Question about Frigidaire Refrigerators
Ice maker not working; no water flow
Frigidaire Side By Side Refrigerator Model # GLRT218WDB9. made after 4/2001
Recently I replaced the water filter (5yr. 10,000 gallon bulky) with an Aqua Pure AP717 (1-yr. 1,500 gal.). Sometime afterward, I was told the ice maker wasn't functioning; that water wasn't flowing to it. Fortunately the freezer works. So I went online to determine whether the filter was the improper brand installed.
To check, I filled in the section for the model number and got this: Puresource Water Filter WF1CB as the proper item for this appliance.
I was wondering whether this is the actual problem. Thank You.
catriver
  • 878 Answers
SOURCE: slow water flow
dadcanfix. There are two possibilities here. One could be the water valve itself, clogged or not seating or opening properly. The second would be the water tank on the refrigerator side, partially frozen. I believe they have a kit now with coiled tubing that replaces that tank because of the trouble they had with it. Remove the refer drawers and take a hair dryer and go over the tank lightly. See if that improves the water flow. Catriver..post back.
Posted on Mar 21, 2007
Basti
  • 1447 Answers
SOURCE: leaking pure source 2 ice and water filter
Hi-
Three things
  • Water supply valve may not be completely open.
    Open valve completely.
  • Water supply valve may be blocked by foreign material or may not be large enough.
    Supply valve must have a 1/4" opening for water to fully supply ice maker. Many self-piercing valves do not have this big of an opening. Replace water supply valve with one that has a 1/4" opening.
  • Water filter may need changing.
    If equipped with a water filter, replace filter canister or cartridge.
Hope this help
Thanks for using Fixya!
Posted on Jul 14, 2008
docjohn174
  • 943 Answers
SOURCE: Kenmore Ice Maker Problem, Side by Side Refrigerator
Thanks for the question There is a water valve just for the ice maker so the problem could be there if you have a volt meter you can check the valve what you can do to check the valve reverse the wires onthe valve and push your water dispenser if no water goes into your ice maker . you have a bad valve replace thanks for the question The appliance doc
Posted on Sep 11, 2008
vanni7
  • 163 Answers
SOURCE: water dispenser and ice maker not working
Hi!! tony , yes you have a bad water valve its located on the bottom back of your frig..Replace your water valve..Good luck..
Posted on Jan 03, 2009
heatman101
  • 43501 Answers
SOURCE: refrigerator ice maker stopped working
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
mnnmbnm
Posted on Sep 30, 2010
Frigidaire refrigeratyor ice maker doesn't get watyer
either your filter was put on in the wrong direction or when u replaced there were stuff in the line and it stopped up the hose or your have a crimp in the line
Dec 23, 2015 | Frigidaire FFHS2611LB Side By Side...
I recently replaced my water filter on my Kitchenaid side-by-side refrigerator, model KSCS251, and since then my icemaker no longer makes ice, nor do I hear any water flow into it. The water, however, does...
Try swapping the wires on the dual water inlet valve. It's on the back where the water supply comes in. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips
Jun 16, 2011 | KitchenAid KSCS25FKSS Side by Side...
Refrigerator ice maker stopped working
heatman101
mnnmbnm
Jan 13, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Water dispenser and ice maker not working
Jan 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Ice maker not working - Frigidiare refridgerator Model number FRS26BH6CB4
take the line off of the solinoid valve and check to see if there's a screen in the valve. that could be plugged with debris.
Dec 20, 2008 | Frigidaire FRS26R4A Side by Side...
Ice with Sediments
in the water supply line to but well before the refrigerator fit a ceramic water filter
that has a filter so fine that many germs cannot pass through
Nov 26, 2017 | Frigidaire FSC23F7DSB Stainless Steel Side...
what filter? drying filter? Water filter? Dust Filter?
Jun 24, 2008 | Frigidaire FRS26R4A Side by Side...
Ice Maker Slow Making Ice and Water Dispenser No Longer Dispenses
Try replacing the filters, they might be slowing the water flow.
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Water not flowing into ice maker
yes there is a problem with the water valve or the fill tube that puts water into the ice maker is frozen not letting water into the ice maker
Apr 15, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
52 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
