Question about BenQ PB6110 Multimedia Projector
PB6110 Powers down after 30s, splash screen appears, red temp lig
PB6110 starts booting, (fan goes on flashing power light) then splash screen appears, (lamp has only 184 hours) and then displays input (I'm running a DVD) player, then the red tempurature light goes (while the lamp remains green) and then the whole thing shuts doewn (power led is yellow) fan shuts off.
What gives? Is it a faulty temperature sensor... BENQ was less than helpful..
  • bqidmm Mar 02, 2009
    same problem here. No filters to clean. I opened the projector and tested the thermal cutout which seems ok - tested the resistance while increasing the temperature.
    Is there a combination of buttons to press to reset the temp warning?
Be sure to check the filters and make sure you have good airflow thru the proj. Cleaning filters solved our temp shutdown problem.
Posted on Nov 18, 2008
Wont Boot 1st PSU Flashing Amber
standard troubleshooting:
1) I've seen power sources appear to power up a system, but are somehow broken just enough to not get the system to POST (do you have another system you could at least borrow the power source from?)
2) pull anything you can so that you just have mobo, power, cpu, memory, and graphics.
2a) try using just one memory chip (and try each chip you have, or best to borrow a chip from a working system); even try different slots
2b) if onboard graphics, try a known working graphics card addon
2c) does the screen power off (like normal sleep) or system shutdown? if latter, try re-thermal pasting the heat sink to the cpu.
I’m happy to assist further over the phone at https://www.6ya.com/expert/shunter_ccf54e0913bd0501
May 22, 2016 | Fujitsu Siemens Siemens PRIMERGY RX300...
Blinking green light
It is likely that the power supply is failing. It tries to start and powers up briefly then shuts down.
Oct 28, 2013 | Sony Grand WEGA KDF-60XS955 60" Rear...
Toshiba L455
If this were a backlight problem, you probably wouldn't be able to see the Toshiba Splash Screen.
Do you see a little dash at the top of the screen? It sounds like your hard drive has lost its MBR (master boot record) or completely failed. The MBR tells the system where to find the operating system on the drive. Try finding a Windows OS install or upgrade disc or your Recovery disc. (For a Windows CD, you'll want to match your current OS.) Alternatively, find a LiveCD of a drive partitioning program (with a repair MBR feature). I've used the True Image and Paragon Partition Manager.
Try to boot from the optical drive. (You may need to access the BIOS to change the boot disc; press F2 after powering up the computer. If you get to the blank screen, then shut down and retry. It takes me several attempts to get into the BIOS.) If you can get the boot CD to work, try to repair the computer. Let me know if you need the details. It will depend on if you are using Windows media or a Partition repair Live CD.
You can also try to restore from your backup. (I hope you back up regularly.)
I hope this helps.
Jun 29, 2013 | Computers & Internet
62hmx95, blinking light, powers on then off
Examine in order the lamp, the ballast, the fans.
Apr 29, 2012 | Toshiba 62HMX95 62" HDTV
Sanyo pcl-xu50 flashing red power light when i turn on my projector the light goes green it powers up for about 20 seconds then the power light changes to a red flashing one for about 10 seconds then back...
Projectors shut off when they overheat. They overheat when air does not move through the projector cooling it. This happens when the fans are not working or air filters/vents are not working.
Check to see whether the fans are working. If they are working, open the cover and see whether air filters/vents are covered with dust. If so clean them.
Sep 26, 2011 | Office Equipment & Supplies
My Toshiba Tecra M5 won't boot. The power light flashes on and off, the fan starts but nothing is on the screen. How can I get it to boot?
Well, it sounds like you have a hardware problem. Start by removing the Ram and hard Drive from the machine and insert a boot disk. If your not getting the Tecra Splash screen when you press the power button, the screen that appears before the windows boot screen, you may have a bad Monitor or Burned background lamp or faulty BIOS install or upgrade. Any of which will give you this problem.
Dec 26, 2010 | Toshiba Tecra M5-S4332 Notebook Pc
Unit turns on for 20-30 seconds then powers off.....Please Help
it is the ballast issue,u can try one of the equivalent ones or just try & rework on the old one, perhaps one of the mosfets is leaky!!!!!!!!
Feb 06, 2009 | HP Digital Projector Vp6110 Multimedia...
Sony Vaio laptop vgn-fs640-w problems
The motherboard controls the fan speed - and laptops often turn it off entirely when it is not needed. This sounds like a motherboard issue where an internal trace is broken and sometimes it makes contact, other times not. There's probably nothing you can do except replace the motherboard.
Jan 18, 2009 | Computers & Internet
Hd 61Z786
u need a new light bulb they are about 200
Dec 02, 2008 | JVC HD-61Z786 61" Rear Projection HDTV
PROJECTOR POWERS DOWN
This would appear to be a bulb that has reached end of life -- or the projector thinks that it is because of hours. Usually most bulbs are 1000 or 2000 hours. Depending on your projector there are different ways of checking bulb life hours -- if you Google your projector model number and "bulb life" you will usually get a post on how to check these hours. Also, if it is a new bulb and you haven't reset the hours counter, it may need to be reset (however you also don't want to wait too long before changing a bulb that has reached EOL since they can and do explode sometimes taking out the projector with it).
Jan 18, 2008 | Sanyo PLC XU50 Multimedia Projector
BenQ PB6110 Multimedia Projector Logo
1,081 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
