Question about Starbucks Saeco Italia Digital Barista Coffee Machine
Overheat? Machine has been great for over two years but now overheats easily, by which i mean that when i'm trying to steam milk i get a message to close the knob because the machine needs to prime, but even when i close the knob it's too hot for any water to come out so i have to shut everything down and wait for the machine to cool. I generally prime by releasing about 2 to 4 ounces of water but am now in the habit of priming with at least 8 oz though i have no reason to know if this helps. I also will pull my shot of espresso before steaming milk (even though i always used to steam my milk first) because the problem occurs with the higher temp of milk steaming; if i steam milk first and then run into a problem, the machine won't let me brew any shots. Any suggestions? Much appreciated.
  • 29 Answers
Typically it give the ventilate because insufficient amount of water/steam is comming through. A clog in one of the lines is usually the problem. This causes all kinds of headaches. There is nothing you can do so I suggest you do a search for an Authorized Saeco reapir center and have them do a service on it.
Posted on Aug 06, 2007
Water smell
You may have some residue inside the steam pipe from previous uses (e.g. milk). If you know how to remove the steam pipe, this will be easy to clean. Otherwise, you could try a pipe cleaner (depending on the type of steam wand).
You can also try running the steam pipe into some water, but be careful not to overheat the boiler (consult your manual... it may say you can't steam continuously for more than a minute, or even less).
Sep 24, 2013 | Nuova Simonelli Microbar Espresso Machine
Saeco Incanto Classic, the digital display is getting moisture inside??
I am on my third year. The valve for making steaming milk wears out every year ( I make about 4 capuccinos per day). Ouc local guy Heinz in Charlotte will take my steam valve apart once per year and replace O ring. Costs $25. He is great. If you dont do this is leaks steam and water into the circuit boards and kiss the machine good bye. I make this an annual trip. If the valve turns really easily this is a hint things are amiss.
Dec 02, 2010 | Saeco Incanto Classic Espresso Machine
Takes a long time to steam milk. water comes out of the brewing head while steaming milk
i'll preface this by saying i have never used a strarbux machine, but I have used dozens of others (daily habit for 18 years now)
when are you trying to get your steam (ie before or after brewing the espresso)
If you have been trying before, wait till after (if your machine does not let you turn off the espresso output then when the coffee starts to slow down (just past the peak of flow).
It should take only a few seconds to steam the milk. (also the closer to the surface of the milk that the steam is released the frothier the milk will get)
Nov 15, 2010 | Starbucks Coffee Makers & Espresso...
Jura capressa F7 steam milk problem
You should decalcify, when you steam the milk some what gets through to the steam and the build up of these minerals causes the issue
Aug 11, 2009 | Jura Capresso C1000 Espresso & Coffee...
Seaco Incanto not frothing milk properly
Hi
When was the last time you descaled the machine, and not with vinegar? Scale can accumulate inside the boilers and insulate the water from the heating elements, produce less steam. Descale on a regular basis.
May 12, 2009 | Saeco Magic De Luxe Espresso Machine
Not frothing milk
that means that the steamer is not generating enough pressure steam.
This happens either because there is not enough heat, or if you release the steam when pressure is not enough.
Very common problem with the american maid makers.
bear also in mind that Krups are not the best at frothing milk, and this is also a basic model.
If you want the best capuccino Coffee machine, buy the italian ones, Gaggia, Delonghi, Ariete etc. that are all great at this, or get a bigger Krups as a replacement like the Krups XP405040 that is also good at capuccino
May 09, 2009 | Krups XP7225 Espresso Machine
STEAM PROBLEM
Does the steam itself smell, or just the milk. If yes on the steam run the descale again. If no on steam then check the perfect cream wand the black plastic arm connected to the steam wand, dissamble and clean, make sure all the holes are clear.
Mar 26, 2009 | Gaggia Syncrony Logic 74884 Espresso...
Overheat cutout switch
The coffe maker has a heat fuse attached to the side of the pump so when over heats that melts and does not damage the coffee maker
They charge $100 to replace which is a bit tough, you could bypass easily but could damage the machine if not careful
as we have two and one has just stopped pumping, not picking up water so maybe worn valves and I just have it all to bits and noted the heat fuse on the side of the pump
Feb 10, 2008 | Saeco VIA Venezia
Saeco via venezia overheat cut out
Disconnect from the power and remove the 5 or 6 grub screws retaining the main steel cover and take the cover off. You will see a plastic re-set button on top of the boiler amongst the electrical terminals - just click it on again.
To stop overheating always open the steam valve immediately you switch the machine on until water squirts out - this tells you the boiler is full & not dry! Also remember (unlike me!) to switch the machine off as soon as you have finished brewing...
Bart42
Feb 10, 2008 | Elektra (SX) Espresso Machine & Coffee...
Steam wand used to make great foam until just a week ago
The stainless steel cover has a very small hole near the top. The hole allows a venturi action - meaning air molecules are entrained with the steam flow to increase the affect. Milk will clog the hole, but warm water and a guitar string, cheese wire, even a staple - something thin - will work to clean it out.
After frothing either clean the entire stainless steel piece or at least occlude the end at the same time as shooting through some steam. I usually use a kitchen sponge with the abrasive pad attached. The pad helps insulate the heat and provides the necessary resistance to force any milk out the small hole.
Yes, I hate living with this also. In fact I am considering machining a different steam tube assembly.
Red
Oct 05, 2007 | Saeco Incanto Rondo Fully Automatic Coffee...
Starbucks Saeco Italia Digital Barista Coffee Machine Logo
181 people viewed this question
Top Starbucks Coffee Makers & Espresso Machines Experts
Steve Allison
Steve Allison
Marvin
Marvin
eyecam
Are you a Starbucks Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
