Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Ice forming where ice comes out to refrigerator
Ice cubes won't come out on our side by side refrigerator, because the opening ices up and makes the freezer door stick.
  • dkl1952 Nov 18, 2008
    I have the same problem with my Kenmore Side by Side. Ice is forming inside the icemaker where the ice is dispensed and the freezing ice thickens and makes opening the door difficult. I removed the ice bin and cleaned it out, but the problem continues.
I am not sure if this is the same issue or not.  the flap that closes after you have dispensed ice does not close or seal all the way.  The gasket is worn down. the result is warm air get up into icemaker and warms ice and refreezes in one block so now the dispenser gets blocked.  We had to replace the flap in the door.  bought the part at an appliance part  store (not sears) they were helpfull and looked up the part needed.  Also a sheet of ice forms on the  bottom of the freezer.  When water is dispensed a small bit drips inside freezer in back and runs down to botom of freezer slowly forming a sheet of ice.  Use a hair dryer to defrost and then you must unclog the drain in the back at the bottom of ffreezer to allow it to drian.  Once we finally unclogged the drain we have not had any problems for about 2 years.
Posted on Feb 18, 2009
Freezer won't make ice cubes, but does provide cold water.
The water and ice maker are two seperate water control valves built onto the same. Your water control valve for the ice maker may be defective and require that you change the set. Fill ice maker with tap water and allow the water to freeze. If the ice maker dumps the ice into ice bin and then does not refill then this points to the water control valve. If the ice maker does nothing after water freezes then the problem is the ice maker. Send me a model number and I will look up the part numbers for you, Thanks, Sea Breeze
Jul 08, 2012 | Frigidaire Refrigerators
My ice maker doesn't make enough ice cubes
Is the ice maker itself filling normally, meaning where the cubes are made gets enough water to cover the complete area or just a few slots? If not then check the fill tube where the water comes into the ice maker to make sure no ice has formed blocking the water from coming in.
Now if ice production in general has slowed, going from every 45 minutes or so to like every 6 hours, then your machine more than likely isn't getting cold enough. The ice maker requires the temperature be at least 10 degrees F or below for it to function properly.
Jun 16, 2012 | Kenmore Side by Side Refrigerator
Ice dispenser does not work unit makes ice and water works fine
As long as the ice trays are filling with water, it's not actually the function of the ice maker to make ice. Ice simply forms because the freezer compartment is cold.
The icemaker's function is to sense when ice is formed in the trays and to dump the ice into its container.
This requires the use of a thermostat to sense the water/ice temperture and 'tell' the icemaker when it's time to dump the ice.
During the dump cycle, a heater briefly comes on as the arm swings through the ice cube compartments to assist in loosening the ice cubes and make them easy to dump.
If the icemaker is filling with water but you get no ice, I suspect that either the control circuit (thermostat, relays, and wiring) is not 'telling' the heater to come on, or the heater is burned out.
Some units also have a timer circuit such that both the timer contacts and the thermostat contacts must be close in order to initiate a dump cycle (i.e., it must be time to dump and the water in the cubicles must be frozen).
A skilled homeowner could make these repairs, but if you don't feel comfortable taking your icemaker apart and testing the components, I advise leaving the job to a qualified repairman.
I hope this helps. Good luck.
Sep 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Arctica won't make ice; ice was frozen solid yesterday. After removing, it won't make any more ice cubes.
Sep 12, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice is forming around the auger under the ice bin. constantly have water dripping from ice cube shoot
the door that the ice comes down to fill glass is not closing; the ice chute door just above the lever to fiil glass with ice it is either jamed with ice or is broken and needs a new repair kit.you can inspect by opening door and look at approx. 3 inch door that ice falls threw to see if closed.warm air causes ice to form.
Sep 07, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice maker dripping water fusing ice cubes
The dual water valve (solenoid) that open and let the water from the line when the ice maker calls for it, is leaking and needs to be replaced.
Aug 17, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker will not make ice cubes...it dispenses water, but no cu
two common problems are the spring comes off the feeler arm or the ice cubes jam on the sweeper the plastic arm with fingers on the edge of the ice maker
Jul 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool side-by-side refrigerator ice dispenser
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Oct 13, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
170 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
