My goodman furnace seems to never catch up to the setting on my thermostat. It is constantly running
What a problem !
Posted on Nov 18, 2008
Goodman Model GMV950905DX-an electrical surge burned out the transformer which I replaced, also replaced the circuit board. The variable speed furnace will no longer kick into high speed and it will l
If I remember correctly, there are dip switches on that control board that can be set individually. It is possible that it is just a setup issue. The switch positions should be explained in the installation instructions. I know that some Goodman and Amana two stage furnaces can be controlled by a single stage thermostat, but the dip switches have to be set properly. If the switches are set correctly the furnace will run in low stage heat for approximately 5 minutes and if the thermostat hasn't satisfied yet, it will kick in to high stage heat. I hope this points you in the right direction!
Dec 16, 2014 | Goodman Manufacturing Goodman Gas Furnace...
Furnace blower runs after temp is reached
Is your tstat fan selector in auto?? Does the fan ever shut off?
Jul 18, 2017 | Heating & Cooling
Furnace will not shut off after the setting is reached. have changed thermostat. Temperature reading goes down on thermostat, furnace still runs. Model : Goodman furnace,gmh95/gch9
Check if your thermostat is set on 'o fan' setting.
If it is, trey to set it on 'Auto-fan' instead.
since it seem as if the heating does go off,only the fan may be running continuously.
this is possible if the thermostat is incorrectly set or installed.
good luck.
Jan 30, 2010 | Goodman GMS90703BXA Heater
Will not turn on when set to automatic. when switched to on position no hot air comes out of vent.
If you are talking about the switch on your thermostat, "On" and "Automatic" refer to the fan. In the "Auto" setting, the fan only runs when the furnace is running, in "on" setting, it runs the fan constantly. Your furnace is not firing for some other reason, the on/Auto switch is working properly.
Dec 16, 2009 | Goodman GMS90703BXA Heater
Electric furnace won't shut off
It sounds like a bad or badly miswired T-stat
Jan 20, 2009 | Goodman CLQ36AR49 Air Conditioner
Electric furnace runs but won't shut off on heat setting
I would insist that Sears either have a Senior tech come out and fix it or return it to the state it was prior to them touching. Then call some one else. Have them involve the Goodman rep in your area.
Seems that furnace runs every 5-10 minutes
check air filter is clean also automatic fan control settings try that first
Jan 08, 2009 | Goodman GMS90703BXA Heater
I have a Goodman electric furnace model ARUF049-00A-1. It seems to run constantly and emits an odor of sewer through the air ducts
Can you view inside to the electic heaters and ensure they are clean? On rare occasions, insulation from furnace or attic believe it or not gets into furnace and gets cought up in the coils. It could possibly ruin your sequencers, you'll have to have a tech replace those.
Dec 05, 2008 | Goodman Heating & Cooling
Goodman Furnace m/n GKS90453BKAC
A constant red light (not blinking) indicates that the thermostat is not calling for heat. Of course you know it is but just to be safe, jump out R and W on the board. If it continues to do the same as you indicated, replace the board.
Dec 05, 2007 | Goodman GMS90703BXA Heater
My fan runs constantly even if the system is off. The only way to cut it off is to kill power by the main outside breakers
Check the thermostat and make sure it is in the auto position. If that does not correct the problem you will need to disconnnect power to the unit, unhook the thermostat wires and plug power back in. If tha corrects the problem it is either in the wiring or the thermostat. If the fan continues to run, replace the furnace control board.
Nov 05, 2007 | Goodman CLJ30AR32 Air Conditioner
Heating & Cooling Logo
55 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
