Siempre aparece como apagada y esta instalada los drivers
Be sure that the device is ON
Set a wireless network
Click your Start Button
Select and click Control Panel
Select Network Connections
Select Wireless Network Connections
Right click
Select View Available Wireless Networks
5. Highlight the network you want to connect to
Click Advanced
6. Select the wireless network tab
7. Highlight the network in the available networks window
9. Click configure
9. IN the Properties Window
Double check the SSID (network name)
Enter the WEP KEY provided to you by the office
Click OK
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you need more help with this post a reply
hope this helps you
