Question about Eclipse 5440
Eclipse CD8445 Clock Problems
I have an Eclipse CD8445. And everytime I set the clock then turn my car off 4 a short period of time it resets to 12 O clock. What can I do?
    Problem Solver:
  • 15 Answers
If you lose your preset stations as well, it means that your memory wire (sometimes yellow sometimes red) is not hooked to a constant power source. Get a testlight and find a wire in where the radio is at that has constant power once you find that attach the memory wire.
Posted on Nov 28, 2008
Need to reset atomic clock to Virginia time zone; now 4 hours ahead
To set up your clock simply install one fresh AA, LR6 ALKALINE battery. Due to the nature of long wave radio signals it is normally not possible to receive a signal during the day so it is best to install the battery late in the evening. Select your time zone by pressing one of the four time zone buttons PT-Pacific Time, MT-Mountain Time, CT-Central Time, ET-Eastern Time. The time zone buttons may be pressed any time after installing the batteries. If multiple buttons are pressed the clock will set to the time zone selected last. If no time zone is selected the clock will default to Pacific Time. Another time zone can be selected during or after the clock has set itself. Your clock can only set itself to one of the four time zones stated above. For time zones outside of PT, MT, CT or ET you must manually set the time using the Manual Time set button on the back of the movement.
When the battery is installed the second hand will advance eight seconds (two seconds per step x four steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each
hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
May 31, 2012 | La Crosse Radio Controlled Atomic Clock
I got a chevy equinox 2006 everytime I start it the clock resets to 12? What is the problem?
the clock must supply directly from the battery , if no anytime when you switch on and of the clock come back to 12 and lose the memory.Is not difficult but need time to find the wire from clock and connect to an permanent 12 volt supply somewhere on the board , consumption is very small few miliamps.
May 08, 2011 | Chevrolet Equinox Cars & Trucks
I have model cd 3424 and cant set clock
This was taken from a radio similar to yours. Same brand but different model. Hopefully it'll help.
(Also the "SEL" button it talks about is a big round button/knob on the right of the unit.)
Setting the Time
This receiver uses the 12-hour display notation.
1 Turn [SEL] button to select CLOCK ADJ.
2 Press the [SEL] button.
The clock adjustment mode is activated.
3 Turn [SEL] button to display the item to be selected for
adjustment.
Hours, minutes or exact hour will be switched each time the
button is turned.
4 Press the [SEEK / FAST] button.
[SEEK] button: Turns the time forward.
[FAST] button: Turns the time back.
To set the clock to 0 minutes, 0 seconds (an exact hour),
press the [SEEK / FAST] button.
For example:
At 3:29: Pressing the [SEEK / FAST] button returns to 3:00.
At 3:30: Pressing the [SEEK / FAST] button advances to 4:00.
5 Press the [RTN] button.
At this time, other adjustments can also be made in
Function Mode.
6 Press the [FUNC] button to exit Function Mode.
Mar 02, 2011 | Eclipse CD3422 CD Player
It looses time and the radio controlled feature does not bring it back to the correct time. I put in a new battery and it still happens. It is a La Crosse Technology Radio Controlled clock Model:WT-3101
When the battery is installed the second hand will advance eight seconds (2 seconds per step x 4 steps). The clock is now searching for a signal. For the initial setting it is recommended to stand the clock in an upright position near a window. Within five minutes the clock will either receive the WWVB signal and set itself to the exact time, or it will determine that the signal is not receivable at its current location and time of day. If a signal is not receivable it will fast-forward the hands to the 4, 8, or 12 o'clock position and search for WWVB each hour until a signal is received. If the time is manually set the clock will continue to periodically search for a signal and automatically reset the hands when the signal is received.
Jan 24, 2011 | La Crosse Radio Controlled Atomic Clock
How to set clock on clarion drx7375
Setting the clock
1. Press and hold ADJ button 4 for 1 second or
longer to switch to the adjustment selection
display.
2. Press the right or left side of SEARCH button
% to select “CLOCK”.
3. Press ENT button 2.
4. Press the right or left side of SEARCH button
% to select the hour or the minute.
5. Turn the Rotary knob & clockwise or
counterclockwise to set the correct time.
* The clock is displayed in 12-hour format.
6. Press ENT button 2 to store the time into memory.
7. Press ADJ button 4 to return to the previous mode.
Note:
• You cannot set the clock when it is displayed with
only the ignition on. If you drain or remove the car’s
battery or take out this unit, the clock is reset. While
setting the clock, if another button or operation is
selected, the clock set mode is canceled.
Sep 13, 2010 | Clarion DRX7575z CD Player
Unable to set microwave clock
sometimes the clock resets after unpluging for a short period. when you restart / power up note the time it starts at generally 12:00 miday good luck gbw
Feb 07, 2010 | Sharp Microwave Ovens
Set the clock on a clarion cd player?
Setting the Clock
1) Press and hold in the BAND button [4] then press the DISP button [9] to toggle the display to the clock mode.
2) Press and hold in the BAND button [4] then press and hold in the DISP button [9] for at least 2 seconds.
3) Select left or right to adjust the time using the a-selector
~Adjusting minutes
Each time you select right >> using the a-selector [3], the minutes increment up by one digit (0 to 59).
~Adjusting hours
Each time you select left << using the a-selector [3], the hours increment up by one digit (1 to 12).
*The clock only displays time in a 12-hour format.
There is no way to toggle the clock to a 24-hour format.
4) Press the BAND button [4] to set the clock into memory. This also resets the seconds counter to zero.
Note:
*The clock can only be set by turning power on to the unit and switching to the clock display mode. You cannot set the clock when it is displayed with only the igntion on. If you drain or remove the car's battery, the clock must be reset. While setting the clock, if another button or operation is selected, the clock set mode is canceled.
Dec 08, 2009 | Alpine Car Audio & Video
First off who installed the radio?
If you or a friend did you ned to make sure that 12+ always is supplied to the radio and is hooked to the appropriate wire on the radio. If it does have 12+ always and it is hooked up correctly a replacement of the radio is in order, however I bet the wireing to the radio is crossed or the radio itself is uncorrectly installed.
The reason is the accessory and 12+ always wire has been crossed or was never there to begin with.
Nov 17, 2008 | Eclipse CD8445 CD/MP3/WMA Receiver
How do I set up the clock?
Here are the steps to set the clock:
1. Check that the main unit is in standby mode (clock displayed)
2. Press and hold the [DISP] button
3. Turn the [VOL] button to adjust the time (Right: Minutes will advance, Left: Hours will advance)
4. Press the [DISP] button briefly
These steps were taken from the owners manual available at: http://www.eclipse-web.com.au/DOWNLOADS/Owners%20Manuals%202008/CD1200.pdf
Sep 24, 2008 | Eclipse CD1200 Car CD/ MP3 Player
Setting the clock on Eclipse cd5405 deck
Push the function button once. turn the right knob (SEL) untill CLOCK ADJ shows on the screen. push SEL in one time to lock in CLOCK ADJ and the hours will blink. Turn the SEL knob to set the hours. push SEL again to get to the min. Turn SEL again to set min.
Aug 29, 2007 | Eclipse CD5405
Car Audio & Video Logo
146 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Steve Sweetleaf
Steve Sweetleaf
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
