Question about HP DeskJet 5550 InkJet Printer
My hpdeskjet 5550 printer is not printing. lights are flashing
I had to chg ink, cartridges did not stop in center to change. I held it til it stopped, then changed the ink..now lights are flashing and it won't print at all.
  • 57 Answers
Hi all of you ,
Since the cartridge drive not stop in center when open the to door, you have ffurther problem
try use the old one, if ok , clean your printer.
thanks
Hamedo
Posted on Nov 19, 2008
Deskjet troubleshoot My HPdeskjet 5550 won't print.: My HPdeskjet 5550 won't print. The orange light is flashing
hi..........
In this error condition, the following light pattern displays on the product control panel and a message might display on the computer:
  • Print Cartridge status light : On
  • Resume light : Off
  • Power light : On
Figure 69: The Power light is on and the Print Cartridge light blinksc02645167.gif
    hpweb_1-2_minus.gif Causes
    • The cover on the product might be open.
    • There might be a problem with one or both cartridges.
hpweb_1-2_minus.gif Solutions Follow these solutions in the order presented to resolve the issue. Solution one: Close the top cover on the printer
  1. If the cover on the product is open, close it.
  2. Press the Resume button (c01219285.bmp ) to continue printing.
Solution two: Determine the cartridge issue When there is an issue with a cartridge, a yellow arrow on top of the carriage (inside the product) points to a drawing of a cartridge that indicates what the issue is. Follow these steps to determine the cartridge issue, and then continue to the next section for solutions to resolve the issue.
  1. Open the top cover on the product. Wait for the carriage to move. The yellow arrow on top of the carriage (inside the product) points to a drawing of a cartridge that indicates what the issue is.
  2. Look at the drawing and then find the icon in the following figure that matches the drawing. Each of these icons represents a different cartridge issue. Use the icons to determine the cartridge issue. Figure 70: Determine the cartridge issuec02645168.gif 1 - Tri-color Cartridge Problem icon 2 - Black Cartridge Problem icon 3 - Tri-color Cartridge Low-ink icon 4 - Black Cartridge Low-ink icon 5 - Cartridges OK icon
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 28, 2011 | HP DeskJet 5550 InkJet Printer
How do i change the ink cartridge on my printer
These are the steps on how to install/replace cartridge(s) on Hp Deskjet 5550.
  • Press the POWER button to turn on the printer.
  • Open the top cover. The cradle moves to the center of the printer.
  • Open the cradle latch.
  • Slide the print cartridge out of the print cartridge cradle and discard it.
  • Remove the replacement print cartridge from its packaging and carefully remove the plastic tape. Hold the print cartridge so that the copper strip is on the bottom.
  • Slide the print cartridge firmly into the cradle. Ensure that the copper contacts of the print cartridge meet the copper contacts of the print cartridge cradle.
  • Close the cradle latch.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Nov 19, 2010 | HP DeskJet 5550 InkJet Printer
Changed both ink cartridges. Ink indicator light still flashing. Won't print test page.
remove cartridges switch off unit open cartridge door and clean off sensors and bay with a semi damp int free cloth close unit power up and then pull out power cable wait 10 seconds and plug power cable back in when it asks for the cartridges insert them
Jan 25, 2010 | HP DeskJet 5550 InkJet Printer
I have a HPdeskjet 5550 printer. While printing,
Have you tried switching off the printer and then starting after sometime
Dec 09, 2009 | HP DeskJet 5550 InkJet Printer
Hp 5550 print cartridge light flashing.power light on,not flashin
All HP ink cartridges are dated. If you are using the remanufactured ones the date is not changed and will not work properly at all. By HP ink only and you will never run into this again.
Sep 03, 2009 | HP DeskJet 5550 InkJet Printer
Can't find ink levels on my printer
I just had this same problem on my Deskjet 5550 printer. The orange light (ink indicator) was staying on. I found out that all you need to do is just open the front cover to the printer. If your printer is running out of ink, the print cradle will move to either the far left or far right side. If it moves to the far left side, the BLACK cartridge is low or empty and should be replaced. If the print cradle stays on the far right side, the COLOR cartridge should be replaced. Normally, when you open the front cover, the print cradle should move to the center. Hope this helps!
Aug 11, 2008 | HP DeskJet 5550 InkJet Printer
Ink light wont shut off
You will have to change the cartridges in the store that you have bought them, cause at least one of them is with problem in the internal circuit.
Mar 25, 2008 | HP DeskJet 5550 InkJet Printer
Printer won't print
Did you peel the piece of paper on the ink cartridge?Or if that doesnt help do this get the cartridge out and then dip some water on the ink leaking part with a piece of paper and well see what will happen.
Hpdeskjet 940c printer
make sure thats the right one and to test page and cean the heads if there still not ok change the cartridge again
Jan 03, 2008 | HP DeskJet 940c InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
193 people viewed this question
Ben Johnson
