Question about Nvidia TNT2 M64 16MB PCI Video Card Graphic Card
Can't get driver to load/card won't work
Machine is running win98SE I installed card, went to bios and set it to display pci first. Had forceware 81.98 on desktop to load. During setup it says "no nvidia chip found on this system" and setup fails. In my Aida program (component id) it says this card is Nvidia Riva tnt2 m64 pci........ So I downloaded riva driver from nvidia site that says it's for all OS. It won't install either. Am I doing something wrong in install, is the card bad, or could it just be incompatible?
    Problem Solver:
  • 28 Answers
I did a little research for you and found you are not alone in having this problem. It appears this issue arises from the use of the newer drivers. Try an older version driver, making sure to first remove the previously installed driver, until you find one that works. Here is a link i found where the user reports success. Windows 9x/Me: ftp://download.nvidia.com/Windows/45.23/4...n9x_english.exe And finally, from http://forum.worldwindcentral.com/showthread.php?t=2503&page=2 , a user reports this (for WinXP): "I was able to download a driver for the NVidia TNT2 from the NVIDIA website, but you have to go to the frequently asked questions (FAQ) section to get the link to the driver that works for the TNT2. Here is the link: http://www.nvidia.com/object/winxp_2k_66.93.html The driver is from November 1994. It will, among other things, provide a host of resolutions, including the previously un-available 1068 x 1050 required for 22" widescreen monitors. Hope this helps. Good luck!" Good Luck!
Posted on Dec 05, 2006
How do i install windows 7 64 drivers for NVIDIA Quadro NVS 280 PCI
Go to www.nvidia.com....click support....drivers....and you card model. Download relative driver and install
Jun 22, 2016 | PNY NVIDIA Quadro NVS 280 - Graphics...
HP d530 sff with XP won't boot with NVS400 PCI card installed
display first going to your Nvidia card which is i think is faulty, however if you still want to attach it , change the bios setting, display first to onboard instead of pci
Jan 30, 2013 | Nvidia Computers & Internet
I am trying to install a pcie-x1 video card on a ibm eserver x206m i salvaged from work. I am running windows 7 64bit . I have tried to turn off on board graphics so that it takes the video card i just...
I know this is really old, but I had the same problem on my 206m 8584 with a pci-e x1 video card. I had to upgrade bios first, but nothing seemed to change, bios only showed onboard video as option and windows perfectly recognized the exta card. I went to windows video settings, it showed both video, onboard as main and active and extra as inactive, changed the second video to main and active and switched the plug to finally see my enhanced video. Only problem is that bios screen won't show up on pci-e card, so I start seeing something only after one minute :) Hopes this saves someone else some time.
Nov 03, 2010 | IBM eServer xSeries x206m
Sapphire HD2400 PRO 512M - Doesn't seems to be working
For windows to work, it needs the card's drivers to display properly. The bios will display, and the beginning of windows load messages will show, but then it switches to the installed display driver. Take the card out, and use the old display method, and load the drivers for the new card. Then set the screen resolution to 800x600 and the shutdown, and install the new card. The bootup should go correctly, and once the new drivers are in, then set the resolution desired.
Oct 14, 2009 | Computers & Internet
I can't install the Display Card most recent driver!
That happened to me before if you dont get any solutions the only thing i suggest is to download Forceware which is a driver which will work but is not driver signed.
Apr 20, 2009 | Computers & Internet
System does not see new video card
Confirm the card works in another system to eliminate it as a suspect. Try a beefier power supply in the machine (sometimes these 300 to 350 watt supplies just cant hang when an addon card is installed). Check the BIOS settings and make sure that the PCI Express slot resources are active for the card. If the card uses a power connector, make sure it is connected. Keep us posted.
Mar 21, 2009 | Gateway GM4019E PC Desktop
9600GT No Display
Have you put another power cable to the back of the Video card. There is a slot on the back of the GT for more power. Once that is plugged in beeps will stop and you should recieve signal
Feb 09, 2009 | ASUS PCI EXPRESS 2.0 GEFORCE 9600GT 512M...
GeForce4 MX 420 Video Card
First question: Are you sure you have a PCI card?
there are several points here:
Make sure you have the monitor connected to the correct output on your computer. (In this case to the output of the graphics card, not to your onboard output)
If you have a PCI card set bios to PCI
Setting it to AGP means the computer is looking for a graphics card in you AGP-slot on you motherboard.
I cannot help thinking, that you actually have a AGP card in a AGP slot and that you computer is not working on onboard, but on AGP. But you can check which graphics device is used, in display properties (right-click Desktop, Properties, Settings)
Please post some feedback
Apr 04, 2008 | VIA P4MA Pro Motherboard
Video graphics card
being a PCI card, not a AGP or PCI-E the system may not simply switch to that one a primary display adapter when you install it, in the bios under advanced system settings or intergrated periferals, you should have an option to change the primary display adapter, make sure a PCI adapter is included.. if it isnt, chage it to recognise a PCI card as a primary adapter, turn the system off, and install your card then, depending on the bios/model of the mainboard on some of those dells, it may be a little hard to find, ive had to play with a few of them
Nov 24, 2007 | Dell Dimension 2400 PC Desktop
Nvidia TNT2 M64 16MB PCI Video Card Graphic Card Logo
142 people viewed this question
Top Nvidia Computers & Internet Experts
Terry
David
David
Are you a Nvidia Computer and Internet Expert? Answer questions, earn points and help others
