Question about Amana AER5515QA Electric Kitchen Range
Bottom element on range doesn't work
Recently, we had a problem with our 4 year old Amana electric coil range. Without an explanation, the digital clock suddenly disappeared, the temperature setting canged to celsius and the range would not bake correctly afterwards. Although we had luck in turning the on board clock back on and changing the temperature setting from celsius back to Fahrenheit like it was in the beginning, we could not get the bottom heating element in the range to work at all. We replaced the bottom element in the stove assuming it had gone out, but this did not solve the problem. Now we are stuck with two good heating elements (have checked both with a multimeter,) we can't afford a service call and are at a loss as to what to do.
    President:
  • Amana Master
  • 2,651 Answers
We can check a few things, first off you need to confirm 220v. to unit itself, ill assume you do, the top elements are working correctly.. sounds like a bad electronic control, what youll need to check is on the control itself, there is a wire labeled L1, then there will be a bake terminal, ill also assume L1 has 110v, other\wise the clock wouldnt be liting up, but if you carefully unplug the bake terminal and test terminal for power( it will have 110v, after you select bake andstart oven.
Posted on Nov 18, 2008
We have Amana electric stove AER5735QAS that will not heat beyond approx 180-200 degrees when the stove setting on heat is set to 350. The stove is approx 4 years old. Impression is the problem may be...
If the heating element cycles off and on, it's probably not the problem but a thermostat or high limit. The thermostat should have a sensor wire, a part for sensing temperature and should not be placed or located anywhere near the heating element.
Oct 29, 2017 | Amana AER5735QAS Electric Kitchen Range
My oven is two years old and the bottom oven coil will not heat up. The top one works just fine but not the bottom.
you may have a burned out bake element even if the range is only a couple of years old. if you can see the element look for a burned area. if you can't see it you will need to unplug the range and see how to get it out yourself or call a repair service. hope this helps.
Oct 13, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Hello. Regarding my Amana range (MODEL: AGDS902),
You will have to replace the bottom element.
John
Oct 03, 2009 | Amana AGDS902 Gas Kitchen Range
Bottom element not working tried a new element still not working
I THOUGHT THE INFORMATION WAS TOO STEEP I WILL WORK IT OUT MYSELF
Jun 21, 2009 | Amana AER5515QA Electric Kitchen Range
Bottom heating coil not working in my amana oven.
Most likely the temperature sensor is bad. This is a small pencil shaped rod in the top of the oven.
Well, to ensure the temp sensor isn't bad, you can take an ohm meter to the contacts of it and measure the resistance. It should be around 20 ohms. If it is much greater or infinite, then its bad. To get to the contacts you will need to unplug the oven, pull it away from the wall and remove the rear panel. Then disconnect the wiring and touch the probes from the meter to the contacts on the sensor. You can order a new sensor locally or from repairclinic.com. Let me know what you find.
Benjamin
Mar 23, 2009 | Amana ACF4215 Electric Kitchen Range
Bottom element on range doesn't work although its been replaced
You have to replace the clock. That will definately fix your problem.
Nov 17, 2008 | Amana AER5515QA Electric Kitchen Range
Amana Range, Electric wont bake or broil
the fact that the time keeps flashing is odd, an you set the clock?? and if so does it return to blinking again???sme stoves wont allow proper operation of oven without the clock being set.
Mar 23, 2008 | Kitchen Ranges
Amana Electric Dryer runs but does not heat up - model ndw2330ayw -
I HAVE AN AMANA DRYER MODEL LE8217W2 ITWILL COME ON FOR A SHORT TIME AND THEN CUT OFF. I CHANGE THE BELT, THE MOTOR AND THE THERMOSTAT. THE DRYER STAYS ON , BUT WILL NOT HEAT UP. WHAT'S NEXT ???? PLEASE HELP!
Nov 05, 2007 | Amana NDE2330AY Electric Dryer
Oven will not heat past 220 degrees
Check your bake element, I had the exact same problem and found the bake element had burned in half. The broil element comes on during preheat and kicks off at around 220 degrees.
May 06, 2007 | Amana AER5515QA Electric Kitchen Range
Amana AER5515QA Electric Kitchen Range Logo
246 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
