Question about Pinnacle Breakout Box & Drivers for DV500-DVD (210100180)
I have pinnacle with breakout box,but in pinnacle studio12 can't
I have pinnacle with breakout box with software pinnacle studio8
now i want use studio12
why studio12 can't detect my pinnacle the breakout box ?
it can only capture from dv only, i want captere from AV analog
please help me, thank you
  • djpattyd Nov 29, 2008
    I have the same problem with studio 8 breakout box. Also, I have to reinstall the av/dv driver everytime I turn on the computer. If anyone can help it would be greatly appreciated.
    djpattyd
  • cwhatley Feb 01, 2009
    Same problem, worked great for Studio 10 now with 12 it's gone!
There are two kinds of breakoutboxes. Studio 12 does not support version 1. Not sure how you can see the difference between the 2 boxes.
Posted on Dec 11, 2008
Drivers for Pinnacle DV 500 DVD under Windows 7???
This is an outdated product and no longer supported by Pinnacle. Old drivers are still available. Click here and here to view them. Or click here for a complete list of archived products.
Note that the drivers may or may not work with Win 7 and no one other that Pinnacle can provide appropriate drivers. For the software you can try the Compatibility mode.
Oct 04, 2010 | Pinnacle Breakout Box & Drivers for...
Lost manual
take this link
http://www.pinnaclesys.com/PublicSite/us/Support/Consumer+Support/?viewDownload=1
i could not access im behind a firewall couldnt get to it
Mel
Jun 09, 2010 | Pinnacle Studio Ultimate 12 for PC
Use with laptop
Sorry, they have disappeared, and only USB versions are available.
Feb 04, 2010 | Pinnacle Breakout Box & Drivers for...
I have Pinnacle dv500 plus card and want to use it with XP. would u plz send me a link where I can download the driver for win XP?
You can get the drivers for Windows XP here: http://www.pinnaclesys.com/PublicSite/us/Products/Consumer+Products/Advanced+Video/DV500+series/DV500+Series+Support/Download+Area/Drivers+-+Updates?mode=documents
It's the 4.5 version you need for Windows XP - and don't forget to install the PCI Performance enhancer if you don't want the video and audio to be asynchronous.
Greetz,
Mainframe
Apr 16, 2009 | Pinnacle Breakout Box & Drivers for...
Capture video from composite input
you should make sure everything that may cause interference is away from any of those cables, such as cable/dsl modem, wifi router..etc because they cause a large amount of electromagnetic interference
Nov 02, 2008 | Pinnacle DV500 DVD Video Capture Graphic...
DV 500 Plus
I know what card this is now.
When Avid Corp took over Pinnacle a few years ago, this product seem to disappear. In fact they were begging me for awhile to get one. I almost did too.
I wonder if service pack 2 or 3 messed this thing up? I've seen some complaints on here that are similar to what your experiencing.
There are some new analog capture they have out there now that work with digital a lot better than they did a few years ago.
There is something realy proprietary they did to that thing that can make a mess of things..
Aug 16, 2008 | Pinnacle Breakout Box & Drivers for...
2000 Ford Ranger
TEST B: BATTERY VOLTAGE OUT OF RANGE - DTC B1676
1. Check if vehicle has been jump started within past 2 weeks. If vehicle has been jump started, ABS is
okay. If vehicle has not been jump started, go to next step.
2. Using DVOM, measure voltage between positive and negative battery terminals. If voltage is 9-19 volts,
go to next step. If voltage is not 9-19 volts, diagnose charging system. See appropriate GENERATORS
article in STARTING & CHARGING SYSTEMS.
3. Turn ignition off. Disconnect 25-pin ABS control module. Install EEC-IV 60-pin Breakout Box (014-
00322). Turn ignition on. Measure voltage between breakout box terminal No. 20 and ground. If voltage
is more than 10 volts, go to next step. If voltage is less than 10 volts, repair Light Blue/Pink wire between
ABS control module and instrument panel fuse panel.
4. Turn ignition off. Measure voltage between breakout box terminal No. 25 and ground. If voltage is
greater than 10 volts, go to next step. If voltage is less than 10 volts, repair Red wire between ABS
control module and power distribution box/engine compartment fuse box.
5. Measure voltage between breakout box terminal No. 9 and ground. If voltage is greater than 10 volts, go
to next step. If voltage is less than 10 volts, repair Yellow/Light Green wire between ABS control module
6. Measure resistance between breakout box terminal No. 8 and ground. Also, measure resistance between
breakout box terminal No. 24 and ground. If both resistance measurements are less than 5 ohms, replace
ABS control module and repeat self-test. If either resistance measurement is greater than 5 ohms, repair
suspect Black wire between ABS control module and ground distribution.
NOTE: DTC B1676 will set if vehicle has been jump started.
2000 Ford Ranger
2000-01 BRAKES Anti-Lock - 4WAL - Explorer, Ranger & Mountaineer
Jun 11, 2008 | 2000 Ford Ranger SuperCab
Pinnacle DV500 plus
I could send you a copy of my installation CD. Contact me under rangerx@gmx.net.
Jun 08, 2008 | Pinnacle Breakout Box & Drivers for...
Dvd writer
You need to first click on my computer. In the folder section right click on my computer. Left click on properties, then device mangager, then hardware. From the list click on your dvd writer to see if it's working properly or if your computer even reconizes it. It may also be disabled. If it's disabled enable it. You will also need to update the driver or reinstall it. If none of that works, you need a new dvd writer.
May 03, 2008 | Pinnacle Breakout Box & Drivers for...
Pinnacle Breakout Box & Drivers for DV500-DVD (210100180) Logo
611 people viewed this question
Top Pinnacle Televison & Video Experts
David
David
Daniel Dollive
Daniel Dollive
Greg Ulan
Are you a Pinnacle Televison and Video Expert? Answer questions, earn points and help others
