Question about Phoenix Gold PD-386 Car DVD Player
Pal/ntsc how do you stop the picture from flickering
0 characters
1 Points
Pioneer DVD player the screen will not stay still
maybe the dvd is st to pal/secam, and your tv is set to ntsc...look for the pal/seca/ntsc button in your remote control of dvd player and set the player to recievers are set to ntsc by default if you are in asia...
Oct 15, 2014 | Car Video Players
I cant get the color to my screen
the screen is in PAL mode you must Push the input button then the up or down button to switch between PAL and NTSC in that input
Jan 15, 2010 | Sony MV-7101DS Car DVD Player
Black screen
hi there,
try to check if your using pal or ntsc...try adjusting the video output and you'll probably get the picture eventually.
hope this helps.
Jan 30, 2008 | Pioneer Car DVD AVH-P6600DVD Car Video...
Video keeps flickering
Jan 30, 2008 | Farenheit DVD-36 Car DVD Player
Portable Mustek DVD player indicates Wrong region
Thanks Guest Mar 07, 2008!
Solved my region problem with the code 9735.
Nov 30, 2007 | Car Video Players
Alpine dve-5207 & tmx-r705
Hi Allan,
To my understanding, both are inter-compatible to either NTSC or PAL.; the player will auto detect what format the disc is and auto-switch over. As the manual says, "DVE-5207 automatically changes the video output signal (NTSC or PAL), according to the disc." On the other hand, the TMX-R705 needs manual settings (2 ways):
1. NTSC and PAL can be directly switched when the DISP on the TMX-R705 remote button is pressed for at least 2 seconds; or
2. On the TMX-R705 remote, press the SETUP button, press the DOWN or UP button within 10 seconds and select AUX 1 SIG. or AUX 2 SIG., press the LEFT or RIGHT button within 10 seconds to set the selection.
Just an after thought, pls verify that your DVD Region number is either 2 or ALL. Additionally, you can verify the color format the unit is using (as well as the disc) by pressing DISPLAY during playback on the player.
Should this not be corrective, perhaps you need to check the grounding/wiring and the interconnections cables.
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Nov 14, 2007 | Car Video Players
Necvox Fd 7569 Headrest monitor
NTSC and PAL you is the after you press the mode, you press up/down very fast
Sep 22, 2007 | Necvox RE-8169D 8 All-In-One Motorized...
There is a Sound but can't see the image of a DVD
NTSC and PAL are DVD Formats data formats, like CAD and WMA. You need to NTSC to PAL converter to convert the video before you burn it, its a long process and you may lose noticeable quality. My neighbor does this with NTSC videos he d/ls of the net. Search the net you may find a conveter(software) for you. And a fast computer would help, he has a dual core 2 and it still takees a bit of time.
Aug 25, 2007 | Kenwood KVT-817DVD DVD/CD/MP3/WMA 7"...
Sony Mobile DVD MV-7101 Display is Black and White
Try pressing the arrow up on your monitor while it is on the PAL mode. This is what I just tried on my systema and it switched from PAL to NTSC.
Jan 07, 2007 | Sony MV-7101DS Car DVD Player
Phoenix Gold PD-386 Car DVD Player Logo
16 people viewed this question
Top Phoenix Gold Car Video Players Experts
xxxxxx xxx
Are you a Phoenix Gold Car Video Player Expert? Answer questions, earn points and help others
