Question about Connex 4600 Base CB Radio
Engien revs and lights dim when i key up
Galaxy dx949
when i key up only if my trucks running. my lights all dim, my voltage meeter drops from 14 to 12 all my lights dim and then when i let go of the key my engien revs about 500 rpm then drops back down to normal real quick like... wth!
  • Rob
    Rob May 11, 2010
    Y'all removed TR32, aren't y'all?
    Probably running one of those leenyers, too...
    Awww, Andy!
    Nip it in the bud.
    You're either running 100w+ power, or the RF interference when you key down is confusing the vehicle's computer, y'all.
  • s60six May 11, 2010
    does it have a built in kicker?
You don't say how much power you  are running, but it must be quite a bit, or you have an amp you're not telling us about.  By keying up the radio, you're putting enough load on your electrical system to pull the voltage down which causes you lights to dim, rpms to drop, etc.  When you key off, everything goes back to "normal" which means no load so the engine will surge momentarily before it recovers.  Depending on how many watts you are running, you may also be affecting the alternator regulator.  Your alternator may also be a little weak.
Posted on Jan 10, 2009
I have just bought my daughter a 1997 KJ Ford Laser and when she turns on the a/c the lights dim and revs drop and when you stop at lights etc the car idles very rough and then stalls. Anybody have any...
check voltage at the battery terminals while the engine is off, it should be around 12 VDC, then start the engine and check again, should be varied betwen 13 to 14 VDC, and turn the head light and A/C on and check to see if dropped bellow 12 that means alternator regulator is faulty. good luck
Jan 16, 2015 | Ford Cars & Trucks
Voltage drop. When in parked I rev up the engine, when it comes down, the voltage drops from 14 to 10, for about 5 secs. I think the truck will cut off but it immediately comes back up to 14.
If the alternator is weak, and you have accessories like the headlights or blower motor running, and the RPM drops below 600, the voltage could be below 12. It would depend on the load, RPM, and several other factors.
Feb 12, 2014 | 2000 GMC Yukon XL
89 Yamaha virago 750 while riding lights go dim and engine cuts out unless bike is revved up then engine runs and light come back (sometimes) what's the problem?
You have a charging fault, it sounds like 1 phase of your alternator is down , so giving a low charge rate check in this order.
alternator winding resistance at the plug/ skt into the regulator and,or reg/ rectifier unit
the plugs clean and connections good.
next the out put voltage which should be about 13-14 volts just above idle, lights off, rev engine up to 2-3 thousand revs voltage should be 14.5volts,turn on the lights voltage should not drop to under 13 volts with the engine above 2k rpm.
low charging rates are normally down to alternator and wiring issues not the regulator which if faulty wil give no out put , so no chage at all
Jan 14, 2014 | Motorcycles
Ignition key lights up but does not turn over
It's common for the battery to have enough voltage to make just about everything electrical on the car work, but not have enough power to crank the engine. I would check your battery first. When you try to start it, does the voltage drop below 12 volts? If so, you need a fresh battery. If you don't have access to a voltage meeter and your battery is more than 5 years old you can assume that you need to replace it.
Apr 21, 2013 | Volkswagen Polo Cars & Trucks
Galaxy DX949 cb radio with the 5 amp fuse (if I hook it up to the cig lighter) will it still blow?
if you have bought the cig light plug for that radio it shouldnt blow ade you having problems blowing fuses?
Mar 09, 2013 | Radio Communications
93 nissan pathfinder charging problems
check for voltage at the battery with the engine running. You should see 14 plus volts. Now turn on the lights, bower motor, and whatever else you can to put the maximum draw on the battery. If the voltage drops below 13 volts the alternator is bad.
Feb 03, 2012 | 1993 Nissan Pathfinder
Replaced starter, car started for 4 days. Fifth day car wouldn't start, just made a clicking noise. What could it be now?
If the lights are dim it is a battery problem. It might be a just dirty terminal or the connection on the starter is not good. Check the voltage of the battery with the lights on, should be 12 volts. If it drops when you try to start then it is faulty. The voltage when running should be 14 volts or more.
Nov 28, 2011 | 1999 Plymouth Breeze
Whenever i open my head light at night, the dashboard light gets dimmed. I can't see my speedometer.
Theres a control below the light switch that will brighten the dash lights when in dim
Jan 21, 2011 | Ford Taurus Cars & Trucks
Radio Communications Logo
136 people viewed this question
Top Connex Radio Communications Experts
AnyMHz.com
AnyMHz.com
Steve
Steve
Steve
Are you a Connex Radio Communication Expert? Answer questions, earn points and help others
