Question about Dell PART NUMBER KIT SPEAKER MM ACS45 ALTEC EUR 45502 Computer Speakers
Can't increase & decrease the volume
I have this altec lancing model acs45.1, the problem is i can't increase and decrease the volume of the speaker, but i can still heard the music.. can you help me please
  • 3 more comments
  • Helplessblde Feb 13, 2008
    I tried to follow the steps that was listed as the solution. Truth, I didn't understand them. I have the ACS45.2 speaker system and don't know what to do.
    Wanted to expand on the problem. There are two volume buttons (up & down) and a power light on top of the main speaker. When you push both together, the power should turn on and off and when on you should be able to adjust the volume. The power button is on continuously (won't turn off) and the volume will not adjust. There is also a subwoofer, although that has it's own volume and seems to work. ANY help would be greatly appreciated.
  • Wompwomp Apr 15, 2008
    I have a similar problem with the Altec Lansing acs45.1. The down button to decrease the volume no longer functions, only the button to increase the volume. And I can't power the unit down since both buttons need to be pressed simultaneously to accomplish this. I opened up the speaker and everything looks ok. I've read on another forum that it might be the Electronic Volume Controller IC (PT2256) but I don't know how to check if mine is good and I haven't found a source for one anyway.
  • Ekong Nalla Jun 01, 2013
    the problem is in the board your volume control is defective. Just replace volume control IC PT2256 and it will be ok.
    the problem is on the circuit board your volume control is defective. Just replace PT2256 your volume control IC and it works fine.
    Problem Solver:
  • 9 Answers
Double check your connections. Still not working fine. Remove the input jack connector and try to touch or hold the tip of the connector, also adjust the volume of the speaker, you should heard loudly the 60 hertz sound of your body signal. Otherwise you have a defective amplifier in the speaker system.
Posted on Aug 25, 2007
SOURCE:
Hello ! I have a Sony DAV-DZ640K Home Theater System, the problem is that I can increase and decrease sound levels for individual speakers, like i am able to increase and decrease surround (back) speakers...
Sound distribution varies according to speaker configuration. You have to select speaker size and placement and a number of other characteristics to get results. A review of the setup instructions in accordance with the physical size of the speakers you are using and nominal impedance values may help.
Feb 26, 2014 | Sony Audio Players & Recorders
I am using creative speakers with woofer i get disturbance in audio when increasing and decreasing volume
spray your volume control with a dirt/rust cleaning cannister if you cant access it, open your spk system then spray it directly with straw stick into the cannister so that it can be easily sprayed into that volume control, hope this can help.. thanks for asking, good day..
Nov 14, 2013 | Altec Lansing Audio Players & Recorders
How to increase brightness without fn+f6 keys because for now the f6 key is not working
Press and hold the "Fn," or function, key on your EEE PC-1000's keyboard.
Press "F3" while holding "Fn" to lower the brightness on your monitor.
The brightness on your computer decreases each time "F3" is pressed.
Press "F4" while holding "Fn" to increase the brightness on your monitor.
Each time "F4" is pressed, the brightness increases.
Press "F8" while holding "Fn" to decrease the volume from your EEE PC's speakers.
Each time "F8" is pressed, the volume decreases.
Press "F9" while holding "Fn" to increase the volume from your EEE PC's speakers.
Each time "F9" is pressed, the volume increases.
Press the "Ins" key while holding "Fn" to take a screen shot, or make a copy of what is currently on the computer screen.
hope this helps
Oct 08, 2012 | ASUS EeePC1000 1000H 1000HA 1000HC 1000HD...
How do I increase the volume on my Nokia 1661?
There are 2 types of volume in your nokia phone that you can increase or decrease.
The first one is the ring tone volume. You can either increase or decrease your ring tone volume by pressing the menu key then go to settings, go to profile, select any desired profile go to personalise go to ringing volume, then increase or decrease by using the navigation button to the right or left.
The second way is to increase or decrease the volume of the speaker of your phone which i think is the cause of your question (this volume enables you to hear clear and loud the person on the other phone). You increase or decrease the volume by making a call, as soon as the call starts ringing, press the navigation key to right to increase the volume or to the left to decrease the volume.
Jan 19, 2010 | Nokia 1661 Cell Phone
I am having a problem with my Altec Lancing speakers not playing. The sound comes from the speakers on my lap top, the headphones work and the sound card is fine.
Of course make sure they are pluged into the right spot, they are powered on...sometimes the volume control is all the way off.
Jan 08, 2010 | Computers & Internet
Disturbance in audio when i increase d volume
do you have wireless?, this could be affecting your sound, also check your hardware compatability and make sure everything is good 2 go.
Oct 03, 2008 | Altec Lansing Audio Players & Recorders
Altec lancing 221 pc speakers are not working.
right click in speakers icon and open volume control----check volume control fader in up position-------check that nothing in mute setting and remove mute where ever you find it.-------confirm that you plug speaker jack in right place(line out).-check your sound driver and confirm it is ok.
Aug 06, 2008 | Audio Players & Recorders
No sound
see if u can get master speaker wiith cables on it that died on ebay best bet what kinda are these
Jan 05, 2008 | Altec Lansing ACS 45.1 Computer Speakers
578 people viewed this question
Top Dell Audio Players & Recorders Experts
Steve Allison
Steve Allison
ptpumpman
Marvin
Marvin
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
