Question about Frigidaire GLER642A Electric Dryer
Dryer won't heat up and the dial is not moving on some cycles
Model:CRGR5700AS0 Serial: XD23601902 dryer tumbles can hear a click when it is suppose to be warming up but don't
Called repair people
Posted on Nov 18, 2008
E15 error code on hoover tumble dryer
  • The control unit on the tumble dryer will vary among different makes and models. The main purpose of the controls is to allow the user to select the drying cycle. You can choose the time and temperature setting on most units, while others allow custom settings such as moisture sensors and end-of-cycle alert signals. The controls may include a dial or a touch panel and LED screen display. Some tumble dryers allow you to independently select the appropriate time for the load you are drying and separate programs for temperature.
  • The motor inside the tumble dryer spins the basket to allow the clothes to tumble while being dried. The tumbling action allows the air to pass through the clothing to dry them faster. Heating laundry that is stagnant will likely dry the clothing on the outside while leaving damp clothing inside the pile. The constant motion, along with the heat and steam created by heating the clothing, reduces wrinkles. The motor also powers the fan that delivers the heated air to the basket of laundry. The heater can be an electrical element or gas powered.
Jan 15, 2013 | Dryers
There is no heat. The cycle dial doesn't move as it tumbles.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
Feb 01, 2011 | Whirlpool Dryers
Dryer making clicking noise when running. Heat no longer working. Gets "stuck" in a cycle continues running and dial not moving.
Based on symptoms, this is a gas dryer. The clicking that you hear is the solenoid opening so that gas can flow and be lit. Except that gas isn't flowing, or the igniter is burned out (if or pilot is blown out if so equipped).
It is normal for the dial not to move unless it is in a timed dry mode (like air or freshen mode) because the moisture level of the clothes is not changing.
Jun 13, 2010 | Kenmore 63942 Dryer
My white knight tumble dryer does not heat up,tried pressing the reset button but still does not heat up
you have a heating element burnt out. You will need to remove the back of the dryer and in the bottom of the dryer casing you will see the element Looks like a toaster element. Take model and serial # to an appliance parts house for replacement. An appliance tech shouldn't charge you that much to repair if you dont want to do it yourself.
Good luck hope this helped you some
Jan 28, 2010 | Dryers
Dryer won't heat--element replaced; tumbles fine
Before you purchase any more parts, you should have use of a multi meter. If the dryer is not heating at all, and of the following parts could be bad.......Operating (cycling) thermostat, high limit thermostat, thermal fuse, timer, or motor centrifugal switch. All but the motor switch can be easily checked with the dryer UNPLUGGED using the ohms feature of the meter.
May 03, 2009 | Dryers
Dryer flame on magtag wont stay lit. Pilot flares up but no flame
Thermocouple is probably bad. The pilot burns and heats a sensor which tells the CPU that the Flame can start, and the thermocouple heating up changes voltage with increase temperature and tells the CPU that the Flame is burning OK. If it is defective, there is no voltage change and the CPU assumes that the Flame didn't start for some reason, (Gas only!) and turns if off for safety. Over and over xx times.
My .02
Good Luck!
Mar 26, 2009 | Dryers
Roper Gas Dryer not heating.
Is the fuse on the picture is the one you bypassed:
The thermal fuse
- The wiring diagram which may help you.Here is information about prices n more elements that you may need. "Did I answer your question ?
Did it solve your problem?"
Jan 19, 2009 | Roper RGX4634KQ Gas Dryer
there is an overheat resettable stat on the back under a small red cover. try for a start pressing the centre of the red cover and you should hear a click and dryer will then heat. this is the most common fault - get back to me if somethinbg different
Sep 05, 2008 | Dryers
Beko tumble dryer not drying. drum goes round but it doesn't get hot. Model DRCS68
go into service mode and reset
to do this move to delicates turn on dryer and keep
pressed down cancel button for about ten seconds release
then all lights should flash when you press cancel again machine will go through test mode , then just turn machine off
it is now reset, this worked for min a drcs68w
Apr 23, 2008 | Dryers
Frigidaire GLER642A Electric Dryer Logo
64 people viewed this question
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
