Question about Motorola Mobility RAZR V3
Razr dead for good?
My razr simply stopped working one day. When you open it and power on, the keypad lights up, but display is blank (not white), and does not dial. Just wondering if it can be fixed. By me preferrably. Thank you in advance for any and all assistance!
    Brigadier General:
  • 7,752 Answers
The flexcable on the phone needs to be replaced on the phone...you will need to take the phone to a mobile service center to have this done....
Posted on Dec 28, 2008
Phone is working but the screen is black
squeezed lower left side of display and powered up ,problem fixed
Sep 12, 2010 | Motorola Mobility RAZR V3
2007 razr v3m can make calls but display screen
problem the solved.What makes the screen of a phone white is when the screen of the phone is damaged or the flex of the phone has cut.
The flex of the phone is attached to the keypad of the phone. They are joint together.
The flex of the phone can get weak due to opening and closing the phone all the time.It might be the flex is weak and it needs to be replaced.
If when replaced and still no display, then it's definitely going to be the screen of the phone that will need to be replaced.
Would advice to prevent more damage on the phone, you can give it to a mobile repairer to check it for you if you can not.
Take care.
Mar 20, 2010 | Motorola Mobility RAZR V3m Cellular Phone
I have an older model motorola razr that the screen went blank but it is stil working.
Yes this is the most common problem with the RAZR.
There is a small cable connecting the screen to the keypad part of the phone. This cable is called a flex cable and fits through the hinge of your RAZR so that the screen and keypad are connected even as the phone opens and closes on the hinge.
BUT, this cable often wears out or can even be severed even a slight bit, and the phone would then work, but only the bottom half, the screen would be dead. I fix this issue for people more than any other cell problem. You need to have the flex cable replaced.
Nov 28, 2009 | Motorola Mobility RAZR V3
Hey good day :) my moto v3i just stopped
my moto v3i just stopped turning on. everytime i press the power button, the keypads just lights for about 1 second ands then turn off again. i tried to use the combination key, POWER BUTTON (+) * (+) # and then the screen displays the BOOT LOADER thing so i thought this phone might be ok
Jun 05, 2009 | Motorola Mobility RAZR V3i Cellular Phone
Blank Screen
Remove the battery and SIM card, wait about 5 minutes and re-insert everything. If the screen shows up, well and good. If not, there is a problem with the display and you will need to get the device serviced.
Sep 06, 2008 | Motorola Mobility RAZR V3
Motorola RAZR V3x Whiye screen problem
I have managed to fix the problem by doing a software update.
I stumbled across the solution..........I had the phone connected to the computer when I started it in the 'boot loader' screen as opposed to just turning it on. This time the computer recognised the phone was connected and through the motorola software update program I was able to update the software and the phone now works fine.
BTW I did lose all my address book, messages etc.
To start in the boot loader screen hold down the * + # + pwr keys all at once.
Jul 29, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Handset dead
Upma I have experienced this before and if the phone has been damp by body heat or other moisture then it does do this. try drying it out with a hairdrier on a cool setting. then leave it to dry properly for a couple of days in a warm NOT HOT place. the keypad will start to work and the battery will settle as well. let me know how this goes. t1m0thy
Jun 27, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Krzr wont turn on.keypad flashing??
Either your battery is completly dead - and thats easy to replace for under $40 - otherwise it may be your flex cable - but the k1 is built stronger than the razr ever was - did you drop water on it? check if the white sticker under the battery is still white and not pink
Jan 21, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Motorola RAZR V3m External Display Problem
Ive had 2 silver razrs and my first did the exact same thing it's a sensor intenally that wears out ecspecialy on the silver ones dont ask why? But i sent my back and replaced it. If you pay insurance everymonth like me use it!!
Jun 01, 2007 | Motorola Mobility RAZR V3
Only displays white screen
Hi, Its a strip problem,when u change your mobile strip then screen willbe ok! By: M.Qasim Butt
Apr 13, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
