Question about Sony STR-DE685 Receiver
Trouble getting a picture with a source selector
I recently purchased a psyclone component selector to hook up several gaming systems to my receiver. I have 3 systems hooked up to the selector. It has one output that goes to the receiver. Each of the game systems input to the selector is different. One uses component, one uses composite, one uses a composite with an S video cable. I have all of these outputs going to the reciever from the selector. I have hooked the selector to the receiver under "video 2" and I get sound for all three when each system is selected and video as well with the composite and s video cable system. How can I get the video to work on the others too? Can it only take one type of input at a time? I don't have s video outputs on two of the system so that's not an option for me. I don't have a manual for my receiver so if there is a way to select the type of input i don't know how. Any help will be greatly appreciated. Thanks!
The input on your television monitor must be set to view the composite with the S video cable. You will not be able to view the component video unless you also have component video outputs going from the input selector to the television. After you have done that, you will also have to change your television input from "video 2" to whatever input you used for the component video hookup.
Posted on Dec 30, 2006
SOURCE:
Digital Coaxial not working on DVD player
There might be several problems. As the projector has component only connections and the DVD player none, then if the Receiver has component out, you can hook it up to that. If the receiver has HDMI inputs then you can connect the DVD player via the HDMI socket to it. The Coax sockets on the DVD player will be for sound. Number one should be connected to Digital coax 1 and assigned for it.
It's possible that the sound on the DVD player is switched off on the coax or has the wrong format selected. You will need to see the player's menu for this, so if you can't see the screen using the projector, connect a TV instead.
However if the receiver has no component out and no HDMI sockets you will have real problems connecting the DVD and using the projector with it. Though you should be able to hear the sound via the Denon.
May 28, 2017 | Denon Audio Players & Recorders
I am looking for a users manual for my Psyclone PSC01. Can anyone help me locate one? I have looked for hours and still cannot locate one.
Go to http://www.psyclonegamer.com and choose Source Selector. The PSC01 model is on the top of the selections, click on it and "download manual" icon is at the bottom of the page.
Mar 12, 2011 | Psyclone PSC01 for PlayStation 2
I have a Yamaha 5930 5.1 receiver but it does not have HDMI connections. Is there a way to convert the Video Components to HDMI capability through a switch or adapter?
You can buy video-to-HDMI converters. Here's one through Amazon.com, but there are many other sources. I just picked it as a sample since it was a nice picture. I didn't do much searching, so I don't know how common or expensive a converter with multiple input capability might be. But simpler A/V selector switches are available, so if you have several things you want to connect you can get one to use along with the converter.
Keep in mind that conversion to HDMI won't give you the same quality as the direct HDMI output from a device. So if you have several devices with HDMI outputs, you might be better off buying a new receiver with HDMI inputs instead of dealing with switches and converters. It will ultimately be easier to hook everything up, and you'll have better A/V quality too.
Jan 08, 2011 | Yamaha HTR-5930 Receiver
Has trouble getting input signal
This unit has a defective hdmi board,this is a common problem with this model. The unit is to be taken to a onkyo service center for exchange of the hdmi board under warrenty, if out of warrentyit will cost you several hundards of dollars.
Apr 19, 2010 | Onkyo TX-SR606 Receiver
Video blanks out TX SR605
I had the same thing happen with my SR705. I ended up hooking the video to the tv and leaving the audio to the receiver. Haven't had trouble since
Jul 24, 2008 | Onkyo TX-SR605 Receiver
WD-65100
I do not know if a splitter is available yet for HDMI ,but check to see if the Cable box has an HDMI input and if not then there is no way I know of.
May 14, 2008 | Televison & Video
I am trying to connect my Samsung 56" DLP HDTV to my JVC THD50 home theatre system, all the speakers are hooked up correctly but I can't source from the tv to the speakers correctly, I connected a...
On the rear of the receiver you will notice several AUDIO IN connections. Make sure that the AUDIO IN and the receiver's input selector match (for example, if you are connected to AUDIO IN for the VCR section, the input selector on the FRONT of the receiver should also be VCR). Also, make sure that the input selector you are using is set to "Digital Audio" or a digital audio enabled equivalent and NOT analog. Check all connections again to make sure you have not grounded any speaker wire. Check to see if "MUTE" is on TV or Receiver. Try another audio in source just to make sure the speakers are connected properly. If that works, you can pretty much decide that it's either the input selection is wrong or the audio source is not set to digital 9also check to see if PCM is enabled and try setting to "AUTO" if you have that function. If you have option on receiver for speakers A and B, make sure selection matches your wiring.
Apr 03, 2008 | Audio Players & Recorders
Hook up all my components together
Hi knit, You need a 4 port A/V switch. Ebay has one: http://cgi.ebay.com/4-Port-AV-Audio-Video-S-VIDEO-Selector-Switcher-w-Cable_W0QQitemZ150168531361QQihZ005QQcategoryZ73390QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Oct 05, 2007 | Sony PlayStation 2 (PS2) Console
Sony STR-DE685 Receiver Logo
101 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
