Question about LG 32LB4D 32 in. LCD HDTV
HDMI problem (32LB9D)
I have a 32 in LG with a Dish Network HD box via HDMI connection. The TV has worked great for the past year or so. Just recently the sound has been intermittent, but only after the TV has been on for several minutes. This intermittent sound eventually leads to no sound at all. I've switched out both the Dish Network box and the HDMI cable, separately...same result. I've also tried all three HDMI inputs on the TV...same result. Currently, I have an S-video and component audio out and it seems to be working fine. I'm assuming there is a problem either with my TV or the communication between the box and the TV when connected with an HDMI. Any opinions or suggestions would be greatly appreciated. Thanks.
SOURCE: no sound through ps3 hdmi
on ps3 go to settings sound and change sound out put to hdmi you will see 3 different options
Posted on Nov 07, 2008
shbuckler
  • 126 Answers
SOURCE: DVI-->HDMI cable causes tv speakers to hiss and pop
DVi to HDMI. ? hmmmmm
I recon you spend £49.99 and get a DVI & Audio to HDMI Converter. This will resolve the issue
Posted on Dec 25, 2008
  • 54 Answers
SOURCE: 42LG50 HDMI error message
pull the plug on your tv and cable box for 1 minute and start fresh. glitches like this happen all the time with hdmi. if this does not cure, the error message you get needs to be posted.
Posted on Feb 28, 2009
  • 7 Answers
SOURCE: LG 42PX4DV - HDMI Audio / PC Audio IN problem
one quick fix you can try. plug in the HDMI cable, slect a digital audio sound output from the sound settings on your machine, then leave it connected and restart it. It just might work.
Posted on Aug 05, 2009
  • 50 Answers
SOURCE: "No signal" sign on TV screen using HDMI selector
it sounds like a refresh issue, double check you selector and make sure it fits the refresh of the tv. i had this once with a sharp where the tv was 120hz and the selector was 60 and it created a no signal and when it did come in it was jumpy. if you have a 120 tv then selector should be the same.
Posted on Apr 27, 2010
3D tv issues with HD channels on Dish Network
check screen resolution of your lcd tv & receiver too
Aug 24, 2012 | Dynex DX-L42-10A 42 in. LCD TV
How do I connect my LG TV to my dish network
Hello Al, my name is Cheri Torres and I work with DISH Network Internet Response Team. I came across your post and wanted to see if I could help. Connecting your LG TV to your DISH Network receiver should be fairly easy, depending on the connections you are using. If you are using an HDMI cable you will need to connect one side of it to your LG TV and the other end into your DISH receiver, as long as you have an HD receiver. If you do not have an HD receiver you are probably going to want to use composite cables(red, white and yellow). If you are using either of these cables you are going to have to set your TV to an input in order to receive the DISH picture. You can select an input by finding a button on the TV remote or the TV itself that is listed as input, source, AUX, mode or video. You will need to cycle through each one until you find the DISH picture on one of them. Once you have the picture you will need to press SAT on your DISH remote and everything should be working fine from there. I hope this information is useful and if you have further questions feel free to ask!
Dec 31, 2011 | LG 42PG20 42 in. Plasma HDTV
How do I program the Dynex DX-32L151A11 to work with a Dish Network control box--and how do we improve from the 480 pixel image? Lastly, no matter what I do the sound is a muffeled sound regardless of...
You will need to get a HD receiver box. Your tv supports upto 720P so a HD box that is set to 720P should work just fine. You should connect it via HDMI . As for your second question does the audio be like that even when you are using other input source such as a DVD player?
May 17, 2011 | Dynex DX-L32-10A 32" LCD HDTV
Today, while watching tv on the Dish, tv suddenly started powercycling. I unplugged it, waited, and then tried a DVD -- worked fine. Tried Dish again, power cycled again -- on off on off, 1/2 second of...
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities.
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | LG 47LD520 47 in. HD-Ready LCD TV
What kind of HDMI cord do I need to purchase for this TV, I am running DISH Network also. Thanks!
There is only one type of HDMI cable, so any HDMI cable should be fine. Component cables are an alternative to HDMI cables, but keep in mind that component cables do not carry audio, so you will need to have the audio connected separately. Our HD receivers work great with HDMI or component cables.
Phillip Chang
DISH Network Customer Service Representative
Feb 08, 2011 | Sanyo 42 in. LCD TV
How do you connect the Virgin VHD box to LG RZ32LZ55 TV for getting HD and also the audio. For the audio the V HD box has a optical audio port and a test port ( i am not sure it works!). The TV has a DVI...
All you need is an hdmi-dvi adapter. You will also need a component audio lead to plug into the mini(3.5) jack socket on the tv as dvi does not carry sound. You will need to initially use the scart to set up your tv for hdmi as the menu can only be seen via the scart until you set it up.
Jul 24, 2010 | LG RZ32LZ55 32 in. HD-Ready LCD Television
HD not working.
Have you connected it Via HDMI? if the screen is still connected via Scart then that is the problem.
May 03, 2010 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
PLEASE HELP ME CONNECT MY DVD PLAYER TO MY NEW PROSCAN 32LB30Q.
Use either another HDMI cable (available at your local electronics store) or a component video and left/right audio cable to connect the two pieces together. The connections on the back panel of both pieces should be color coded and clearly marked.
Apr 10, 2009 | Televison & Video
Connecting an a/v receiver to a Dish network receiver
DO you have manuals for all the units listed?
If not , try the Samsung consumer site.
It would take me quite a while to figure out your situation even with manuals and I have a business to run besides.
Also, ask some questions of Tech Support at Samsung..Let them KNOW how much you spent on their stuff.
God bless,
SF
Jul 07, 2008 | Televison & Video
HD READY
I have the same TV & I've tried connecting it through "component" & the DVI but neither work & a Virgin media tech says only an HD TV will work 'the boxdoesn't recognise component
Steve
May 05, 2008 | LG RZ32LZ50 32 in. LCD Television
LG 32LB4D 32 in. LCD HDTV Logo
62 people viewed this question
