Question about Dishwashers
F & p nemo dishwasher just beeps
My Fisher and Paylel dishwasher now won't turn off, it just sits and beeps. None of the pause or other buttons work. i have disconnected it from the well hoping for a reset but no change. Cheers
Mike
  • 351 Answers
SOURCE: Problems with Fisher & Paykel Nemo model DW681.
is there somthing stuck in the wash motor,can you hear a humming noise ? if yes remove motor and see if you can turn it by hand.hopr this helps.
Posted on Mar 14, 2008
  • 351 Answers
SOURCE: fisher & paykel Nautilus dishwasher
pull the dishwasher out and push down on the top of the dishwasher were the door latch is ,its not making conntact with the microswitch.but you could also have a broken handle.these are both common faults on this model.hope this helps.
Posted on Mar 20, 2008
  • 50 Answers
SOURCE: Whirlpool Dishwasher Not Working
Change the thermal fuse in the control and door switches. The thermal fuse is designed to fail if there is a problem with the switches.
Posted on Feb 26, 2009
SOURCE: Fisher & Paykel Nemo Dishwasher
try ensuring that the container is completely dry before putting in powder
Posted on May 18, 2009
SOURCE: fisher n paykel nemo dishwasher won't go. Sounds
Check to see that the outlet pump (underneath) isn,t stuck eg sumething stopping the pump from turning.Also check that the outlet is clear where it connects to the sink outlet.Hope this helps.
Posted on Dec 13, 2009
Fisher paykel dishdrawer
The controller is detecting some abnormal condition. Clean the interior of the dishwasher with warm water and clean cloth. Remove the base drain plate etc., before cleaning and clean the plate separately. Put back and try again. If no difference, then buy Finish dishwasher cleaning kit and run the dishwasher on one of the hot cycles. (You will have to keep pushing the pause button ). See if it clears everything. If not then call the technician as the controller may need replacement.
Nov 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher & Paykell Nemo model 820 won't start
It sounds like the interlock switch on the unit isn't working, it is a switch than closes when you lock the unit to start the wash cycle. there may be something interfering with it. look to make sure you have a good seal when you lock the unit if not then something is blocking it from sealing properly this will make the buttons give a beeping sound and not work. Hoe this helps.
Nov 18, 2013 | Dishwashers
Fisher n paykel nemo dishwasher won't go. Sounds
Dec 13, 2009 | Fisher Dishwashers
I keep getting a beep and believe it is a Fault Code
try turnning the unit of at the plug the the controll panel holde the program botton in and trun unit on try this on both draws
Jul 23, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishwasher problem
i had the same problem with a fisher paykel nemo dishwasher beeping at end of cycle, as im a mechanic i was curious to pull it apart and see how it works, i pulled the main control board out and unscrewed the three screws holding it all together and inspected the circuit board, and what did i see, a dry solder on the blue relay box or something, resoldered it, reassembled it and now works a treat, hope that helps
Feb 01, 2009 | Dishwashers
Fisher and paykel DD605SS
hold all three bottons: power, pause and start and power cycle the unit, it will reset the dish washer.
Nov 22, 2008 | Fisher and Paykel DD605SS Stainless Steel...
Fisher and Paykel 23 Top washer isn't coming on
is the lock symbol showing in the lcd badge when it's not back lit can be hard to see ,if it,s showing push lock button till it beeps release immediatly now try power button or start/pause button
Jun 05, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Dishwashers Logo
285 people viewed this question
Top Dishwashers Experts
