Question about Airtemp B7D18E7A Air Conditioner
FAN DOESN'T GO ON
The unit turns on, but no fan.
I think the connection from pcb is lost so fan is not switching on so i think you should not try to solder it rather try to change the fan
Posted on Jan 28, 2007
Gas package unit
the bushing or the bearing in the motor may have already worn out. or may need some lubrication. the rotor is trying to turn but it's stiff and won't continue to turn. dont continue to turn on if it wont spin otherwise you'll damage the motor further. it might also be the busted capacitor "if it has"
Jun 04, 2013 | Amana Heating & Cooling
AC unit comes on, but fan doesn't work. It works with furnace.
check for loose wiring to Tstat, or the new stat has failed.
if the stat has a fan on switch and when on the fan works then replace the stat
Apr 10, 2013 | Heating & Cooling
Fan light turns on but doesn't turn off with remote also fan doesn't go on with remote
Make shure your batteries are good in the remote. Also some remotes have little dip switchers inside the battery cover that are either on or off. They must be in the same position as the dip switches on the receiver in the top canopy of the ceiling fan or the remote & receiver won't talk to each other. Apart from that you will probably need to replace the remote control & receiver unit.
Dec 12, 2012 | Hampton Bay 52 In.Carriage House II in...
Compressor comes on for about 1 minute, but fan doesn't. Then a sound like a pressure release valve opening starts and will continue until you turn the unit off. The unit will sometimes work normally...
The sound is from the compressor high side pressure exceeding design limits due to the fan not operating, the fan pulls air across the coil to remove heat from the freon which keeps the pressure down. The capacitor or fan motor may be bad. Need to open unit panel and visually inspect the capacitor for swelling, (rounded top should be flat) where the wires connect. Also use meter to test mfd of capacitor. May only need capacitor replacement, most common failure on this unit.
If not corrected damage can be done to the compressor due to overheating.
Aug 24, 2011 | Heating & Cooling
Two winters ago i had to change out my thermostat. Then last summer my AC wouldn't turn on. So i thought it was the thermostat i had so i just went and bought a better one. but still the Fan on the AC...
If the compressors running and the fan is not you should check the fan motor capacitor and check for power at fan motor if power is there you have bad fan motor
Jun 21, 2011 | Heating & Cooling
Condeser unit fan not turning.
Hello, most likely youmhave a bad capaitor or bad fan motor. If you push the fan and it gets going than the capacitor is bad,if not bad fan motor.
Jun 08, 2011 | Goodman CKL36AR36 Air Conditioner
The fan will not engage when unit is turned on and after 5 or so minutes the circuit breaker trips.
since the fan doesn't run - the compressor heats up and pulls excessive amps and trips the breaker.
99 out of 100 times your fan motor will be bad.
You need to replace the motor.
Jun 07, 2011 | Kenmore 74123 Air Conditioner
Have amana heat pump ac unit,,condenser fan doesn,t turn when on, not cooling, makes humming noise
The fan needs to be cleaned and lubbed. If this cannot be done then replace the fan.
May 22, 2011 | Amana Heating & Cooling
Airtemp B7D18E7A Air Conditioner Logo
56 people viewed this question
Top Airtemp Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Squire
Mike
Are you an Airtemp Heating and Cooling Expert? Answer questions, earn points and help others
