Question about Fujitsu Siemens AMILO Pro V2000 Notebook
Hotkey(wireless button) restarts computer
Every time i try to activate my wireless connection by pressing the wirelessbutton(hotkey) on my amilo pro v2000 the computer restarts itself.
This problem just recently occured...
Does anybody have any experience with this malfunction?
  • DrBiGM Jan 09, 2009
    i have the same problem
    and i need help
  • Anonymous Feb 09, 2009
    me too same problem!
Can't get the wireless to come on
Exterior Wireless Switch
Step 1
Position the laptop so that you're facing the screen and the keyboard is in front of you.
Step 2
Check the front edge of the laptop's casing.
Step 3
Identify the wireless indicator light labeled with a wireless antenna icon. The "On/Off" switch to the left of the indicator light is the wireless switch.
Step 4
Move the switch to the "Off" position to deactivate the wireless adapter or move it to the "On" position if you want to power on the wireless adapter.
On-Screen Wireless Switch
Step 1
Press and hold down the "Fn" function key on the computer's keyboard to display the laptop's hotkey card icons on the screen.
Step 2
Click the "Wireless" icon on the screen or press the corresponding hotkey button on the keyboard, typically the "F8" key on a Toshiba laptop.
Step 3
Click the "Wireless On" or "Wireless Off" icon in the options list below the hotkey card icon to activate or deactivate all wireless connections. If your laptop has Wi-Fi and Bluetooth connections, you can also choose to activate or deactivate these services separately.
if have drives problem you can download using this link
http://www.toshibadirect.com/td/b2c/retail-product.jsp?poid=452315
Sep 13, 2013 | Toshiba Satellite L505DS5983 Notebook
My volume buttons on my compaq presario c769us are not working , is there a combination for the volume buttons
From the manual:
http://h10032.www1.hp.com/ctg/Manual/c01114193.pdf
Hotkeys are combinations of the fn key (lower left of keyboard) and one of the function keys:
Mute and restore speaker sound. fn+home
Increase speaker sound. fn+pg up
Decrease speaker sound. fn+pg dn
To use a hotkey command on the computer keyboard, follow either of these steps:
Briefly press the fn key, and then briefly press the second key of the hotkey command.
- or -
Press and hold down the fn key, briefly press the second key of the hotkey command, and then
release both keys at the same time.
Muting speaker sound (fn+home)
Press fn+home to mute speaker sound. Press the hotkey again to restore speaker sound.
Increasing speaker sound (fn+pg up)
Press fn+pg up to increase speaker sound. Hold down the hotkey to increase speaker sound incrementally.
Decreasing speaker sound (fn+pg dn)
Press fn+pg dn to decrease speaker sound. Hold down the hotkey to decrease speaker sound incrementally.
More manuals for this model:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lc=en&product=3678775&
Jan 25, 2013 | HP Compaq Presario C769US Notebook
I have IBM thinkpad R60 laptop . I got the laptop formatted few days back and loaded windows XP and MS office . after that the wireless radio is On all time . earlier after pressing fn and F5 th options...
Please follow these steps to make it work:
1. Uninstall the wireless driver using Add/Remove Programs
2. Uninstall the Hotkey utility using its Setup program (uninstall is an option in the Setup app; it doesn't appear in Add/Remove Programs control panel)
3. Restart
4. Delete the Hotkey folders from C:\Program Files\Lenovo\PkgMgr [key step!]
5. Reinstall the Hotkey Utility and the wireless driver (don't reboot if prompted)
Regards.
Jul 29, 2011 | Lenovo ThinkPad R60 Notebook
Amilo 2727 wireless adapter hotkeys
Please uninstall the driver though Device Manager and get it install from the disc given by manufacture website or download the latest driver.
Path is :
My Computer(right click)->Properties ->Hardware->Network Adaptor
Jul 30, 2009 | Fujitsu Siemens AMILO Pro V7010 Notebook
I recently discovered that Anytime I start my Toshiba Saetelite A105-S3611 laptop/notebook with windows Xp SP2, there is a message: ?Toshiba Power Saver?, A fatal error has occurred, this program will be...
Download the hotkey utility from the toshiba web site. I got this errorafter installing service pack 2 for xp. The hotkey utility fixed it.error appeared every time I started windows xp. Go to:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp
and go to downloads, select model and download:
Toshiba Hotkey Utility
Install and restart, problem solved. thank you, thank you...
May 05, 2009 | Computers & Internet
Amilo pro v3515: the hotkeys fn+up for brightness
you need to download a driver called "hotkey utility" and the buttons will work again
go to :http://uk.ts.fujitsu.com/support/downloads.html
search for v3515
you will find a list of drivers , scroll down a alittle and you will find hotkey utility , download it , install it ...... try the buttons :) MAGIC
Apr 19, 2009 | Fujitsu Siemens AMILO Pro V7010 Notebook
Wireless hotkey not working
i belive that when your computer boots you press F2 and the wireless card is automatically turned on
Mar 21, 2008 | Fujitsu (S26391-F2494-L100) Bluetooth...
Built in wireless lan........
Operating System? Sometimes with XP, you have to disable the Zero Wireless Configuration Utility when using a proprietary on-board utility. This is done in the services.msc panel.
Start > Run > services.msc (ok)
Dec 03, 2007 | Computers & Internet
Hotkey mode
This just worked for me. Using your PC keyboard, boot up to the PC first and then power up your mac. Hit the scroll lock twice and IMMEDIATELY hit enter. You have to go fast- click-click-click with no hesitation and it works great. I still can't toggle the hot keys to set up my mac keyboard, which I prefer using, but I'm assuming it takes the "right" timing on the keys. I'll keep trying.
Oct 23, 2007 | IOGear GCS632U 2-port KVM Switch
Hotkey
you may have a faulty keyboard driver, go to my computer icon, right click>properties>hardware tab>device manager, then go down list to keyboards, click + sign, right click on your keyboard type and select uninstal. Restart notebook and the keyboard will be installed automatically again and should work, if not, make sure you have the latest drivers. If still not working then there is a hardware fault, but i doubt it as the software is reporting the button is being pressed.
Aug 27, 2007 | Toshiba Satellite M45-S331 Notebook
Fujitsu Siemens AMILO Pro V2000 Notebook Logo
363 people viewed this question
Top Fujitsu Siemens Computers & Internet Experts
Alun Cox
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
