Question about Seagate (ST3160026A-RK) 160 GB Hard Drive
External case removal, Seagate ST3160026A-RK External drive
Hi all, I want to replace the drive in my Seagate ST3160026A-RK but can't figure out how to get the case open. Can anyone tell me the secret??? Thanks!
  • venktech Mar 31, 2009
    Can anyone tell me what kind of screws are used in this hard drive. I am trying to remove the screws but am not able to.
  • Anonymous Mar 18, 2014
    the usb connection broke. how do i open the case and is there a way to fix the connection
    Problem Solver:
  • 4 Answers
You remove the foot/stand unit, then the silver cover with the circular rubber ring can be carefully pried off. If you do this, you'll void the warranty, so if you want to do this because your unit is dead, then you should return it for a warranty repair. If you're doing this to put a larger capacity drive in the box, be aware that larger or faster hard drives might generate more heat which could adversely affect the new drive's ability to operate properly.
Posted on Jun 23, 2007
SOURCE:
Transplanting Hard drive from Seagate Free Agent go flex to another enclosure. I believe the power supply is dead only one light comes on and it just beeps
Here's one case. They're not terribly scarce, but not found just everywhere, either.
http://www.amazon.com/Aluminum-External-Drive-Enclosure-Silver/dp/B000F3WB0Y
Jul 07, 2011 | Seagate Free Agent Go Small 12 GB USB...
I have a Seagate 3.5 inch pushbutton backup external hard drive, M# ST3400601CB-RK that states that it needs to be formatted. I would like to remove the hard drive and put it as a slave on another PC. ...
Attaching it to another PC will just move the problem to the other PC. USB drives frequently have the problem you are seeing.
You can have your partition and data restored remotely by this guy. http://FreeDataRecovery.us
May 27, 2011 | Seagate (ST3500601CB-RK) (ST3400601CBRK)...
Please i need the power adapter rating for seagate
Have you got the original power adapter?
If so the voltage details are printed on the label on the bottom of the adapter.
If the external USB Seagate hard drive houses a 31/2" drive then it requires an power adapter that provides +12 volts and +5 volts both supplying approx 2000mA of current.
If the Seagate uses a 21/2" (laptop) hard drive then it only requires +5 volts power adapter.
The only problem is the power connector to the external drive, make sure it suits the external hard drive unit and the power pins are correctly wired for the Seagate. If the polarity of the plug is incorrect lt wired (ie reverse polarity) then it could damage the USB hard drive and adapter case.
Nov 20, 2009 | Seagate (ST3500601CB-RK) (ST3400601CBRK)...
The USB port on my seagate 500GB external drive has broken off, and is somewhere inside the case.
You should be able to pop open the enclosure to retrieve the hard drive. You may need to take out a few screws.
Once you've done that, you can purchase another external USB enclosure to replace the broken one.
Aug 09, 2009 | Seagate FreeAgent (ST305004FDA1E1-RK) 500...
System will not detect my Seagate ST3500641CB-RK 500gb external hard disk
if your system some virus hope it is not read......better you try any other some card reader or pen driver if it read you try other OS ....
Jun 07, 2008 | Seagate (9Y7275557) 400 GB Hard Drive
Power supply for Seagate 400GB
Ebay or seagate.com may be a solution.
I've used those Seagate portables and 2 have caused problems.
Or disassemble the unit, remove the drive and buy a portable case or USB adapter.
Oct 16, 2007 | Seagate 400GB 7200rpm External HDD Retail...
Seagate (ST3160026A-RK) 160 GB Hard Drive Logo
930 people viewed this question
Top Seagate Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
