Question about Bosch Audio Players & Recorders
No power hab to fix the power button and one of the speakers didnt work so took it apart and fixed power button and found that the little capicator or what ever it is was bad had no power to the speaker so I just soldered it directerly to the speaker minus the cap.or what ever it is . The problem is nothing works now at all no display no radio etc tested the recepticle and it tested as something wrong with the gounnd any one know where to go from here and how to fix this problem. I hooked everything up like I took it apart I think any help would be great. Thanks Rick
PC-mCoy
  • 5 Answers
SOURCE: Logitech Z340 Power speaker problem
yeah you can fix that one into your own. first thing that you do is get a multi-tester and put the two terminal the red one and the black into the tip of male plug of you wire. then set your multi tester into the ohms selector any ohm selector which found at the right side of the multi-tester. if the arm of multi-tester was moving it means OK... if not open the speaker carefully and reconnect the wire by using soldering iron & lead.
Posted on Nov 06, 2007
SOURCE: The bass speaker doesnt work
OK, Bose owners out there listen up and listen good. Here's the real scoop on 1.(getting access to the inside of most bose subwoofers, 2.( repairing said subwoofer.
Follow these steps in removing the cover of your subwoofer. Unscrew the two screws from the cover. (They are on the input/output side of the cover) Remove the two knobs (Bass and treble volume).
On the opposite side of the cover, (put those damn shoes back in the closet) there is a lockout tab that needs to be swung out, it moves 90 degrees in a counter-clockwise direction and is located under the center of the cover.
A small flat blade screwdriver works great for swinging this tab out and will be necessary for the next step (the screwdriver that is).
On the same side (opposite the input/output side) there are two small tabs near the edges of the cover, one on the right and it's counterpart on the left. If you look closely in the gap between the cover and the sub itself, you will see these 3/8" wide tabs near the edges and towards the top of the cover.
With the flat blade screwdriver, put the blade between the cover and on the tab and pull down. Then with your hand balled into a fist, gently hit that side of the cover towards the input/output side. the cover will move only slightly but the tab should remain depressed.
Do the same procedure on the opposite side of the cover and it will slide about a 1/2 to 3/4" towards the input/output side and can then be removed by pulling it straight up and off of the cabinet.
Yay! If you get this far without incident then you are ready to implement repairs. In the case of the AM15's, normally what happens is a resistor will open up and prevent the triac (turn-on device) from firing.
The fuse is on the underside of the PC board and this above mentioned resistor is a 100 ohm, surface mount "chip" resistor on the top side of the PC board. It will not appear to be bad but trust me, if the fuse is good and the sub will not turn on... replace it!
You don't have to use a chip resistor since as a consumer you may have a rough time finding one but a 1/8 watt or 1/4 watt resistor you can find at any Radio Shack will work just dandy in this application.
Cut the leads short and solder the two cut leads to the pads on the circuit board where the chip resistor is currently sitting. The chip resistor will be black, about 1/4" long, 1/8" wide and have "101" printed on it's surface. On some models they used two 200 ohm resistors in parallel but the result is the same. One 1/4w axial lead resistor will do just fine. Plug it up and give it a try. (Before you replace the cover).
Secondly, if the fuse is blown on a "Lifestyle" Bose subwoofer, contrary to popular belief, it blew for a reason. The speaker outputs and the subwoofer output devices are TDA7294 IC's with TIP142 and TIP147 Motorola transistors used as current supplements to these said output devices. If the fuse is blown and replacing it only results in another blown fuse then chances are good that one or more of these are blown. In some cases it's very easy to tell, the front of these IC's will be blown off and/or you will see burn marks on the board where they are mounted. These devices are located inside the amp portion of the subwoofer. (The black metal heatsink underneath the input/preamp PCB. As a consumer, if the fuse is blown, unless you are familiar with soldering techniques and troubleshooting electronics, leave this to the pro's. It isn't as easy as you might think and you can destroy the PCB in your attempts to repair it.
 This was from a Guru of Bose systems at ecoustics.com: Mark Burgess
Posted on May 11, 2008
r_ic7
  • 13 Answers
SOURCE: Fried Woofer
The problem are worsen that before. It is wisely to replace both left and right amplifier
IC, but make ensure that the power supply feed a good amount of voltage to amplifier,
Also a strong good signal. Be sure to measure it.
r_ic7
Posted on Nov 29, 2008
SOURCE: Creative Inspire T6100 5.1 - No Power
are you sure if you plugged into the right spot
Posted on Dec 14, 2008
  • 3 Answers
SOURCE: denon avr-2500 left main speakers very quiet.
The Denon 2500 was one of the best ProLogic receivers built, it was a work horse and very little ever went wrong with them.
To make sure you're only supposed to hear right & left speakers, press the Stereo button on the remote. Also recheck your speaker connections - this is the single most overlooked connection problem folks have.
Check the balance control to make sure it's in the center position
Make sure the Tape Monitor is not engaged.
Then, check to make sure that the Pre-Out, Main-In jumpers are connected properly on the rear panel.
If that is not the problem, try pressing the Tone Direct button on the remote (aka Tone Defeat on the front panel).
Posted on Oct 22, 2009
How to fix if capacitor went bad-no sound from speaker?
You can unsolder the cap from the working speaker and test for that and swap it out to see if it fixes the problem.
May 05, 2015 | Bose 161 Rear Speaker
HP dv6704nr power button doesn't work but quickplay/dvd start laptop, completely turns off if screen is beyond the cut off point no matter if it is in POST or in windows, and speaker doesn't w
i would take the button bar of and check to see if the cable is off to one side its a flat ribbon cable sounds like it is a little sideways that will make that happen there is a little clip be gentle undo it a little bit and straighten it out
Feb 25, 2013 | HP Pavilion dv6704nr Notebook
CA-MXGT700 JVC stereo no longer gets power?
Check the "tiny little glass fuse". It may have popped
Nov 01, 2012 | JVC Audio Players & Recorders
Okay, I took apart my 2003 VW Jetta's AC/Heater control unit without the aid of a diagram. I found the bulb and replaced it but I also took out the AC and Recirculate buttons and now they don't work. Did...
first off make sure u didnt blow any fuses if the ac fuse is blown it wont allow these buttons to opperate and if not you need to make sure its plugged in all the way sometimes the plugs get loose and will not make contact good ...if these dont work u will need a new controller they run from about $119 to $200 from dealer ..
Jan 24, 2011 | 2000 Volkswagen Beetle
Creative Zen V Plus won't turn on, computer won't recognize.
hi there, what i did was push and hold the reset button for about 30 seconds and then vuala, it reset and still had all of my stuff on it. to the guy who the reset button didnt work you might want to try two or three times, otherwise i dont know what else there is to do but get a new one. well i hope this works for you guys.
Dec 01, 2008 | Creative Labs ZEN V Plus MP3 Player
YST SW005 Subwoofer
Just buy a new one, and it didnt cost me a premium plan to find out. I thought you guys were here to help and not take someones money and then say theres nothing you can do. I am movin on boys. It doesnt take an expert to figure this one out. I just thought you guys would have maybe a better idea. Buh bye.
Aug 12, 2008 | Yamaha YST-SW005 Subwoofer
Same problem took mine apart and caps are buldged out where did you find you capicators
Radio Shack, Just act really smart and a little strange, and ask where they keep the capicators.
Jun 24, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Won't turn on at all
Hello, I just fixed a friend of mine's mp-c7085. Same situation. Kid just got it for christmas, dropped it and it stopped working. I took it apart and found that the on switch broke it's soider connection to the board. I carefully resoidered the switch and it works. You can tell for sure if you take it apart and squeeze the on switch to the board while you try turning it on.
Feb 01, 2008 | Coby MP-C7085 MP3 Player
Nov 04, 2007 | Logitech Z-340 Computer Speakers
60 people viewed this question
Top Bosch Audio Players & Recorders Experts
Lawrence Oravetz
Nicola Conroy
Are you a Bosch Audio Player and Recorder Expert? Answer questions, earn points and help others
