Question about Lands Phones
INTEROME My intercom button will not turn off, and therefore i can not make out going calls. I get no phone dial, however sometimes the speaker phone works.How do i fix it?
  • 1 more comment
  • afarhat25 Nov 18, 2008
    help
  • afarhat25 Nov 19, 2008
    I have the G.E 4 line Business Telephone 9451.
    Its not stuck, how do i fix the hang up clicker?
What phone or phone system do you have?
Posted on Nov 19, 2008
  • Anonymous Nov 19, 2008
    Could the button be stuck? When you hang up the handste, does it shut the intoercom off? It could be the hangup clicker.
    That I do not know. You would have to pull the phone apart and see, there should be a small plastic rod that is not connected, if that is the problem.
Lightning storm and my office phones are all stuck on pulse dialing.. I was told awhile back to do the following..speaker, intercom, *0, dial 1, conference, dial 7 press line buttons dial 1..this is n
May be you Have to replace all phone
Try with a New Phone .If it works on all Locations
then replace all OR Else call the Intercom Technician to fix the problem
Nov 24, 2014 | Lands Phones
M7310 Non-Stop Dial Tone
Intercom button/s provide dial tone when they are pressed. They are required to call other phones on your system.
Sounds like your button is stuck or issue with the motherboard.
Dec 17, 2012 | NorStar Meridian M7310 Phone
How to remove FWD/DND FROM A PANASONIC KX-T7030X PHONE
Press intercom button
dial *71
choose the call forwarding type to cancel as follows
dial 0 for internal and external calls
dial 1 for external calls only
dial 2 for internal calls only
dial 0 to cancel call forwarding
press speaker to end
Jan 18, 2011 | Panasonic KX-T7730 Corded Phone
If you want to "make an announcement" using speaker phone using intercom, how do you do it
When you intercom the extension, insert a STAR ("*") before the extension number.
EX:
Dial intercom 12, will ring 12.
Dial intercom*12, will page the phone and go straight to speakerphone.
IF the far end user has their "MIC/HFAI" button lit, they will need to do nothing, they can just talk.
IF not, they will need to lift the handset, OR, press the "MIC/HFAI" button, to be head.
Oct 05, 2010 | Lucent PARTNER18 Corded Phone
I can't make a call or receive calls, I tried unplugging it several times and all the lights starts blinking!! When I try to dial a button, it gives me a busy signal.
You are probably trying to dial out on an intercom button. This will give you a busy every time. You may have to dial 9 to get out.
To test your phone, 1st find out what your intercom number is (press feature*0 and then press the intercom button) Your display will show you the intercom number of your telephone. Then try to make an in house intercom call to another working telephone. If that works have them call you back.
The next step is to find out if you have any lines programmed to your phone. (press "feature*0) and then each button on your phone. The display will show you what is programmed on that button. If you have any that say "001 Line001" or such those are the outside lines to dial out on. Hope this helps.
Bill C. www.dyna-tech.us We provide remote programming and tech support for Norstar CICS MICS and Call pilot 100/150.
Mar 11, 2010 | NorStar M7310 Corded Phone
Intercom use
We have the 25414RE, so I can tell you how ours works and hope it helps solve your problem...
You first have to assign each phone a "number". Push the menu button, and go to phone options (you scroll by pushing the review button to the left or right), choose set phone id (once you are on that option push the select/save button just above the review button) - I started with the first phone I plugged in and made it number one, and so on (we have a total of 5). Once the phone ids are established, simply push the intercom button and the corresponding number on the right speed dial/intercom numbers - it should dial the phone you want. It also has an option (again we have the 25414RE) to have the phone auto answer the intercom - so if you are paging someone in a room that isn't near the phone, or the phone is shared by several users, it picks up without anyone having to push anything. Otherwise, the phone that you are calling has to either have the handset picked up or the speaker button pushed. Hope that helps you!!
Mar 10, 2009 | RCA 25404RE3 Corded Phone
How do I retrieve messages on the Panasonic KX-T7030 phone?
  • Call into your mailbox (usually by dialing intercom 165)
  • Press 4, and 4 again (for "Incomplete call handling")
    By default, three options are enabled:
    option #1: leave a message
    options #5: call the operator
    option #6: return to top menu
  • Follow the audible prompts to disable options 5 and 6
Here are some other features you may need
  • Make sure your Auto Answer button is lit up, so you can receive intercom announcements, and respond hands-free.
  • Use the Call Forwarding (FWD) to send un-answered calls to another phone or to voicemail
  • Press BGM (or 1 on the touch-tone pad) for background music, if your system is equipped.
  • Use Absent Messages to show text messages on other people's phones when you are away.
  • Use System Call Waiting so your phone will ring even when you're on the phone. Press Intercom and dial 7311 to set it up, or 7310 to cancel.
  • Use Do Not Disturb (DND) when you don't want to receive calls. Press Intercom, press FWD/DND and dial 1 to activate, or 0 to cancel.
  • Press MESSAGE when you call a busy intercom number. This will turn on the MESSAGE light on the other phone, and the other person can tap that button to automatically call you back.
  • If you get a busy signal when you call an intercom number, you can signal the other person by dialing 1 (if that phone is programmed for System Call Waiting (above).
  • Dial 330 to make an announcement to all phones.
  • If you want your phone to automatically select an outside line when you pick up the handset, press PROGRAM, dial 99, dial 12, press STORE, press PROGRAM
  • Feb 12, 2009 | Panasonic KX-T7030 Corded Phone
    Calls go straight to voicemail
    Your phone is fowarded to Voice Mail and do not disturb is on. Turn DND button off. If it is not the case on your phone press intercom # key 601 then hang up. Then do intercom #key 604, dial your voice mail extension numbe, r press the speed dial Select button, dial 16, press the redial button then hang up.
    Dec 11, 2008 | Toshiba DKT-2020 Corded Phone
    Blocked Intercom
    If you do not have a button to press to call him, you must press the intercom btn and dial his intercom # . to find his intercom # , go to his phone and dial feature 00. His intercom # will be displayed. press feature 00 to exit.
    Mar 06, 2008 | Lands Phones
    Lands Phones Logo
    127 people viewed this question
    Top Lands Phones Experts
    Are you a Lands Phone Expert? Answer questions, earn points and help others
