Question about Freezers
Layer of water on bottom of freezer,causing problem opening bottom drawer, having to use hair dryer to thaw.
  • 370 Answers
If it is a frostless your drain tube is plugged. The water cannot go through the whole to the drip pan so it flows over into the freezer. Unplug the freezer and leave the door open all day to thaw. Or take the back wall out of the freezer and unthaw the drain tube with hot water and a hair dryer.
Posted on Nov 19, 2008
Ice buildup in bottom of freezer--puddle of water on floor
this sounds like your freezer is operating properly, except that the drainage of the water when going through the defrosting mode is not draining properly, pooling on the bottom of the freezer and then freezing. Check the drainage hose for the defrost in the lower pan. I would remove everything, place in ice chest, let the unit completely thaw out and then inspect. I hope this is beneficial.
Aug 05, 2009 | Freezers
Kenmore freezer drawer frozen shut
use your wife's electric handheld hair dryer as close to the rails as you can once slightly open you can use table salt/ice melt to free the drawer or; turn up your house thermostat to about 80 degrees for the day while you are at work; the drawer should be free by the time you get home.
Nov 18, 2013 | Freezers
Frigidaire FFHS2311LWD has water pooling up and freezing bottom drawer and lower vent. Drain tube doesn't seem to be clogged. Water leaks onto floor some days.
the drain tube is most likely clogged. if the lower vent is freezing up there is no way to confirm because it is covered with ice. the reason water leaks onto the floor is, the refrigerator goes into defrost, frost melts and runs down the ice to the door. use a hair dryer to remove all ice, then use hot water to check drain. drain tube may be up to a foot long and may have a trap. you may have to go in through the back to gain access to the drain
Oct 22, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
How do you defrost a older modle 13 cu ft standup freezer ?
Empty it out....pull the plug... get out the hair dryer....when all of the ice is thawed and the water soaked up then you plug it back in and restock the food...
heatman101
Jan 30, 2011 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Water freezing in bottom of freezer. freezer is 10 years old.
The defrost drain outlet is stopped up and freezing over.
Remove the bottom basket.
Turn the freezer off.
Look in the center of the freezer just below the cooling coils in the bottom of the freezer.
You will see a water drain trough.
It will be full of ice.
Use a hair dryer to thaw the ice and remove it.
The drain will become exposed.
It must be thawed also,so that you can pour water through it and the water goes all the way to the drain pan underneath.
Sep 18, 2010 | Whirlpool Freezers
I have a Jenn-Air Refig with the freezer on the bottom. The ICE maker is not working and I think it might be frozen. How do I disconnect the ice maker so i can thaw it out?
Why not do a quick thaw and move the frozen goods over to the firdge for a few minutes and grab a blow dryer. This should give a temporary fix until you can pin point the problem. Be kind to me please with a Thumbs up. I am a long ways away and can only help a little. Raz
Apr 09, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Fridge/freezer model FFA90P frost free ice has
The water coming from the bottom is from the evaporater tray because it is too full and running over. There is a grill on the front bottom of the frig. ,and there is a srew or two on either side probably 1/4" maybe 5/16" loosen these and remove the grill. If no srews visible then it just snapps in. Remove grill and slide tray out and dump it.
The icing problem under the freezer tray is a defosting issue. you can move the food items to a cooler with ice or another unit and let this one thaw out with the doors open and unplugged and towl on the floor, the tray that is overflowing now will overflow again while the frig. is unplugged because there is no heat being generated to cause evaporation. You will need to have this checked out by a pro, generaly a service fee and they will tell you what has failed and can ballpark a price to fix. once the unit is thawed, ( this can take 12- 14 hrs) the unit will work again until the air passages get frozen over again. I suspect defrost heater element, defrost heater timer if ice maker equipted,there is also a little fan up there tan can fail. without seeing the unit in person only guesses. the thawing trick will buy some time.
Jul 12, 2009 | Hotpoint Freezers
My freezer bottom gets a frozen layer of clear water in the bottom every few months...then i must transfer everything and TOTALLY thaw to get that drain hole free again...whats up with that? granny
This water comes from the defrost cycle. The drain hole is probably plugged with food. The drain usually goes to a small pan under the condenser where it eventually evaporates. Look for a hole or slot in the bottom of the unit.
Apr 18, 2009 | Frigidaire Freezer FFU1464
Freezers Logo
167 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
