Zenith z56dc1d dlp lamp timer reset procedure
  • Anonymous May 06, 2009
    zenith 42" DLP TV. takes 30 - 40 seconds for picture to show up. Shows " replace lamp" Ordered & replaced lamp- doing same thing.
    Talked to Zenith & was told to reset timer, by pushing e"enter" on TV
    & mute on remote control but the timer "box" did not show up.
Hold them both until the box appears. It works
Posted on Aug 21, 2009
Tip
Procedure to reset Panasonic TVs
If you have replaced the lamp in your Panasonic DLP TV and are having problems such as a message on the screen telling you to reset the lamp timer or the unit not powering up, you probably need to reset the lamp counter. All DLP and LCD TVs which have high intensity lamps generally need to have a lamp timer circuit reset after a lamp change. The manufacturers want to give you a heads up prior to having a catastrophic event such as a lamp exploding which could cause a fire as well as other damage.
Therefore in many cases until you reset the lamp timer the unit will not operate or it will keep reminding you to reset the lamp timer which is very obnoxious. This is not a hard procedure but you will need the original factory remote to accomplish the task. Generally the procedure involves pushing a sequence of buttons.
I recommend placing a piece of masking tape on the rear of the TV with the date the lamp was changed to make it easy to remember when the next lamp change will be necessary. Also you could purchase a lamp now to avoid paying more in the future.
The following procedure should solve your problem:
1. Turn on the television.
2. Press the down button on the TV display (not the remote)
3. While pressing the volume button, press the "split" or "PIP" button on the remote.
This should reset your lamp timer.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank You.
hardrocko
on Oct 28, 2010 | Televison & Video
Zenith z56dc1d dlp tv picture works for about 1 minute then starts shaking and tv shuts off
You may want to get it in a rather warm room and or remove rear cover and use a hairdryer to warm everything up inside the Cabinet--with rear cover off look to see if the fans are dirty etc and if they all come on, if a DLP especially look at the lamp itself and the fan that cools it.
Dec 18, 2012 | Zenith Televison & Video
Zenith z56dc1d stays on standby mode after replacing dlp lamp
If problem is different from before lamp replaced remove the lamp and make sure the pins it engages on are not bent out of position--it is possible to insert the lamp and not get it in correctly.
If Zenith it was made for or by LG>
Jun 01, 2012 | Televison & Video
I need step by step instructions how to in stall lamp for my zenith z56dc1d
The steps are :-
1.
2.
3.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Feb 12, 2011 | Zenith Z56DC1D 56" Television
The tv won't come on. the bottom red light flashes twice
YOUR tv does look like a dlp if it is ? then you need to start with lamp. if you replace lamp and clean vents and that don't help. then you need an electronic technition to determin whats causing your problem. J.D.W.
Jun 25, 2010 | Zenith Z56DC1D 56" Television
How to replace lamp on Z56DC1D 56 inch television
as a tip Get it done professionally It is not just a matter of popping onhe out and another in. tHThe lamp has to be set up correctly and the hours reset on screen and at the lamp site as well on many models. Many on here have done the DIY option and found they have halos around the objects on the screnn, the lamp blew in 10 mis after installation and many other problems of not being able to set the lamp hours despite it seemingly being easy from the menu.
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Zenith Z56DC1D 56" Television
How to reset the change lamp notice
You would need to contact LG to have them refer a Service Facility to bring a Service Remote Control out to reset it. I do not know of any way else to do it.
I hope this helps,
Skyassoc
Aug 28, 2009 | Zenith Z56DC1D 56" Television
Zenith 56" DLP Z56DC1D won't turn on
Replace Lamp and CK both Fans to make sure they are running.If Fan behind Lamp does not run TV will not light LAMP.
Jul 20, 2009 | Zenith Z56DC1D 56" Television
Televison & Video Logo
853 people viewed this question
Top Televison & Video Experts
