Question about Dell Dimension 2400 PC Desktop
I can not get my cd drive to work.!
I am having problems getting my cd drive to work when trying to download items from a cd or to install prombems also from a cd. When installing the program, the disc works up to the point whee the installation wizard appears.
    Sergeant:
    Champion:
  • 275 Answers
All you need to do is go to the device manager
uninstall the cd/dvd drive
uninstall the ide secondary as well as primary channel and make sure you unistall the secondary channel first coz normally the primary channel is ur harddrive and if u uninstall the primary first the system will hang you will have to shut the system down forcefully
than restart the system and the system will detect everything again and issue should be resolved
if no than go to the support.dell.com ... click on drivers and downloads....select the option enter ur tag... thats the service tag which is located on the back of the system its a seven digit alpha numeric code located on the white lable with barcodes ...and than select ur os by default the operating system which will be selected would be the one you got with the system... click on cd/dvd ...download the firmware which is applicable ...
you will find the model of the drive in the device manager in the cd/dvd option and after downloading it install it and than restart the system and this should resolved it ...
if that doesnt help it means the lens of the drive are weak u will have to get a new one
so if the system is under warrantty get a replacement from dell
technical number is 18006249896
Posted on Nov 19, 2008
    New Friend:
  • 53 Answers
Thanks for your question but have you tried to go through control panel then hardware and update your hardware for the cdrom drivers this should solve your problem
scincerly: passwords122
Posted on Nov 18, 2008
I had a problem with my computer, I had it fixed, i like the old microsoft office that I had. I have a CD but my cd-rom doesn't work. Where can I download a microsoft office home and student 2007...
http://www.digitalriver.com/v2.0-img/operations/microsoft/531540_reallife/pd/pd-has-en-US.html?theme=rlt
Download and install the trial then activate it with your key.
Aug 05, 2011 | Microsoft Office Home and Student 2007...
How do i instal my web cam?
hi dee, its simple when you buy your gear head WC330I cam they have give one Installation CD its called web cam Drive, just put the CD in your CD ROM and double click that EXE setup file and in few min your cam is ready to work.
IF you don't have you Web cam drive no issue you this link copy and paste to your browser
http://pcgearheadsupport.com/ghs/detail.php?item%20id=21
when page get loaded you can c one option
Drive Download
Click Download near drive so that your web cam drive start to download and you can install your cam in your system.
Good luck ! if you think your problem solved don't forget to rate
Dec 31, 2010 | Gear Head WC330I Webcam
Will not load
Open up your PC. And from the windows menu, left Click to open, Settings, Control panel, and the Add
Hardware wizard. From the Add hardware wizard, install your ASUS hard drive. Just follow the instructions. If you get it installed, then it a job well done. Most of the time, Asus is a supported item of Windows XP, Vista, & 7
However, if you are prompted to have your own CD to
get it installed. Just have your download from the
Internet. Just type at the Search engine blank (Free
download Asus (90N804SH021) Hard drive software
installer). Once you have your download, go back to
your PC menu. Click open, the download and follow
the instruction to have it installed. Then, have your
test on the Asus harddrive.
Nov 28, 2009 | ASUS (90N804SH021) Hard Drive
I have cd but my computer cant read it
It is impossible for the CD to work, unless the CD drive is defective... try other CD drives
If the CD has a lot of scratches then you need to download drivers in the internet to solve the problem...
click this link to get the driver.
Find number and choose from 55 to 59, since you did not specify your Operating System.
Fixya me if this solves the problem.... Rate me thank you if not.
Feb 07, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Computer is not recognizing my cd/dvd drive
Umm..Try install all the drivers of your system. the CD was enclosed in your system. if ever the cd is not work you should download the driver of your system.
or After installing a new windows do not restart your system until you finish all the driver installation and also the driver of your CD/DVD.
I 100% pinpoint that the your CD/DVD needs a driver. so install and you'll be fine.
Jan 18, 2008 | Dell Inspiron E1705 Notebook
Not reading CD RW
In the device manager, delete the items that have the yellow error icon, and the cd drive. Reboot your pc, you will get a message that says found new hardware, install the drivers.
If you do not have the drivers for the devices, go to http://www.driversguide.com/ and search for the drivers, download them and then follow the instructions listed above.
Jan 02, 2008 | Dell Dimension 3000 PC Desktop
Logitech webcam download
Look for your product each of the two links provided
http://www.logitech.com/index.cfm/405/&cl=us,en?prodcrid=405
http://www.logitech.com/index.cfm/405/&cl=us,en&legacy=1
When you find your product click Get Software
Note toward the center of the page -- Other Downloads
this is a list of items to download often there is more than one.
Choose operating system above for each item
Checkout the download instructions bottom of page for each item
Click Download Software to get the software
Unfortunately all items do not display download software and some say drivers/software are not available.
Dec 24, 2007 | Logitech Webcam
Dell Dimension 2400 PC Desktop Logo
1,128 people viewed this question
Alun Cox
