Haier HLH367BB, 37" LCD TV. Power button fell off the top aboout 6 months ago. Using a universal remote, original got chewed up by the dog over 6 months ago. Now buttons don't respond, won't stay off unless unplugged, able to use only by using video 2 plug in and just switching from satelitte Tv box to dvd. In Des Moines, IA Is service available locally or what can be done?
  • 319 Answers
SOURCE: My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Posted on Apr 23, 2008
  • 4 Answers
SOURCE: NO POWER, PICTURE, OR SOUND, power button flashes green 2-3 times
had same problem. update tv software with a usb drive. do not take the tv apart. its easy download to computer unzip to usb drive and put drive in right side of tvs usb slot with power off, then turn power on, you should get an update screen.
did not work for me the first time i had to format usb drive to fat (not fat32) and then unziped to the drive took 10 minutes to update. I have tv 60PP9200D/37
Posted on Apr 28, 2008
SOURCE: programming rca universal remote for my toshiba tv
I can't exactly help you, but can you tell me how you programmed the remote to your TV, because I cannot get mine to work...
Posted on Sep 12, 2008
SOURCE: My TV has stopped responding to the remote control (and the universal remote) and the front panel buttons don't work
waynejman, I have the same exact problem, can you tell me what your outcome was?
Posted on Nov 16, 2008
SOURCE: Samsung 40" LCD HDTV #LNS4041DX/X
I the same problem and I found that the Capacitors used on the power supply portion of the circuit board were leaking and/or bulging. These parts were failing and as a result the problem worsened with time. If you are able to remove and solder new parts on to the circuit board follow the following procedures. Or get a technician to do the repairs.
1) Make note of connections at back of TV.
2) Unplug power cord and other connectors from back of TV.
3) Remove back of TV with a Phillips (+) star shaped screw driver.
4) Note the position of all connections to the main board.
5) Remove circuit board taking care not to damage any of the components.
6) Locate parts CM806, 811, 812 & 817, all 1000 uf 10v capacitors.
7) Remove and replace parts with capacitors of equal physical size that are (1000 uf ). I would recommend a voltage rating of 25v or 32v. Note that the voltage refers to the amount of voltage the capacitor can handle. The higher the better.
8) Reinstall and reconnect the circuit board.
9) Replace back on TV and setup the unit as before and you’re done.
10) Enjoy!
I replaced the parts for just under $10.00.
Posted on Apr 27, 2009
VW37L 37 in. LCD HDTV input button wont work
Have you find out if the problem is with your remote control? For instance, you are able to control your TV using a Universal remote control. My 32" Vizio TV had a similar problem, initially thought it was related to my remote control but in fact the TV didn't respond either to an universal remote control of my SAT receiver that I eventually use to just turn on and off the TV. I've found out that the problem was with a little board on the TV located at the left down corner viewed from the front side of the TV and that receives the signal from the remote control. I found the board on ebay for about $5, replace it and the TV responded again to both original and universal remotes.
Nov 11, 2013 | Vizio VW37L 37 in. LCD HDTV
Philips 37PFL5322D
Your remote control need cleaning. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 750 posts to different brand TVs now.
Pull up older posts there. have all details about how to clean a remote control.
Sep 12, 2012 | Philips new universal remote control...
Apex DVD/Tv combo GT2015DV won't play dvd's
Something is wrong..crbr799 your DVD-TV has a TV-DVD button on the right front to switch from TV to DVD play...OPEN button on left side ,place DVD in tray, close & press PLAY...
I something simulator that needs the remote control for the SPECIAL functions....by the way the ORIGINAL r\c is $135 to $155, a replacement ($35) will turn the TV\DVD on ( which you can do without the r\c) and NOT function with anything else.
P.S. they will try to sell you universal r\c that work with the CABLE boxes, the ones that you pay a monthly fee!!
Aug 11, 2011 | Apex Digital Televison & Video
I need a new remote control. My dog chewed up the original. Is there a universal remote I can buy that works with my ilo tv?
Try website like Remotes.com to buy the original remote.Any universal remotes is find,but getting ur tv codes to work on ur tv universal remote are 70/30%,u want to tries with the univeral remote,it up to u.
Jun 24, 2010 | Televison & Video
Do they make a 27 in in this tv
Universal remotes are so cheap now I would just get another one and program it for your TV. You can also get original remotes at http://remotes.com/ Let me know if you need anymore help.
hardrocko
Thanks for using FixYa
Mar 02, 2010 | Funai Trutech 13" TV
My dog chewed our Tv remote
Try website 1-800-remotes Factory original.Get the same or very close to the original.
Dec 15, 2009 | Philips Magnavox Learning Universal Remote
Dog chewed my Philips DVD remote!
Remote codes
http://www.remotecentral.com/index.html
Mar 02, 2008 | Big Button TV Universal Remote
Remote Control Problem
take the batteries out of the Sharp remote press and hold the POWER button on the top of the remote for 5 seconds. Put batteries back in. Make sure that function is set to TV. Should work - if not call Sharp. If you are inside the original manufacturer warranty they will replace remote
Dec 21, 2007 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Remote Control Menu
acquire universal remote.
acquire exact replacement from mfg if avail.
no alternative if your remote is destroyed.
based on your need to access menus with it.
then hope your dog develops a taste for something else.
to that, my dogs chew bully sticks. it satisfies their need to chew. which is a really big drive. and they cost a bit, but last a long time.
and its cheaper than replacing remotes and furniture, shoes and other things.
and your dog will be extremely happy.
costc has started carrying them.
most pet stores carry them.
they are also known as pizzle.
you really don't want to know more about them.
they will keep your dog happy when otherwise bored.
good luck
have a happy dog.
mark
Dec 14, 2007 | LG 42LC2D 42 in. LCD HDTV
Tv is locked
I had the exact problem...tried a number of things that did not work. My dog "ate" my original remote. After reading your solution I took the universal remote that was programmed to work with the tv and tried holding down each button for a few seconds hoping that one would work like the display button on the original remote. It worked. I have a GE universal remote and the menu/info button worked for me. Again, you need to hold it in for a couple of seconds. Thanks for the help and I hope my added solution helps other people. Claudia in Minnesota
Feb 15, 2007 | Haier HTF20R21 20" TV
Open Questions:
Televison & Video Logo
Top Televison & Video Experts
