Anonymous Nov 21, 2008
    Same thing on 11/20 for me.Where is the hard reset?
I have a Treo 700wx with very similar problem that I solved by starting a hard reset by holding down red button while inserting the battery... keep button down until the message comes asking if you are sure you want to do a hard reset.... I hit the space bar to abort it and IT STARTED UP normally ... worth a try... good luck.
Posted on Nov 22, 2008
After a hard reset (reinstall battery while holding down the end key) I receive the ACCESS Powered screen. When I let the end key go I receive the prompt to delete all data. I key the up arrow and the...
Hi there if you can access the manufacturer website you should download the software available for your device, this should solve the problem.Simply go to the website and look for your model of palm and follow the steps.
Jul 06, 2010 | Palm Treo 755p Smartphone
Palm treo 755p tried removing battery and still only says treo across the screen and reset button dont work
in order to perform a hard reset, you take out the battery. hold the power button and insert the battery.
release the power button when you got palm/access powered. it should prompt you to erase all data. press up to erase and finish setting the device. no need to reinstall the palm desktop software.
Nov 09, 2009 | Palm Treo 755p Smartphone
My palm treo 755p power cycles to the access powered screen
There are different types of resets that may cure this issue. Try them, starting from a soft reset.
http://forum.brighthand.com/showthread.php?t=13189
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 26, 2009 | Palm Treo 755p Smartphone
Hello, have a Palm 755p Treo screen just keeps flashing
There are multiple reasons for the phone to go into an endless loop.
Fix #1 - Soft Reset - Take out the battery. On the back of your phone, pop the cover off, remove battery, place battery back in and it will show each screen once and power on normally.
Fix #2 - Hard Reset - To do a hard reset, hold the power button while you replace the battery and then release it when the Palm logo appears.
Fix #3 - Hammer
Apr 09, 2009 | Palm Treo 755p Smartphone
Palm stuck on the Palm Powered Screen
try syncing it to your computer
Mar 24, 2009 | Palm Z22 Handheld
Powered access
Have you tried removing the battery then replacing it?
Jan 17, 2009 | Palm Treo 755p Smartphone
Constent reboot - flashing Access Powered
There is a soft/warm reset which bypassed the loop without losing your data.  press the up key and reinstall your battery.  do not let go until the palm screen fully loads. when fully reloaded let go.  sounds a little confusing but the palm website has step by step instructions.
Sep 24, 2008 | Palm Treo 755p Smartphone
PALM TREO 700P PROBLEM HELP!!!
While holding the power button and re-inserting the battery will prompt you to choose whether or not to erase all data. If you choose "yes" the phone will reset to factory defaults. This should be done as a last resort, but at this point the phone is not functioning at all. Once restored, you can sync it with your pc or laptop and it will import all of your contacts, notes, favorites, and calenders just as it did before. In the future you may want to think about using an SD card for documents or other important information that could be lost in the event you have to reset again.
Good Luck
Jun 30, 2008 | Palm Treo 650 Handheld
Palm Treo 700P In Death Spiral
I just encountered exactly the same issue.
Was using the phone ended the call and was about to place a call when it started the Death Spiral.
All reset options have no effect. Putting the battery in while holding the sync button will produce a color pattern but no functions are available.
I did call Palm USA tech support - apparently they are aware of the issue but have no free solution that they would offer me - for $199 I could send it to them for repair.
Mar 13, 2008 | RIM BlackBerry Pearl 8100
Contacts will not sync
I had this exact same problem did everything U discribe. I even change cables stood in the wind facing north and sacrificed a small animal (hahaha) I called Palm, they said do ahard reset. (haha) reinter 24 day of data manually into the desktop, I dont think so. Then I shut down all the conduits but calender. then I set the conduit to have the handheld over-write the desktop. PROBLEM solved!! No data loss No hard reset No re-entering data. I then folowed up with several test syncs in several conduit configs, including test data in both desktop and handheld. hope this helps.
Sep 05, 2006 | Palm Treo 650 Handheld
Palm Treo 755p Smartphone Logo
113 people viewed this question
Top Palm Computers & Internet Experts
JC Meredith
JC Meredith
gary433
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
