Question about Brown Stove Works EM610 Electric Kitchen Range
2 burners get red hot no low control ??
  • 370 Answers
Change the burner 2 switches. if they dont turn down to low, then its the burner switch.
Posted on Nov 18, 2008
Left front range top burner temerture control issues
Good Morning Friend,
I understand that you are having trouble with the left front burner on your Frigidaire range, model# FEF355. I see that the burner heats up to a glowing red hot temperature, no matter what you set the dial to. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes.
When power is restored, the first thing you will need to do is set the clock. You will do this by pressing the "Clock" button, then within 5 seconds press and hold the up or down arrows until the correct time of day appears.
Once you have set the time, turn on the left front burner, on the lowest setting. If the burner is still glowing red hot, I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your range and determine what is causing the burner to glow red hot on all settings. Hope this is helpful.
-Best Regards-
May 15, 2014 | Frigidaire FEF355 Electric Kitchen Range
Troubleshooting electrical stove
Infinite switch, it's not cycling internal contacts are welded together, make sure control it's set on low, if the heat element. stays red hot, replace control (inf. switch).
Dec 23, 2009 | Kitchen Ranges
Stove burner gets red hot
Since you do not have a thermostat control on your burners, I would suspect you may have an infinite switch (burner control), that controls that particular burner, possibly starting to go bad. The thermostat control is located on the infinite switch itself and may be cycling on and off improperly. Its hard to tell with intermittent problems, however. If in doubt, you can do a comparison between a working 8" inch burner and the one you are having problems with.
Another thing to consider with these coil type plug in burners, the receptacles under the cook top that they plug into can gradually become loose over time and cause the burners to arc. This may also cause excess current flow through the burner and will eventually cause burner coil damage and/or receptacle failure. I would troubleshoot this by, first, by unplugging the appliance and inspecting all the burner receptacles. If any show signs of burning or melting, replace them. You will need to lift the cook top to access them. Locate the screws under the bottom front edge of the cook top (open the oven door to see them) and remove them. With the screws removed, the cook top will lift up. Prop in place using the hinge supports.
NOTE: Remove the burner coils and bowls before lifting the cook top.
Replacements parts (including burner receptacles) can be purchased at,,, or
If you have any questions, please let me know. I hope this helps you.
Aug 02, 2009 | Kitchen Ranges
Element does doesn't switch off.
What your going to have to do is replace the infinate control for that burner. ( thats the control you turn to sw it from high to low heat )
good luck
Jan 07, 2009 | Kenmore 96212 / 96214 / 96219 Electric...
Burners of electric cooktop not getting red hot
Sounds like you have a bad surface heat controller.
Nothing to do but call a hands on tech to replace a part.
please remember to leave a rating before you sign off
Dec 11, 2008 | GE 30 in. JP340 Electric Cooktop
Is the little center post of the removable frame over your burners in the little notch where it is supposed to rest?
Aug 18, 2008 | Bosch 30 in. NGP 732 / 736 Gas Cooktop
Red out of whack
Jan 04, 2008 | JVC AV-56WP74 56" Rear Projection...
I have never use with computer. have connected to VCR and small television, and copy direct from vcr to VRDVC20 and have had no problems. I do have the soft ware disc, as bought mine new and have used only to copy video to CD and if follow directions exact, the will finalize - no problems.
Dec 01, 2007 | Sony DVDirect (VRDVC20) DVD±RW Dual...
Brown Stove Works EM610 Electric Kitchen Range Logo
200 people viewed this question
Top Brown Stove Works Kitchen Ranges Experts
Justin Duby
Justin Duby
Dan Webster
Dan Webster
Are you a Brown Stove Works Kitchen Range Expert? Answer questions, earn points and help others
