Question about Whirlpool LEW0050P Electric Dryer
Dryer works but no hot air
I have a Whirlpool LEW0050P and it no longer produces hot air. I have replaced the thermostat on the heating element but that didnt work. What should i do next?
  • Anonymous Dec 20, 2008
    no heat
  • dlitchmd May 19, 2009
    Dryer takes one hour for one king sheet. Only gets moderately warm and repair man wants $320 to repair heating element. What part do I purchase to fix this myself?
    Thanks--Susan
Did u get an answer i have the same problem
Posted on Oct 12, 2009
  • 230 Answers
Hello, if it's an electric dryer and you have absolutely no hot air, then it's either the heating element or the thermal cut-off, most likely.
The thermal cut-off is the fuse on the element's housing.
Check both for continuity. Good luck :)
Please feel free to keep emailing me if you'd like.
Posted on Aug 10, 2009
  • Ned Halaweh
    Ned Halaweh Aug 19, 2009
    The problem is either with the heating element or the thermal cut-off on the element housing. You can check both for continuity. Just make sure to remove of the wires from each.
    On rare occations, you might be missing 120v. Check to make sure you have 240v.
    Best of luck.
Troubleshooting heating element on samsung steam dryer
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot or not heat at all. . If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Other Causes and Conditions
Air Flow Problem
Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat
Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Dec 10, 2016 | Samsung Dryers
Whirlpool dryer overhead I change termo fuse all the thermostat but is still overhead is cabrio steamer dryer
DRYER OVERHEATING:
Heating Element
A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem
Cycling Thermostat
Felt Seal
Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel
A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
https://www.youtube.com/watch?v=3m5NZvY9V5Q
GOD IS still GOOD !!!! SO MY ADIVE IS FREE
May 03, 2015 | Whirlpool Dryers
My Whirlpool duet electric dryer seems to get too hot and stops working
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Oct 12, 2014 | Dryers
My whirlpool duet dryer will dry one load of
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Sep 14, 2014 | Dryers
Why does my Whirlpool electric dryer - model SEDS800JQ0, shut off after 2 minutes?
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Aug 09, 2014 | Whirlpool Dryers
Dryer keeps shutting off
DRYER OVERHEATING:
Heating Element
Air Flow Problem
Cycling Thermostat
Felt Seal
Blower Wheel
Feb 18, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Changed out rear bearing and heating coil now something smells like its burning
see this causes and fix it. God bless you
Heating Element A defective heating element can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element to inspect it. The coils should not be touching each other or anything else.
Heating Element Assembly A defective heating element assembly can make a dryer too hot. If the element partially shorts out, it can produce heat all the time, regardless of whether the dryer is calling for heat. Remove the heating element assembly to inspect it. The coils should not be touching each other or anything else.
Air Flow Problem Dryers need good ventilation to work properly. If the vent is clogged it can make the dryer too hot. Clean all of the vent tubing thoroughly.
Cycling Thermostat Although not common, a defective cycling thermostat can make the dryer too hot. The cycling thermostat is supposed to turn on and off the heat to maintain the proper temperature. If the thermostat is defective it may keep the heat on too long. The thermostat is not adjustable or repairable, it must be replaced.
Felt Seal Most dryers have a felt seal at the front and rear of the drum to keep the heat inside the drum. If the felt seal is worn away or missing, the dryer may keep heating and make the dryer too hot. This is not common.
Blower Wheel A defective blower wheel will not spin properly and will not vent the hot air, making the dryer too hot. Check to see if there is adequate airflow out of the dryer.
Oct 02, 2012 | Frigidaire Electric Dryer
My Estate dryer is putting marks on my clothes that almost look like burns. With stain solution I can usually get them out but it's happening with every load now, what could be causing this? It h
Oct 02, 2012 | Estate Dryers
What could be causing inside of the drum of my AD55 F&P dryer to very hot?
Sep 28, 2012 | Fisher and Paykel Dryers
Not blowing hot air anymore
there are two thermostats..one above and one below the heating element..they probably need to be replaced..about 30 bucks canadian..have the shop check your heating element for resistance I had the same problem with my Whirlpool, when I called around for prices one shop suggested the thermostats and then tested my element for conductivity. When it passed he sold me the thermostat replacements(they are sold in pairs) They were very easy to install, just make sure the wires are on correct..Check for small marks beside the leads and then match them up while removing old and installing new. I hope this helps
Jan 18, 2007 | Zanussi TC7102W Electric Dryer
Whirlpool LEW0050P Electric Dryer Logo
382 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Richard Roth
Richard Roth
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
