Question about RCA 24V511T 24" TV
<<<>> hello i have a big screen rca its around 1980 something . and its making a hissing noise , picture is fine and the sound is fine as well ...can you please tell me what the problem is ..
  • adamwes Apr 05, 2008
    my rca was hissing now it's arcing any saving it? where are the high voltage leads?
  • 25 Answers
Yep its a high voltge arc. You may also spell a strange ozone odor.
Turn off the lights and see if you can see it it arking inside the set. Sometimes its fixable by putting silicon over a crack or cleaning off dust but sometimes its inside the High Voltage flyback and it needs to be replaced.
Beware the tube can hold 30kv for months so dont touch the high voltage wiring unless its discarged.
Posted on Jan 14, 2009
    Novelist:
    Champion:
  • 236 Answers
Sounds like you have a high voltage arc if the sound is not coming through the speakers. Possibly the high voltage leads are not pushed in all the way. Be careful! Make sure the set is off and you may also want to ground these leads before you touch them. Youcan get a nasty shock if you don't.
Posted on Jan 12, 2007
SOURCE:
Samsung tv blank screen
It,s shot, Get a new tv,End make shure not to get a samsung,
Nov 03, 2012 | Samsung Televison & Video
Hissing noise horizontal lines
Hello erl, hi.... the hissing noise is usually caused by high voltage arching, but this is suppose to be soft. if the hissing is unusually loud, the high voltage transformer clip cap may be loose, this may cause the horizontal line you see on the screen. take precaution when dealing with this.... here are steps that may help..
1. unplug the unit. allow around 5 minutes for all voltages inside the unit drops to a safe level.
2. open the back cover. place the monitor face down on a table with a dry clean rug or towel.
3. locate the picture tube. on the top side you will see a wire with a cap at the end.
4. use or wear a cloth glove and feel if the cap is loose. re clip the cap and make sure it is secured.
5. replace the back cover.
Feb 15, 2012 | Philips Computers & Internet
Air/Hissing Noise from Brake Pedal
this noise is caused by a defective power brake vacuum booster, (big round thing behind the master cylinder) the diaphragm is leaking vacuum.
May 06, 2009 | 1995 GMC Suburban
52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Apr 23, 2009 | RCA R52WM24 52" HDTV Projection Television
Big screen no picture and makes heart beat noise?
can be a faulty mains board, does the sound still work? if not, can be mains board, and at last if there is a continuous clicking sound it a faulty power supply.
hope that help
pls rate me!
Mar 21, 2009 | ViewSonic N2750w 27 in. HD-Ready LCD...
D52w20 rce not coming on
hissing noise indicates to me you have a high voltage problemm... likely a flyback. could be a crt or splitter. if its the flyback then the horizontal transistor could have blown. I would not suggest working on this unless you have had some electronic experience.
Oct 31, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 32
this problem may occur due to some drysoldering of some components on the mother board...mostly in the power supply section.
Jul 09, 2008 | RCA F32450 32" TV
TV screen wont turn on but just a loud noise coming from the tv
I think maybe the G-board needs to be replaced. A TV shop will have to repair it. They normally start around $200.00
Jul 02, 2007 | Panasonic CT-32G23 32" TV
56" RCA projection TV (FLYBACK related problem)
the base to emitter of the hot will read short on a diode checker/test on ohms it vairies but typically about 50 ohms.e to c, or b to c should have very high resistance. unsolder the collector of the hot. make sure all solder is gone. now test the ohm between your tuner ground & the pad of the hot collector it should read open.
Jan 16, 2007 | RCA P52921 52" Rear Projection Television
RCA 24V511T 24" TV Logo
48 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
