Question about 791XV The 791XV is a 2-way Security and Remote Start system. Th
Viper programming hi i got a 2006 scion tc with a viper alarm installed in it. i got a new remote for it but it came with no insrutions on how to program it. its a 488 vpx 3002 model # is there any way you can help? thanks alex
  • Murrey Hall Feb 14, 2009
    i just bought a used vehicle with a older viper remote. the van quits after running about 30 seconds...
  • 905 Answers
SOURCE: got a new remote for my viper 791XZ and reprogrammed it .
this usually means that the remote did not recieve a signal back from the module or the module did not recieve the remote signal
have you tried repeatively to press the unlock button? does the remote starter work or aux( trunk ) ?
also when putting the battery in the remote , be easy because there is a connector plug soldered on the board real close to where the battery is , and if it is hit by the battery hard enough it will cause those solder connections to disconnect and you will get the beeps and or other malfunctions
Posted on Feb 03, 2009
  • 53 Answers
SOURCE: Viper 5701 remote programming
1st you need to enter the remote into progamming Hold the Function button until the remote gives a long beep and LED light comes on the remote a (it takes about 8 sec.) Then press and hold the remote start buttom until the remote beeps 3 times and LED lights up. Now your ready to program the remote
One of the door has to be open . Insert the key - turn the key to the On position then press the button on the antenna once and then press it again and hold it
You hear a chirp and then you press the lock button on the remote and then you hear a second chirp to recieve confirmation and then release the button and the turn off the key .
Remote should be program
Posted on Jul 12, 2009
  • 69 Answers
SOURCE: how do is program a viper alarm and remote starer
first you will need to locate your valet switch/button, which will be a black push button located somewhere under the driver side dash.
Open a Door,
Turn your key to ON position,
within 5 seconds of turning your key to the ON spot,
press and release the program button 1 time, then press it a 2nd time and hold it this time
the L.E.D will flash one time and then you will hear a chirp,
while still holding the valet switch, press the lock button on your new remote. you should hear a single chirp.
After chirp you can release the program button and turn the key to off.
you should hear a long chirp when the alarm exits the programming
try the remote
if the remote functions don't work properly, you can always try a different # pattern.
ex: press 2 times and hold on the 3rd, press 3 times and hold on the 4th.
Posted on Aug 18, 2009
  • 171 Answers
SOURCE: disable viper alarm
Yes the best way is disarm the alarm and put in a Valet Mode
To activate the Valet Mode do the following:
There is a push button or toggle switch to disable the alarm (to engage the valet mode). Without knowing where this
switch is you won't be able to disconnect the alarm.
1. Put the key in the ignition and turn it to the "on" position.
2. Flip the toggle or hold the push button for at least 5 seconds.
3. The LED. light will stay solid on.
4. Turn the ignition off
5. Release the push button. If you have a toggle leave it alone in step 2
Posted on Jan 08, 2010
  • 132 Answers
SOURCE: how to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
Posted on Apr 04, 2010
Remote starter only allows my starter to turn over twice; needs at least 3 with my key. How to adjust to have it starter run longer on remote?
I know you are looking to have the remote starter run a third time but I would say you need to look at your Fuel Pressure Regulator on the Scion. Sounds like it is not holding fuel pressure at the fuel rail and that is why it requires a third Crank
Jan 05, 2016 | 2006 Scion xB
I have scion tc 2005, I've let them scan the car and they told me that the engine immobilizer system malfunction
well scion tells you up front to check with the manufacture before installing any devices so you might be out of luck on this one
Sep 11, 2012 | 2005 Scion tC
I lost my remote for my viper 350 hv,and when i used my key to open the door the alarm went off,and disconnect the viper box,and bought a new remote,and when im trying to program my new remote and plug my...
You have to turn your ignition on and press the valet button switch, to turn off the alarm. Then, you have to use that same valet button to learn the remote to your alarm, following the steps in the installation manual.
Sep 20, 2009 | Viper Security and Remote Start System...
How to reprogram Karr alarm in Scion tc?
dealer only or wouldnt be any good as an alarm if any tom **** or harry can do it ,Try disconnecting the battery and holding the leads together for a minute then reconnect the battery
Aug 12, 2009 | 2006 Scion tC
The alarm does not beep when remote is pressed scion tc 2006
Hold down the lock button for about 5-10 seconds
May 10, 2009 | 2007 Scion tC Coupe
I had a viper 5701 responder LE 2 way system installed on my 2006 dodge Dakota, everything works fine but my headlights and parks lights stay on constant while in remote operation and my park lights do...
If your vehicle has daytime running lights they will be on when remote started no real way around that try leaving your parking brake on.
The new vipers default setting is constant rather than flashing.
Dec 17, 2008 | 5701 VIPER 5701 2-WAY ALARM w/REMOTE START
791XV The  791XV is a 2-way Security and Remote Start system. Th Logo
415 people viewed this question
Top Viper Vehicle Parts & Accessories Experts
Kevin Daniels
oneStan
oneStan
jason
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
