Question about Kyocera KM-1505 Copier
Error message DC1560
Hi - we keep getting a J 30 error message flashing on the counter - what does it mean and can I fix it myself?
thanks
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 87 Answers
This code shows that paper feed is jam in left side.just check any paper is jammed in this side.or sensor liver is pressed in paper path.by MIAN JEE
Posted on Dec 18, 2008
What does a flashing orange mean on my samsung ML 2165?
Install the Easy Printer Manager from Samsung site and you will see error message.
Reset toner counter (up to firmware version 1.xx.01.12) you can here:
http://fix-bay.com/fix-proshivka-samsung-ml-2160-2165-2167/
Nov 19, 2015 | Samsung ML Office Equipment & Supplies
NOKIA C2-03 CONTACT SERVICE SOLUTION
Message CONTACT SERVICE on nokia c2-03 please solution...........
Apr 19, 2012 | Nokia Cell Phones
Hi i keep getting the E1 error message flash up on the sewing machine, it still sews but it keeps stopping and the E1 error message comes up, what exactly is wrong with it? can you he;lp? Thanks
E1 means that your machine thinks the thread has broken.
There's nothing you can do to fix this: it has to go to an authorised Singer Service Centre for diagnosis and repair. Usually it's a faulty thread sensor.
Sep 10, 2010 | Singer CE-200 Quantum Futura Computerized...
Can you tell me what an F1 error Message means - 30 minutes into baking, I got beeping and an F1 error message. Canceling did not turn the oven off and the only thing I could do is turn it off at the...
"F1" code clearly indicates that main control board has failed. The possible fix for this kind of problem is you have to replace the faulty circuit board. This is the only solution and you cant repair anything else in this unit when F1 flashes.
Thank you !!
May 30, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Epson Pro 7600 Service required error
Service required mean waste ink counter overflow. You need to reset it. SSC Service utility don't work with this type. The resetter is not for free, it's commercial. Only some distributor have it.
May 27, 2009 | Epson Stylus Pro 7600 InkJet Printer
Sub Zero model # 695 is flashing EC-40 error message. No ice.
When our Sub-Zero Model 650 quit making ice, and the SERVICE ICE lights started flashing, we called our technician who said, "You can pay me $178 for a service call or have another option - you have 2 seconds to decide. Oops, your time is up, I will decide for you!"
"Open the door and push the REFRIGERATOR UNIT ON / OFF message button; wait 30 seconds and push it again. About 95% of the time, the unit creates the glitch, and you are simply rebooting the computer. If that doesn't work, call me. I hate to take your money to come out to push a button."
IT WORKED! The warning message turned off and the freezer started cranking out ice.
Dec 18, 2008 | Refrigerators
You need to be able to clear the counters in the printer that tell the printer to stop working.
In order to do that you must
1. Turn printer off
2. you must hold down the "Paper Source, Paper Feed, Select Feed, Cut/Eject" buttons all at the sime time while you turn the printer back on.
3. From there navigate through the menues to clear the counter that pertains to you or all.
(Error 00000101 is pertains to the print head motor)
Word of warning -
Those counters can be a pain as they cause the printer to stop working however you do need to get your printer serviced by a tech as soon as you can because the error is a warning, reset the counters lets you finsih a job, but if it goes unserviced too long it will actually break down all togther.
So even after you rest the counters you absolutly must get your printer serviced soon.
Apr 17, 2008 | Epson Stylus Pro 7600 InkJet Printer
Macromedia flash error message
Here you can download the 30 days shareware version of complete macromedia flash software. Download and install it. If the problems comes back out after trial expires, it means you are trying to use a feature that requires complete flash software installed.
regards
Mar 21, 2008 | Gateway GT4022 PC Desktop
Service error shutdown
Hi Minolta man. This is a very common message on ALL Epson ink jets. The printer has a "protection" counter inside which monitors the amount of ink pumped into the waste pads in the base of the machine. After a while the counter will hit it's pre-determined limit and light up like a christmas tree and stop you from printing any more. MANY repair centres will tell you (and I believe even Epson have said) this error is not worth fixing. Well it is and it's SOOOOooooooo easy. What you need is a piece of software to reset the counter, some instruction on how to dismantle the printer to get to the waste pads, and more instructions on how to clean the pads. You can get a rescue kit that offers all this from http://www.TheServiceManualShop.com If you don't see thje one you need listed for your model, drop them an email and they will create one for you. The file is delivered by instant download too, so you can crack right on with the job.
Feb 27, 2007 | Epson Stylus Photo R1800 InkJet Printer
Internal parts out of date
I don't have the solution, mine did the same thing a couple weeks ago, just after buying a lot(15) of cartridges. I called Epson support, who wanted 10 dollars to talk to me, I talked em out of it. That kind of message means internal error. There is no fix they say, and they offered me discounts on a new printer, but the C42ux is out of production. I'm still trying to learn more to fix it myself.
Dec 19, 2006 | Epson Stylus C42UX InkJet Printer
Kyocera KM-1505 Copier Logo
150 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
