Question about KitchenAid KESC307 Electric Kitchen Range
Oven lights I have replaced both oven lights with new ones, and they still do not work. What else can I do.
    Scholar:
  • 82 Answers
Try replacing the light/door switch. You can go to www.coastparts.com or www.marcone.com.
Posted on Dec 08, 2008
GE Adora JGB605DET3WW after self clean door would not unlock. Tried shutting of breaker but after turning back on still the same. Replaced door lock motor with another one and circuit board and still...
Press the oven light switch in and see if the it returns to normal. The oven light switch is part of the self clean circuit and it is is not depressed or not working then it could be the entire problem. If pressing the switch in cures the problem, then the switch is working fine and the clock oven control will need to be replaced. Happy New year and have a wonderful day. Oven light switch part number WB24K10068, Oven control part number WB27K10319. when changeing out this part you have to remove the overlay with button description on it and transfer to new clock, try gentel heating it before trying to remove or the paint will rip off and you will need a new overlay here is the part number just in case WB27K10408
Dec 26, 2017 | GE Ovens
My oven light is replaced with a new one but still not lighting up
Bulb socket must have a problem. The bottom contact is not touching the bulb. You may need to replace the socket if you can't bend the bottom contact back into place.
Feb 18, 2015 | Neff Ovens
Neff bottom oven light not working after replaced blown bulb
Hi, My Neff oven bulb was replace with a new one after the old stopped working. The new bulb lasted 4 days and stopped working, could you tell me what seem to be the problem please.
Dec 28, 2012 | Ovens
Hi, I have a wo570xd double oven and the controller is playing up, ihave had F& P send me a new controller (572942p), this controller did not work so contacted them again and they have sent out a new...
fisher & paykel oven model WO570XD seems to be no power from source to the wall oven however range top works fine. Power light on switch to oven is illuminated indicating there is power however there is no lighting on digital display unit. Any help appreciated
May 31, 2011 | Fisher and Paykel Ovens
Microwave GE JES738 doesn't heat
Almost certainly the magnetron tube in your oven shorted and caused the light show and sound effects. This is the microwave source, and without the waves there's no heat. The tube is replaceable, but it's a costly parts. Add in repair labor, and you'd be better off replacing the oven. New ones are often cheaper than the parts alone today.
Apr 03, 2010 | GE JES738 Microwave Oven
CANDY OVEN
It will be the oven element that has failed, you need to fit a new one.
It is located at the rear of the oven compartment.
Feb 22, 2010 | Candy F248P Electric Single Oven
Oven lights don't light. replaced, but no light. panel is good, heat works. Clock is accurate; only lights won't light when door open.
there should be a switch around the frame where the door closes. take that off. then disconnect the two wires. then join the two wires together, if light works then the switch is faulty. get a new one and replace. also make sure the new bulb you replaced is the right one and not faulty.
Jan 10, 2010 | KitchenAid Kitchen Ranges
Fan oven not heating but fan and light work
Most likely the heating element has failed. You need to replace it. It is not a difficult job, you just remove the old one and fit the new one. you will need to undo a few retaining screws and remove the connecting wires from the old one and connect them back to the new one.
Remember to switch off the power to the oven before working on it.
Dec 21, 2009 | Creda Ovens
Oven not heating up
If the oven fan is working o/k, then all you need to do is replace the oven element, a straightforward repair, and cost effective, if no fan, then could be expensive.
Please rate my solution.
Thanks.
Sep 22, 2009 | Neff B1432 Single circotherm plus Electric...
The lower oven ignighter does not glow
I had the same problem and swapped the oven igniter with the broiler igniter and the oven now works. This proved the oven igniter itself was the fault, now I have to replace the broiler igniter with a new one(which is much easier to get to).
FYI: An igniter may glow red and still not allow the oven to work. The igniter has to draw a certain amount of electrical current for the main gas valve to open.
Jul 20, 2009 | GE JGRP17 Gas Single Oven
KitchenAid KESC307 Electric Kitchen Range Logo
81 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
