Question about Kenmore 40494 / 40495 / 40499 Electric Single Oven
Kenmore Ultra Bake Oven Won't Heat Up
We had a power failure where the lights flickered off and on, and our stove displayed 'PF Sab'. I was able to clear that, and the burners work, but now the oven/broiler will not heat up. Is this something that could be fixed easily/inexpesively or will the repair costs equal getting a new stove?
  • 833 Answers
Turn the breakers off and wait 10 minutes and then on.  If this doesn't clear the problem, you'll need an electronic timer module.  Electrical spikes cause problems like this.
Posted on Nov 28, 2008
Kenmore ultra bake self cleaning super capacity electric oven is showing the letters pf in red what could this mean?
PF usually just refers to power failure. You should only have to reset your clock and then check to make sure everything else works.
Jun 15, 2015 | Kenmore Ovens
We have a maytag gas single oven stove. Where do
Hi.
The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
If power is disconnected a new 72 hours cycle will start.
Push and hold the Clock button for about 10 seconds, that will reset SAB mode.
If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
Regards.
Mar 04, 2010 | Ovens
I have a Kenmore Ultra Bake Stove, we had a power outage and neither the oven nor burners works. The code on top reads PF 5Ab. What can i do to reset the stove?
PF is usually power failure.
If "PF" appears at any other time, a power failure occurred. To remove "PF"and to reset the clock, press STOP/CLEAR.
Unplug the unit for half an hour or so to see if it will reset.
If not try to get into the diagnostics so you can see if there is a stored
error code
Feb 15, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
665.95802000 f1 - E 1 error code
take the consol off you will find the tech sheet with all the codes. make sure you turn your power off first.
Dec 23, 2009 | Kenmore Ovens
Bake and Broil not working
Product manuals
Product manuals are available for most in-stock items.
Order a product manual by calling 1-800-366-PART (1-800-366-7278). Or download a free product manual at ManageMyHome.com.
Aug 01, 2008 | Kenmore 33169 Gas Single Oven
Electric Kenmore Ultra Bake Oven
I finally found my manual to the range, and to change from celsius to fahrenheit press the BROIL button for 5 seconds. A tone will sound, and the temperature should switch to Fahrenheit.
As far as the code PF 5ab--it could be PF Sab which means the power went out during Sabbath mode. Try pressing and holding TIMER OFF for 5 seconds. If that doesn't work, then open the oven door, press STOP/CLEAR, press both the HOUR "up" and "down" arrow pad at the same time and hold for 5 seconds, "Sab OFF" should appear. Press START to accept the change, then close the oven door.
Dec 13, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 40494 / 40495 / 40499 Electric Single Oven Logo
892 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
