Question about Panasonic PT-47WX51 47" Rear Projection Television
BROKEN MIRROR The mirror inside my panasonicPT-47WX51CE is broken, do u think can i change it?
  • 905 Answers
Yes , if you call panasonic to get the replacement , you should be able to change it
electech
Posted on Nov 17, 2008
How do i remove my rearview mirror w/temp & comp.
because the plastic inside has probley broken causing it to move freely.
Feb 03, 2013 | 1998 Mercury Mountaineer
Replacing a brokem mirror on a 1996 chrysler town
directly behind the mirror on the inside of the door there will be a plastic triangular shaped cover
gently remove the cover using your fingers or something flat like a knife blade
once removed you will see a few holes in the metal of the door, in these holes you will see about 3 bolt heads which hold the mirror to the door, also you will see a multi wire block for the mirror wiring
seperate the wiring block and remove the 3 bolts holding the mirror to the door
don't even think about replacing the glass if that is all that is broken as it is a major drama
just buy a complete mirror assembly and fit to the door unless it is colour coded to the paint on the car in which case you will have to have it painted
re assemble in reverse order to disassembly
hope this helps
Jul 02, 2010 | 2006 Chrysler Town & Country
How can I remove and replace broken door mirrors? My body man and I cannot remove the broken door mirrors to replace them with good mirrors.
the plastic on the base of the mirror pulls off and you will find two screws undo them and thats it no need to take off the door panel inside
Jun 03, 2010 | 1996 Suzuki X-90
I've got a broken driver side rear view mirror on a 1990 Buick Century. I've got the replacement mirror, I just need help getting the old mirror off the door. Suggestions?
This is what you do take the door skin off of the inside of the door and at the top corner there will be i think three nuts and than your going to need door clips after your done in order to put the door panal back on
Apr 07, 2010 | 1990 Buick Century
How do i change a mirror light on a navigator?
Is it a normal globe inside or one of those LED lamps? If it is a globe it should be replacable if not then I would think that the replacement of the whole mirror would be the only thing you could do (Not sure if they sell the lamp seperate). Hope this is helpful
Sep 19, 2009 | 2003 Lincoln Navigator
Mirror glass broken 94 ford tarus driver side
That is not a Question but if you want to know what to do with your broken mirror. replace the mirror . it may be accessable by a plastic panal on the backside of the mirror on the inside of door by the window.under this panal their should be bolts or screws remove them and the mirror will come off.replace bolts or screws with new mirror.replace plastic panel.
Apr 26, 2009 | Ford Taurus Cars & Trucks
Side mirror inside glass hanging ford explorer
it depends on whats 'hanging', if JUST the mirror glass has come off it's plastic backing plate, then yes you can silicone it back into place. If the mirror glass AND the plastic backing plate are hanging, you can try to 'snap' the backing plate back into the mirror head but most likely something inside is broken and the mirror head will have to be replaced. for a better idea on reinstalling or replacing a mirror see: www.burcinc.com and for aftermarket replacement mirror heads see: www.directauto.com
hope this helps.
Feb 16, 2009 | 2005 Ford Explorer
How to replace broken mirror
Remove the door panel, then remove the speaker inside the door opposite the mirror itself.Then it is usually an allen key bolt or 3 depending on the year. It will come off as one big unit.
Jul 28, 2008 | 1999 Volkswagen Golf
MY JVC HD56G786 TV
If the Mirror broke while the TV was sitting upright, the pieces of glass got down inside the light engine and the cooling fans. I don't think you took the light engine apart to clean out all of the glass so the main cooling fan is probably not running and causing the warning. There is no sensor for the mirror. Did you remove the chassis to clean the glass? You cna remove it again and try powering it up out of the cabinet. There are four fans that need to be running. If the light engine is filled with glass the fan at the bottom of the air exhaust will not turn.
I am fairly certain that since the TV was discarded there is more wrong with it than a broken mirror.
Jan 22, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Broken Mirror
you need to see if the lens where the light comes out is scratched..
if it is then the picture will never be right until you replace it..as for a cheap replacement mirror the picture might be watchable if it is a good quality mirror
Aug 01, 2007 | Samsung HL-S6187W 61 in. HDTV
Panasonic PT-47WX51 47" Rear Projection Television Logo
70 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
