Question about Kitchen Ranges
GE oven line is broken
I have a GE XL44 gas range model jgbc20wea2ww and the knob for the oven itself is completely snapped off along with whatever metalic, long piece that was attached to it. As a result, i cannot use my oven. Im not sure if it possible to replace that metalic line or just buy another range?what is it that i need? thank you
  • 1,543 Answers
You will need to replace the oven thermostat, part WB20K8
Posted on Nov 18, 2008
How do I fix the broken oven knob on my GE XL44 oven?
First you need to check the value body (around the value stem) for leaks.. you can use soapy water, your nose for smell...if you suspect a gas leak... turn the gas off to the appliance (located behind the stove) and call your gas supplier or a service tech...
You can use a thin pair of needle nose plyers to hold the stem.. or an easier way is to cut a playing card in half, poke a hole in the middle of it so it will slide over the stem... cut a line for the edge of the card to the hole so you'll be able to pull the card out from under the installed knob...
Jun 21, 2014 | GE Profile Spectra JGBP90 Gas Kitchen...
The oven comes on by itself for about 20 seconds
If you have the thermostat shut all the way off and the burner turns on, the thermostat is defective.
Feb 02, 2010 | GE Kitchen Ranges
GE XL44 oven won't turn off. Knob off and pin is loose
My GE XL44 oven would not shut off and it turned out to be a worn out thermostat for the oven. I have written up a step-by-step tutorial on how to replace the thermostat on my blog: John Fixes Stuff GE XL44 Oven Will Not Turn Off How To Replace Oven...
Jan 17, 2010 | GE Kitchen Ranges
I have GE XL44 white gas oven and range I want to know if replacement parts available so I can replace the door and front knob panel with stainless steel parts
Yes. But you probably won't like the price.
Do to repairclinic. com and put in your model number to check for parts.
Jan 03, 2010 | GE Kitchen Ranges
I have a ge xl44 gas range. the oven knob has come off
You will need to locate your full model #, usually open the bottom drawer and you can see it on the chassis on the right or left side. Try searspartsdirect.com type your model in and it will give you a parts breakdown and about the best assembly view your going to get. Sometimes there is more to be desired but this should help. Please rate this post.
Dec 14, 2009 | Kitchen Ranges
Kitchen Ranges Logo
259 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
