Question about Honeywell CT87B ROUND HEATING&COOLING MECHANICAL THERMOSTAT - WHITE Heater
My heat wont turn off
I installed a honeywell thermostat in my house last summer. I've installed thermostats before and never had any problems but this one is a nightmare i went threw like 3 before i found one to work with all he wires. i eventually found a more up to date version of what it originally had. well now i turn on my heat and it runs fine except for it wont cut off but the E-heat works just fine and cuts off and th a/c works just fine. i've checked and double checked and the wiring is correct to the best of my knoweledge.I need to figure this out without another $200 bill from the hvac men.
  • Anonymous Dec 30, 2008
    heat runs all the time with Honeywell thermostat
  • 24 Answers
If you have an emergency heat position we will assume you've got a heat pump. If you do not have a heat pump you have the wrong thermostat for your application. Need model of this thermostat, wire colors, termiation points (what terminal designator they are connected to), and if you have it where they were and the model of the last thermostat that worked correctly
Posted on Dec 18, 2008
Honeywell thermostat blank screen on cool
I wonder if they shorted a wire a during install. That is where I would begin.
May 14, 2013 | Honeywell Rth2310b 5-2 Day Programmable...
I am attempting to turn on the home central gas heater for the first time this year. It is controlled by a honeywell self ignition model number sv9541. I follow the instructions on the front panel and...
Check to make sure the gas valve is opened. I've turned mine off for the summer months; when I went to use the heater for the first time...I realized I had turned the gas off.
Nov 17, 2009 | Honeywell Programmable Thermostat Heater
I installed my honeywell rth221b1000 this summer and got it to work with the a/c. When I switched it to heat it does not heat. The heater seems to come on but it does not heat and the fan does not run. I...
If when you turn the heat on you hear the furnace fan start up (exhaust fan) then the problem is NOT the Thermostat....need some more info on the furnace...the Wiring in the thermostat should include a Jumper wire between RH & RC if you have 4 wires and no jumper required if you have 5 wires
Oct 18, 2009 | Honeywell Programmable Thermostat Heater
Honeywell RTH230B works on AC not on Heat
check wiring to furnace check wire hook ups on board match letters and colors sometimes installer use what ever wiring they chose on letters
Oct 16, 2009 | Honeywell Electronic Programmable...
Thermostat wont shut off?
either the thermostatic spring the micro switch is mounted and is defective and is not moving to change micro switch position to cycle furnace or the contacts have welded themselves, try, with unit off tapping on thermostat and running it from low to hi a couple of times and see if this solves your porblem, you can remove outer ring and see the thermostatic coil and turn it and see if the mercury inside the micro switch makes and break the connection
Sep 30, 2009 | Honeywell Programmable Thermostat Heater
Whan your room is up to temp or room is set at 70 and your stat is at 70 do you hear the stat click off .if not its a bad stat. you will have a little flam on your stat that should go off also
Dec 28, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Cold air will not turn on
What you can do is you can go to any store for special like bottles that you put inside the AC unit to get cold air.
Thank You!!!!!!!!!!
Jun 23, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
Mar 07, 2008 | Honeywell Programmable Thermostat Heater
check your wireing make sure that you dont have the red wire touching the white
Jun 02, 2007 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
343 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
