Question about Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook
Turning on my macbook- all i see is white screen and 'no' sign
When I turn on my Macbook, it makes the start up noise but all that appears is a blank white screen with the gray apple on it. After about a minute or so, the apple then turns into one of those symbols with the circle and diagonal line through it. I don't know what to do! What happened before this was I was at school and my computer died. I got home and tried to turn it on and this was what happened!! HELP!
  • Anonymous Dec 03, 2008
    MINE DID THE SAME THING when i was at school!!
  • 11 Answers
Apple has a troubleshooting document about this here:
Normal procedure is to reset the NVRAM and PRAM then "remind" your Mac where to find the system folder. (This problem sometimes happens when the system folder is moved, renamed or deleted.)
It may be necessary to reinstall the operating system. (Fortunately, if you use the "archive and install" option, you can do this without erasing the hard drive or losing your user data.)
Posted on Nov 19, 2008
  • 3 Answers
Well the only solution for this problem is to not have a mac. I recommend crossing over to the linux side. or even just buy a windows operating system laptop. They are much cheaper than mac.
Posted on Nov 20, 2008
White screen of death on Macbook 13". when turning
You may need to reset the PRAM.
Start your computer and hold down the option, command (apple), P and R keys simultaneously until you hear the second chime. Then release.
This will reset the perimeter RAM (PRAM) and may allow your system to start, which it will do immediately if it capable.
If this is not the case and you have already tried removing the RAM and the HD, you may need to have the motherboard tested.
Oct 31, 2010 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Won't turn on
The problem in blank white screen is the display (LCD). Send it to a technician for repair. The blinking folder with a question mark is conflict on drivers. Have you installed a software lately? If you do please uninstall it. Maybe that is the cause of having a blank white screen.
Jul 12, 2010 | Apple MacBook Pro PC Notebook
When I turn my MacBook air on a blank White screen
Leave the Macbook air turned on until the battery goes dead. Then Connect to power and start it up. That should solve the problem. You problem was caused by not letting an update install in full.
Dec 16, 2009 | Apple MacBook Air
Help! I dropped a tv onto my macbook pro 2 ghz c2d three days ago and it worked fine until last night when a strange, matrix like green half image started flashing on the screen. I rebooted and now the...
Twist the Macbook body while turning it on. If that make the image come back, you have a broken logic board. There are Mac Repair Guides that show how to open a Macbook. Watch out for the ribbon cables, those tear easily. Replacement parts are usually available on Ebay. There are third party services that can do it for you, like Mac Repair NYC.
Dec 04, 2009 | Apple MacBook Pro Notebook
When start up the screen is blank, nothing happens
Press the F2 key several times to make sure that the screen brightness is up.
Put your ear down on the laptop on the zone left of the trackpad and below the keyboard and listen for the little whirring and clicking noises of the hard drive. If it is making noises, just walk away for at least 30 minutes and see what happens in that interval.
Look carefully at the screen in good light and make certain that here is no image on it. You could just have a bad backlight.
If so, you can connect the DVI port on the MacBook to a computer monitor or most flatscreen TVs and regain access to the screen until you get the backlight repaired.
You might try that regardless. Even if your display is totally inoperative, the DVI port may still function.
If the drive has stopped making noise and the screen is totally blank, 1. Try starting up the MacBook with the DVD that came with it, and if that doesn't yield anything, 2. Take the MacBook to the Apple Store and ask for a Genius appointment.
Oct 16, 2009 | Apple Computers & Internet
Macbook won't start!
that normally happend when the macbook do not find the software you can read this apple post
Jun 24, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Boot macbook problem
Parallels won't have caused this, Bootxchanger might have but it's not likely. More likely is that you HD is faulty.
A largish number of white Macbooks shipped with faulty Seagate HD which, although fine to start with, started failing after about 1 year of use.
I've seen 3 in the last six months.
Thankfully the HDs in these MacBooks can be changed in just a couple of minutes, the bad news is that the data on the drive is generallycompletely destroyed.
Try starting up from your install DVD, but not do the install. After you get asked about language, at the next screen, go up to the menu bar and locate disk first aid. Run that - you may be lucky and it fixes it or you may not.
Apr 28, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Unable to start....
your hard drive has prolly crashed, same thing happened to my buddies macbook. when he turned it on, it went to a blank screen.  Im sorry  but hopefully you still have a warranty on it bc it was 300 $ for a new hard drive that my buddy got.  take it in to apple and have them look at it.
Nov 17, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Macbook - screen white/blank after turning on
Sounds like it could be a corrupted OS; have you tried forcing it to start up with the OS disk, holding down the 'C' key? That's the first place to start...
If it won't start up like that, you probably have a hardware problem. (You can get excellent troubleshooting guidance at: ) depending on your level of geekness, and assuming the warranty is expired?
Good luck
Oct 05, 2008 | Apple MacBook Pro PC Notebook
Itunes is very tricky and its freezes computers very badly.try to take out battery and than turn on computer slowly,Soon if you can you need to reinstall itunes maybe to start to work better.
Jun 04, 2008 | Apple MacBook 13"White /2.0Ghz Intel Core2...
Apple MacBook 13"White /2.0Ghz Intel Core2 Duo White/2GB (2x1gb)/80GB/SuperDrive (Z0DT) Mac Notebook Logo
3,524 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
