Question about RCA ION-ITTUSB05 Turntable
ION TTUSB05 no sound output from I Tunes
I have successfully installed the ION software and can hear tracks from the turntable through my PC's speakers. Tunes successfully download to ITunes but can get no playback. All other downloaded tunes on I Tunes play ok. I have checked the audio settings any suggestions?
I have a MAC OSX Version 10.4.11
Thanks
5 Suggested Answers
  • 13433 Answers
SOURCE: ION TTUSB05
I would suggest checking if there is a updated version of itunes available for you.
http://www.apple.com/itunes/download/
Atleast try reinstalling the program.
Let me know how that goes, and also are you using another program with the turntable?
Posted on Sep 10, 2008
SOURCE: I'm not getting sound with my Ion Turntable
Ater spending several hours trying to correct the problem I replaced the USB cord and it worked.
Thank you for your reply.
Posted on Oct 07, 2008
  • 366 Answers
SOURCE: ION TTUSB10 turntable plugged into Toshiba laptop,
Maybe the output is not good enough for line in on laptop try mic in, then double click the sound icon down bottom right where time is, goto options, properties, then recording inside of recording make sure all boxes are ticked so you have all options like mic wave stereo mix line and so on, click ok, now make sure what ever you have the turn tables pluged into is selected as your recording device and not muted try again, once this is all ok ., it should work. hope this helps. also make sure your software you use to record is also set up same. take care
Posted on Dec 03, 2009
Testimonial: "Thanks that solved it!"
  • 256 Answers
SOURCE: Sounds from turntable
There will be some feedback from the turntable, and this is totally normal. Ive actually heard the music from the needle itself, and is nothing to worry about
Posted on Aug 18, 2010
I can't hear the music as I record it with windows 7 ...I could with XP
hi,
Check the version of your windows 7. If it is 64bit then it will only support usb devices which can handle 64bit. Try with windows 7 with 32bit.
ok
May 16, 2011 | ION Audio TTUSB05 Turntable
My ion discover dj decks worked fine until i tried to use an external usb sound card alongside it for the headphones, now, even with the usb sound card removed,i am unable to have 2 of the audio outputs as...
i would do a uninstall of anything Made by ion and Re install and see if that solves your issue, Ion isnt a very good dj product so something as simples as this could screw something up. try a fresh install and please let me know what happens and ill assist you from there
May 15, 2011 | ION Audio Discover Dj Turntable
I've just bought a used Ion Audio TTUSB05 turnatable, I ve plugged it into my amp and it sounds terrible. There is a lot of noise before the needle hits the vinyl, presumably it needs earthing, when...
It will need earthing if you are getting hum. As it is used I would replace the entire cartridge and stylus with the best you can afford. Make certain you wire it up right. A good test is with the cartridge removed and your amp on, is to touch each wire (one at a time) with your finger. You should hear a buzz on two wires (one left one right) and nothing on the other two wires (earths). This will help you get the new one connected right.
Dec 01, 2010 | ION Audio TTUSB05 Turntable
I'm trying to hook up turntable to my laptop. I do not have the box, can I get a step by step hook up?
Hi, you want an rca to 3.5 mm stereo jack. Go into yur pc via the mic input. styluscity@gmail.com
Aug 31, 2010 | ION Audio TTUSB05 Turntable
Have linked it up to my normal surround hi fi system but no sound. No sound either when connected to my pc.
You asked this question in the TTUSB category. Do you have that turntable and how are you connecting it to the surround sound?
The turntable has a USB port and corresponding EZ Vinyl software that lets you monitor the output of the turntable. Then you can connect the computer sound card to speakers to hear what is playing.
Carl
Jan 08, 2010 | ION Audio iTTUSB Turntable
How can the pitch be adjusted on my TTUSB05 Ion Turntable? The recrods are playing just a little bit fast.
move the sliding fader toward the (-) or push the quarts lock button to be at 0%
Dec 06, 2009 | ION Audio iTTUSB Turntable
Downloaded songs appear in iTunes library but won't play on comp
I had exactly the same problem and followed the OP's solution, which worked, but I couldn't hear the track as it was being recorded.  So I tweaked the solution.  If you do the following, you don't have to keep changing System Preferences as you switch from record to listening:
Go to System Preferences, press the Sound icon, and click on "Sound Effects."  Then select the drop down menu and select "Play alerts and sound effects through selected sound output device" rather than the USB choice.  Then click on "Output" and select how you want to listen; I used speakers so I selected "Headphones" where the port is "Built-in audio."  Then click on "Input" and select the USB choice.  Now record a track and you can hear it being recorded through your speakers (or headphones).  When it's done recording and after the software transfers it to iTunes, you can play it again through your speakers without going to the preferences panel.
Dec 25, 2008 | ION Audio iTTUSB Turntable
Oct 06, 2008 | ION Audio iTTUSB Turntable
RCA ION-ITTUSB05 Turntable Logo
253 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
